View Full Version : Drag Racing
- street /drag
- March WTB Thread
- March FS Thread
- Solid shifter bushings for a linkage transmission
- IDRC in April at Fontana
- Merging dump into 4" DP
- Cusco (clutch style) LSD fluid
- MICHIGAN US131 INAUGURAL IMPORT VS DOMESTIC SHOWDOWN April 26-27
- clearances for high hp e85
- need help with 15" rim choice for 5th gen prelude
- Please Help B16 Turbo Motor Noise
- High compression boost build
- Events near central pa
- Ennis IFO, March 2nd!!! Who's going??
- sohctodohc's h22 i hope i can get into a class build
- Sparco Seats
- Meth Injection
- Degree in Web Pro Vtec killer Cams
- Drag racing civic stock suspension, Anyone ever done it?
- S300 not logging gears correctly.
- Car not running in a straight line
- Press Release: TGR Teams up with Drag Cartel and ERL for 2014!
- Ososik/The F.O.A.T: IFO Bakersfield Official Video
- What trans fluid to run in b series liberty face plate gears
- Trans temp on a manul trans?
- IFO Bakersfield 02/16/14
- 13 or 15inch wheels for radials
- Prothane/Energy Suspension manual steering rack bushing questions.
- Harness issue
- IDRC 2014 schedule AWESOMENESS!!!
- How much oil in the catch can
- Bakersfield Import Face off - Drag Clip
- 2013 Fastest Non-vtec N/A Race car ???
- Installing Big Cams, Roller Followers
- OsoLatest: IFO Bakersfield
- 3/2 IFO Ennis (Who is going?)
- Should I need to open my Front bumper?
- Build needs help
- No Power
- Kelford Cam Opinions
- SLicked Down 1st Time Ever!! Tonight
- 2014 Drag Racing Schedules Look Strong
- What is the "Offical" fastest Nitrous honda record? B/K/H?
- bakersfiel IFO 2/16
- Trying to get into legal drag racing
- IFO Bakersfield 2/16/2014 ROLL CALL
- SCW OsoLatest: Week before IFO
- Using a intercooler core as a radiator??
- Finally ran my first 9 second passes
- Switch panels
- NHRA Possibly bringing back Sport Compact?
- IFO baytiwn feb 9th Roll call
- 2014 Haltech WCF Purse raised to $60,000!!!
- Build thread for my Drag 1993 EG hatch
- street/strip 2.0 62mm east coast build
- Who runs a 245/45/16 street tire?
- Kenny's Little 61mm street car resurrection from the rice.
- Talk of North vs South brewing
- 2014 SFWD Turbo EG rebuild Scott Oates\Zero 4 Racing
- Who's Going To Baytown IFO
- 62mm Turdbox Sedan 10.1@152
- It's Monday again...OsoLatest - Ososik
- Fastest turbo Street Hondas with A/C
- fuel cell venting
- Where to buy Lenso drag wheels??
- Mission critycal or 4piston GSR head??
- Ls/vtec turbo
- Feb WTB Thread
- Feb FS Thread
- DIY Aero Mods for High-Speed Runs?
- ATI Race damper dilemma
- Slicks size
- Precision gen2 cea wheel
- Reviews on Evans tuning
- The Full Mile?
- Valve Seal to Retainer Clearance
- Transmission fluid questions.
- High HP cars: What Radiator/fan/shroud combo are you guys using?
- Ososik's Sport Compact Weekly-Mon. OsoLatest
- brms drag series $3k to win
- Press Release: Tial Sport Title sponsor of the Prayoonto/Shanghai Civic
- Press Release: JE Pistons joins CLM Motorsports SFWD program
- TGR 2014 Press Release
- Press Release: South Bay Fuel Injectors part of 2014 race season!
- Dropping weight
- Intake Cam twist posible?
- anyone have a liberty bell housing for sale
- Franks custom fiberglass
- KING Alex Russian Bullet Honda S2K runs 8's
- EvilTwin's 2014 62mm build
- Pro Fwd Nissan Juke from Sweden
- Performance from Jdm Type R with 82mm pistons
- New K2H Crank for H-series
- IFO AMS CLASS QUESTION
- My 93' 67mm Hatch Street/Drag Build Thread, Lots of Pics!
- Help identify LSD...
- All motor
- Want a 3 piece fiberglass front end for a Del Sol? Info inside
- 1990 CRX fiberglass front end
- Injectors, ID or SFI
- MSD Rotor - Pro's or Cons?
- Opinions and Feedback on Kens Kustom Chassis cages
- Suspension Bushing questions
- Fastest stock sleeve b16?
- Good chassis shop near central pa
- Charge Inlet Temps with closed front ends
- E98 LS/Vtec nitrous integra
- Press Release: Hasport Performance teams up with Prayoonto Racing
- Question about tires
- Hary’s 62mm FIS-class H2b by KAIZENSPEED
- A/F sensor placement in uppipe
- Question for "future proof setup"
- Questions on slicks
- NDIMA AT PBIR
- 91 integra rwd
- IMPORT FACE-OFF: Reading, PA - 4/6/14
- M&H Racemaster
- Recap of 2013 of "My quest to run 8's" by E-Racer Productions
- PLM TOP MOUNT B SERIES MANIFOLD
- Should there be a Outlaw Class Class 2014 ?
