View Full Version : Drag Racing
- VIDEO Chapulin Performance 8.56 @ 176mph
- Tire pressure gauge
- 8/17/2014 IFO Albany!
- MIR iREV Elimination Round courtesy of E-Racer Productions
- has anyone used the speedfactory drag radiator?
- Accufab 90mm TPS Question.
- T1 triger and aem v2 sync error
- Secondary fuel system
- First time out on slicks, worse 60' than on street tires?
- Racing harness install questions
- Looking for feedback from people who race with either 6266dbb or gtx35.
- damage on countershaft
- T1 Hall Effect Cam Sensor Life Time
- Anyone use a IPG solid aluminum shifter bushing?
- 4th annual Summer IREV at MIR on Aug 24
- Adjusting Pedal Stop on CC Twin Disc?
- Bigger Turbo, Bigger Problems
- 93 Civic Build
- r/s ratio bore and stroke
- Question for the r888 users
- pistons and valve springs/retainers
- dashes and whole car wiring
- Gearing advantages for track
- 45 Psi or 3b boost gauge ?
- pro-am turbo
- Liberty plated gearset not allowing case to close...
- Anyone making over 700hp using a Tunerview RD1?
- Boost issue throw ideas at me
- Stock GSR Transmission Tolerance
- b17 distributor problem in b16 head, crower cams
- Sway bars removed
- more info on this car? did he break the record?
- H2B/spray Disapointed with ET numbers..Seasoned Drag people give me some pointers! :)
- should I sump the tank?
- Burnout porblem in dog box
- IREV @ MIR updates?
- IFO tulsa who's going?
- Gear-x 1-4 drag gears
- slicks on a 15"
- IREV Sunday June 8th!!!
- IDRC STREET TUNER MAYHEM - Bandimere Speedway
- Drag Radial/ Slicks problem
- Need some help
- My SFWD/True street VW build
- FTW Green Race Fuel
- My First 9second
- June WTB Thread
- June FS Thread
- Deciding between 13x8 and 13x9 rims on EK
- TD Autowerkes SFWD hatch receives new goodies.
- Cole from Speed Factory with an 8.38@181 pass
- Civic hatch 3in and 4in exhaust setups
- Strain gage Pin out
- Optimum temp for slicks
- stock fuel system good till what hp?
- 1st Pass of Test & Tune @ Lebanon valley dragway
- Sensors to use with Motec
- bogging off the line
- Explain index racing to me
- What do you guys like for plugs these days? Copper or Iridium
- GRS SFWD Shootout & Match Races: Team Chapulin Perf vs Team MAR Perf: JUNE/28 Orlando
- Exospeed Fender Replacement Timeframe?
- Running with skinnies...
- Chris Cashen FIS 62mm wreck (vid)
- How to make Strange Engineer Drag Coils Work
- CMI June 1st @ Sacramento Raceway
- Question for guys using kingpin machine spherical ft ends
- Who's going to IREV June 8th?
- ati damper, use or trash?
- Someone before the line?
- Spring Nationals at E-Town Video Coverage
- Bit of a strange question - pressurized air tanks legal?
- Will the BW s400 clear my manifold?
- IDRC West Coast Nationals Video Coverage
- trying to decide on which cams to run
- On that 9 second quest!
- gotta gloat a little
- b18b1 boosted
- Proper way to burnout/launch
- 1/8th mile spin fest new car and new setup.
- SFWD Brazil, best 67mm turbo in my Build? Gt4094R or 6766?
- 2.85 Liter K & F Pro Stock Engines Coming
- GRS 1st Street Import Nationals, September 27 & 28 in Orlando Speedworld
- Best drag chassis?
- Boosted car hot lapping - How much is too much?
- Russ Collins (RC Engineering) Passes Away
- 5th gear cuff
- Twin disc probs
- IFO Vegas
- 7th grade math: drag racing style. Help me out!
- little eg street/track car build
- Main studs or main studs w/girdle for B20 build
- Team Bahrain/Drag Cartel all motor breaking into 9.5s and 140mph
- gsr 4dr first time at track
- B20Z EF Hatch Race Car projet
- B18b1 turbo 1/8th mile, quest for 10s
- Ferrea Rocker Users
- acid dipping, how much weight can be saved?
- Radiator core
- CLASH OF THE WEST COAST (CMI) MAY 17TH & 18TH FONTANA
- 32 Passes
- Is Trap Speed Relative to E.T.?
- Car will not leave, bogging
- Quest for9sec past
- Street tire for 600whp daily driven prelude
- What aluminium sheet for EG Drag Wing?
- first time drag racing. need advise
- upper control arms recommendations
- California Smog
- Scott Kelley's Scion xB ...
- RameyBuilt Spring Nationals Go-Pro video and our new personal best of 8.56
- 88 camaro rs vs 97 civic
- IFO Vegas coverage
- Coolant holding pressure after its cooled down...
- Race numbers?
- May WTB Thread
- May FS Thread
- M&H 26-13 ?
- Axle breakage issues: Advice?
- what racing battery???
- IYFO??? VEGAS?
- Spring Nats SFWD predictions?
- Rear drums for track burnout!
- Vegas IFO May 4th who's going?
- AEM Traction Control Help
- IMPORT FACE-OFF: Joliet, IL (Chicago area) - Route 66 Raceway - Sept 21st, 2014
- when i launch my car with 2step
- Anyone have coverage of CMI Spring Showdown at Sac Raceway 4/27/14?
