View Full Version : Drag Racing
- Fastest FWD in FIS
- 2015 MDIR Schedule
- K-Series Shift Cables
- Tires streched too much to be unsafe for racing?
- Fixing wheelhop: What's left?
- A.L.R. b-series civic rebuild for 2015 ogs1320 all motor class
- Dynamic Performance catch pan
- Videos from last 2 Sunday E-Town Test n Tunes | ERacer
- g-force shifter
- K Series vs J Series (N/A Development)
- Kenny's H22 civic 62mm Street car
- K24 MR2 Spyder on a Drag Radial - 12.4@109
- Pointers, tips, advice on better 60 foots.
- Do drag cars benefits for rear sway bars
- DEC wtb thread
- Dec FS Thread
- Best Racing suspension
- 205/60-13 M&H dot on 13x8 wheel?
- skunk2 ultra 5.5 vs pro-jay?
- Borg warner S300sx power
- K24 Chain Tensioner
- Stewart electric water pump
- Which fuels contain MTBE?
- Drag EG build. From Russia
- Street Fighter/Real Street RWD-AWD Cars in Plans for Import Street Nationals
- 2014 Racing Season Wrap Up - Personal Bests!
- Slicks, brake clearance
- East vs West: WTOL-S - Ososik Media
- Drag radial setups
- Axles breaking EVERY pass: advice?
- TWIN DISC what Clutch Master Cylinder
- 1st Street Import Nationals, December 6-7 2014, Orlando Speedworld
- WCF 2014 Round by Round Videos by ERacer
- Making a B20b turbo hatch civic
- Complete Race Results for WCF!
- Switch for MSD to CPR
- Simple Setup CRX Goes 10.6x @ 138 Mph At WCF!
- low budget turbo B20
- Cutting off tech cards at WCF!!!
- World Cup comments
- Have y'all heard of SCF's 3 piece front end?
- Rpm Shift Point (Dyno Included)
- Switching from Hondata to a Fancier one?
- Piston to Head clearance
- Nov WTB Tthread
- Nov FS Thread
- Attention 10.00, 10.50, and 11.50 Index racers that plan to run at WCF!
- s300 security password problem
- Awd k24 civic 9.4@152 Cmi @ sac
- 10.7@127 all motor EF sohc civic @ sac raceway
- Track Rental Tuesday & Wednesday MIR WCF!!!
- WCF Minimum ET For Heads-Up Classes **NEED TO CONFIRM EVERY HEADS-UP CAR**
- 1997 Honda Civic VTI 425whp Video Footage
- Turbo Experts Need Advice
- Xenocron's Fuel Test Results - VP M5 versus FTW Black (methanol fuels)
- Index Cars??? Who's out there?
- Switzer USE rips an 8.7@163
- ImportDPS New 3pcs Front ends
- Anyone use or using AMS 2000 boost controller.
- Race Engine! Oil Orifices...
- battery mounted behind rear bumper nhra legal?
- clutch line/slave setup
- bolt on gsr civic hatch 1/4 mile
- Question golden eagle main Girdle arp bolt torque
- GT4294R exhaust housing size
- Alignment Puzzle- struts blown?
- Rwd b series crx 1/4 mile run CMI sacramento fall fling
- b16b tuning and upgrade
- T1 Cam Trigger RPM Question
- CMI Fall Fling 2014
- Couple of 9 sec Hondas @ CMI sacramento
- The Sauce Spot World Cup Finals Contests
- race/ tucked radiators set ups
- What M+H skinny to get with 15x3.5 traklite launch wheels?
- 1,600ft roll racing @ Pocono Raceway: Part Deux
- Diapers or 2" Catch Pan Mandatory for WCF
- Burn out issue
- Help with rough up/down idle
- My Civic Doing 12's at the Drag Strip
- Spinning too much? Figuring out 1-2 shift
- 85lb or 100lb seat pressure springs?
- Fuel question
- FL2K14 Coverage!
- Slowmotion Motorsports Video (Ohio)
- Learn, Practice and Race all day for only $20! IDRC Finals OCT 18th and 19th
- B20Z P8R Head Crower III Non Vtec 11.4@116
- Minimum ET For Heads-Up Classes at WCF
- SFWD Shootout @ Sport Compact World Challenge in Orlando Speedworld October 24-26
- In car video of my 1st 8 second pass
- WCF Roll Call Raffle - Nov 7-9 at MIR
- Target Power
- tire temps after burnout
- Fastest v6 All Motor
- OGS1320 Fall Nationals at E-Town Videos | ERacer
- Narrowist/lightest tire for 15x6 wheel?
- Help with Drag rims and slicks
- dynosaur performance civic on motec m150
- IFO Gainesville Oct. 2014 Review + Pics
- Hitting limiter in 4th gear
- Evaluate my time card
- Seelback's stock internal B20zVtec N/A&125shot e98 dyno vids pics
- Tire size for all motor
- Tire size
- AZ_CIVIC 10.2 @ 141
- IFO New England Dragway
- Any one tried 255-60-15 mt's?
- OCT WTB Thread
- Oct FS Thread
- slick tyre selection
- Advanced Engine Blueprinting and Technology Instruction Video
- All motor street class times
- Who is the Spec Clutch rep???
- 10 Sec Stock Block All Motor H2B
- How is the weather at Bakersfield import face-off?
- look out for TD autowerkes
- ignition timing question
- Summer iREV Video Coverage
- Oct 18th & 19th IDRC International Finals - Auto Club Dragway, Fontana
- Honda-tech new layout.
- 1.3 60ft
- Next Episode Garage H2B Drag build underway
- Deck height questions
- CKF with C.O.P.??
- Any ef/da get into 10s with stock cable trans?
- Import Face-Off Noble OK Summer 2014 - SFWD Highlights
- Radial for 15X8 Baleks?
- Need help addressing traction issues, Turbo DA integra 23x9x13
- Bolt on Gsr Eg Hatch 13.9
- Rickbeastwood's H2B SFWD Journey (Warning lots of pics)
- my first competitive all motor drag build
- Fastest N/A Fwd at altitude
- Finaly a DA 3pc wide front end!!!!****
- Stripped Thread in Block
- Cannot boost less than 25PSI first gear
- Broken Vanjen Clamp Latches (with picture)
- Logging EMAP and fuel pressure
- Noble IFO, who is going?
- chris' hoodrat civic goes 153
- 4 piston skunk2 ultra?
- Import Showdown September 20-21
- KKT Racing New SFWD Build Bseries Civic
- Full Blown Fuel Pump - Cant put cover back on... Issues with Track Officials?
- ifo rule question.
- spherical trailing arm bushings
- 99 Civic SI Full Race Traction Bar Install?!?!?!
- 8 Second EP3
- Boost in 1st and 2nd gear?
- FALL NATIONALS Oct 4-5 ETOWN
- Trying to finish planning my new setup for next year
- Sept FS Thread
- Sept WTB Thread
- Extreme Wheel hop Even With Traction Bars
- Rollbar Legality
- 225's drag BF's suck on low pump gas boost video
- Gutted H2B hatch on nitrous 11 sec 1/4mile!?!? Advice
- Simple Setup- 10 Seconds Right Off The Trailer!!
- Bolton/Tune K20Z1 Rsx-S Goes 12.9 On A Drag Radial (Vid Inside)
- need some help deciding on gearing
- Ferrea 5000 valves
- 9.72@147 Testing in my 98 Neon
- Tires for dyno?
- b18c5 11 sec build all motor
- how much of a difference is there on airing down m&h 235/60-15 dots?
- Worth changing from 8'' rim to 10''?