- Vtec eliminator pins
- My Street to Drag CRX Build
- turbo question
- Key removal
- new drag racer
- FastGuyRacing SFWD Build Thread for 2014
- Dynamic Performance debuts new Fuel Injector Clinic SFWD car at Honda Day!
- AEM V2 vs S300 V3 discuss
- Almost 190mph, went 187.34mph 1/2 mile. 10,026rpm 5th gear! Hondata TC doin work!
- Import Showdown: May 25, 2014
- Skunk2 pro series valve springs Xp
- SPRING JAM (CMI) Sacramento April 27th
- coolant line ? for 500hp lsv
- What EMS??
- CRX Roll cage
- 11.50 Index builds
- ACL orbit oil pump
- Any advantage in skinnie tire size
- Cody's New All Motor H Record
- Honda Day Atco '14 Round by Round Video Coverage
- IDRC Update: Cheaters, Rats? and Racers
- 1/4 mile insight autism awareness car
- SFWD Mech Tech Shootout, May 16 2014 in Orlando Speedworld
- Does your race care need a ride to the track?
- Final Drive for 900+hp
- finally reached one of my long time goals
- IDRC/Bisimoto Interview- Ososik Media
- Press Release: CLM Motorsports Brings Aboard Maingear As Title Sponsor
- Mil spec engine wire harness
- Honda Day Atco 2014
- melted plug turbo lsvtec tuning issue? aem ems
- Jotech Integra 8.56@177
- Are you big power / dogbox / racepack guys still using stock VSS/harness plug?
- Using clutch on dogbox?
- What could be my E.T? trapping 103.4mph noob inside
- Slicks offset actually hurting my traction? What offset are you running
- Honda Day: Official Updates
- All motor K series slick size
- *Next Episode Garage 62mm H2B EM1 FIS/SFWD build*
- Denso and South Bay Fuel Injector question
- Connecting Rods Selection
- Where to buy these lug nuts
- Need a helmet
- DT Racing Division 2014 Race program *Update*
- Tim Grey Racing 400hp Dyno Video.
- Need help with Aem sensors
- Best tires for a weekend warrior.
- 8.47s kkt racing from dominican republic
- How often are you guys changing your fuel filters?
- Drag strips in north east USA
- lets see your toggle switch panels
- April FS Thread
- April WTB thread
- 22x8x13 slicks on steelies? Success or failures?
- IFO St Louis April 6th
- IFO Columbus Ohio Roll Call Thread
- Hondata s300v3
- DIY Air Intake through headlight / 1/4 Mile questions
- Honda day all motor class roll call
- crazy boost creep issues
- OFFICIAL IDRC WEST COAST NATIONALS - Fontana, CA - April 12, 13th 2014
- ECU relocation / mounting plate picture thread
- EK Traction bar
- Need help for a 9 second pass
- safest hp on fully built gsr 6262 t4 precision
- What are the best drag radials
- Prayoonto Racing vs SpeedFactory
- Forward facing oil drain
- Allvtec's EG hatch 9.0 pass
- UPDATED...IDRC Rules and classes!
- Del Sol 3 Piece Front End
- Best street slicks
- noticeable 60ft difference using solid bushings
- Kirkey, Stock, and JDM Recaro Seat Weight!!
- Steve/Lsthatch J32 turbo new PB; 9.70 @ 150
- best honda chassis for drag racing?
- Honda Day Atco, who's going
- Wichita IFO, March 23rd!!! Who's going??
- 1/8th mile last night..
- Aluminum Exhaust
- Trucks/Car Trailer's for race day
- need some help
- Rameybuilt finally into the 8s
- Precision 6766 vs 6768
- 2014 IDRC Rules Announced
- IFO Wichita Newb Questions
- Bolt-ons/Tune RSX-S Goes 13.31 Radials
- Press Release: Kaizenspeed joins 2014 race program
- question about tire screws
- Not a Honda, But it Will Be a Drag Car! Pics and Video Inside!
- Twin Disks: Comp clutch vs Spec
- How high can I rev?
- Push button for starter, fuel pump? and such?
- High HP timing belt question
- rear diffuser?
- PPG final drive cracks.?
- Fuel Injector Clinic sponsors TX2K14, giving away free set of injectors at event
- Import Invasion 1 at Cecil County Dragway
- Best Price on Slicks/Rims??
- D16 SOHC NON VTEC SFWD 9:71@146 in PR
- Re wiring Fuel Pump Wires have a question 340 stealth
- 2+ years later and back for some fun -- IPGParts.com Turbo Civic
- Drag racing coilovers?
- New 8th mile pb
- Ef twin disc question
- Wilwood DynaPro H/A & 13inch wheels?
- Staging brake / front brakes on pedal set-up.
- valve spring suggestion
- Hondata 4 port boost control solenoid
- Valve and spring compatibility question
- open stock front bumper vs closed off bumper. ET results
- Honda Pro Parts sohc eg 9.96
- Moran injectors
- 3 piece EF front end
- new to FWD !!??? to who has knowledge of wheel and tire combination
- What wheel should I get for 225/50/r15?
- Beware!!! Wiseco piston company quality control
- Beware !!! H22a Gates Racing Timing Belt crack
- 225/50-15 bfg drag radials on crx questions.
- SCW OsoLatest: 2 for 1
- Gringo's quest to 190mph in the 1/2 mile.
- carbon fiber hatch. whats the best/highest quality and fitment?