- IDRC Sin City Nationals - Sept 12th-13th @ Las Vegas Motor Speedway
- 19th annual Haltech World Cup Finals (Import vs Domestic) at MIR on Nov 7-9
- Bigger Tire??
- BADDEST 99 GOES 10.14@133
- First time at track very disappointing, help!
- Honda Day Videos by ERacer
- Car breaking up in Boost.
- How to keep cold intercooler/piping?
- b18c block b20 crankshaft
- Direct fitment roll cage steel plate?
- ANNOUNCEMENT: NEW MFactory SFWD Drag Car
- My custom mounting bezel for AIM MXL in my ek hatch
- Pittsburgh raceway park IFO the 31st
- IREV Sunday August 24th @ Maryland International Raceway!!!
- D2B 10.6 @ 134
- Honda Day E-Town by Ososik Media!
- SFWD Shootout @ Maple Grove September 6 & 7
- Cam degree problems/questions
- k coil dwell time settings
- Weird Clutch Issue -Please help troubleshoot
- LSD diff
- 15x6.5 +40 good size for 235/60-15 M&H DOTs?
- Booster delete master cylinder size
- Skunk 2 LMA Failure
- Loarca Racing (Hondata SFWD) Going East?
- Intake, TB and piping for 900hp?
- EF traction bar/radius rod modification for proper triangulation.
- Illicit Forged and Strada Ind..
- SOCAL RACERS! NHRA 9-SEC LICENSING EVENT! 8/23-24 @ FONTANA
- Mr.johnson Goes A Bit Faster. small frame, stock gear set.
- August WTB Thread
- August FS thread
- whats the record for 98mm all motor b series
- Paradise Racing Triple Bosch 044 set up?
- how much power can hook on 205/50-15 drag radials...
- WANTED: Testers for our new prototype parts
- Which drag rims for big brake clearance
- Liberty transmission ?
- 8/2000 or 1000cc inj.
- b20v 13.9 street tires
- spring rates
- Fastest Bolt-on/Tune/Stock Internal DC5 On A DOT Drag Radial
- Drop in pistons question
- Tilton Clutch B Series which flywheel bolts? Auto or Manual?
- Quick motor mount question (Steel)
- precision 6262 vs 6266?
- need everyone HONEST opinion **livefeed for larger SFWD events**
- Injector question.
- brms drag series fayetteville
- motor mount durometers
- Need help with wheelie bar preload.
- Dyno bad for gearbox?
- Lets Talk SFWD Suspension
- Intercooler piping.... 4" too big?
- Let's see your AMS (all motor street) class cars
- anyone running a thicker head gasket?
- 2 or 4 pole kill-switch required?
- The Little integra that could, that no longer can! :(
- Direct Port Nitrous Kit?
- Lauch control RPM
- Fuel Tank vent options?
- Preferred water pipe/neck setup
- My first crack at competitive roll racing: "Roll Out to Reach Out", Pocono Raceway
- Single cam finally ran 10's
- MEMBERS OPINIONS NEEDED!!!
- Need help for a low budget daily driven drag setup
- Radial Skinnies: 165/80-15 tire.
- B18 Valve spring-lma bore clearance.
- Need help making 600 or more on a b18c1
- When tubes are needed?
- IDRC involvement in the Buschur Racing DSM evo shootout
- LS Crank/Rods Gsr Block/Pistions
- K-Powered Fastest FWD Turbo K?
- First time at the strip and broke something...
- chassis harness with switch board
- 22 inch slick
- 66mm street car eg build
- NEW...SpeedFactory SFWD Project....
- So close to 9's on a 62mm
- Race fronts
- SoCal Racers! Get Your 9-Second License! July 26-27 @ AUTO CLUB DRAGWAY
- July WTB Thread
- July FS Thread
- SFWD & All Motor Shootout, Saturday August 2 in Orlando Speedway
- Fastest/Quickest DOT Tire Street Car Ladder (Forced Induction/All Motor)
- Who makes, Serious - D series drag racing header