- drag suspension.
- Help identifying axles
- Jan 2014 DSport Magazine Feature
- A good DVD to buy?
- Jan WTB Thread
- Jan FS Thread
- Happy New Year too all !!!!!!!!!
- End of Year Ososik Video - WCF!
- Staging Brake install (In-Line) Questions
- Preferred rear spring rate
- HELP for SWAP
- b20 vtec advice
- Aluminium Rods Clearances
- New Pro-Jay K-Series Intake Manifold
- Removed my P/Steering, drain it or loop?
- 11.31 @ 118 Non Vtec All motor
- Few quick suspension tips needed
- rsx wiring help
- Any changes to the 2014 season All Motor class?
- Redline mtl myth..good or bad for carbon synchros?
- Supports bar for Roof spoiler?
- AEM 4-Channel Wideband Air/Fuel UEGO Controller
- *Video* My year recap RLZ/COSMO Civic
- Tim Grey Racing " A Lifestyle We Live "
- 12 second daily?
- OKC FarmTruck Call Out
- 2014 IREV and WCF Dates
- Would you run this ported GSR head?
- TX2K14, Anyone going? Ima get smoked in the roll race event lol
- Low oil pressure and possible main bearing wear
- Ever seen this? Chipped/detoriorating sleeve/deck
- Anyone have complications with e85 and journal bearing turbos?
- 2014 Import Face-Off schedule...
- Help choosing my Dogbox gear ratio
- Pic Request, FF turbo, Wide Front End
- Need tire help
- D3 Performance Engineering New PB 8.35@169 IFO
- IPGparts.com Stock Long Block K20A2 CRX Goes 11.304 @ 119.19
- how do you set up for different fuel
- PRI Indianapolis December 12-14
- Your Max RPM and Dyno sheet
- Will Race-pak, or AIM Strada interface with Neptune?
- Pro-Jay Adjustable ITBS...
- DC5 0 to 60 in 4.5 seconds 1/4 Mile in 12s
- tuning with front scoop
- Dec WTB Thread
- Dec FS Thread
- BC performance AWD eg vids.
- Optimizing boost by gear in s300
- AEM EMS-4 reviews on big power setups?
- EG LS/VTEC 1/4 time
- got bored and made my own intake(again)!!!
- 8.84@164 SFWD S300 MIR WCF
- Question about the altitude time correction
- little fun on the street
- Drag alignment settings: slick psi?
- Why do we run BOVs and burnout in the wrong area?
- JASE front ends
- lets see some nitrous 12-11 sec setups
- anyone ever hit 9s with a 6262?
- MFactory 3.07 Long First Gear. anyone running it?
- Fontana autoclub speed way to re-open????
- Import Face Off (LAS VEGAS) 11/24/2013
- Analyze my slip: first time in the 10's.
- LowBudgetTuning all motor k
- akward set up
- Problem with GAS warming?
- what could do this to the valve?
- AWD del sol
- FWD, a new bracket drag challenge for me.
- Hondata SFWD Eg & K-Power at IFO
- S2000 vs Camaro Grudge Match at MIR
- My new PB at wcf 9.15@163 truestreet!
- B16a3 Turbo Build
- lucas oil racing only 0w30
- Need input! S366 billet wheel
- Fuel Injector Clinic sponsored Prayoonto Racing Integra wins at WCF, congrats!
- WCF Video Coverage by ERacer
- Jo Tech Performance SFWD/Super Street Integra runs 8.60@174 tuned by Real Street Perf
- World Cup Finals 2013 - Audio visualization Teaser - Ososik Media
- turbo gsr fully cut off
- Input on street tires for 500 hp civic
- Battle Box Films Coverage of WCF 2013
- safety regulations?
- DT Racing Division Truestreet integra 67mm @ WCF 9.05, 9.02
- GP1 Racing/Rstech all motor car finally goes 9's
- Speed Factory Racing / Comp Clutch World Record 7.91 @ 196mph *Video*
- Turbo-Manifold studs won't stay tight
- Aeromotive FPR, push lock fitting for vacuum reference help......
- More 2013 WCF footage
- Rstech/TGR F2K- New All Motor Record - 9.74 @ 138.8
- TUNING MY 92 CIVIC HATCH INTO A DRAG CAR
- help wiring my 4 pole battery disconnect switch
- Complete 2013 WCF Race Results with 471 Racers!!!
- 8.57@160 worlds fastest & quickest 3/S in the world
- New Personal Best - 8.88@167 SFWD Civic - Dynamic Performance
- World Cup Finals 2013 Coverage from The Sauce Spot
- Changes to WCF in 2014
- MIR/WCF Jake Gavio
- NOV WTB thread
- Nov FS thread
- Finally got to the track with my drag radials :(
- Thank you to everyone that came to WCF!
- Need to know best place to get s372 repaired!
- Another New member to the 9 sec All motor club
- SEMA 2013 Las Vegas
- K Swapped EG Hatch (10 Sec Pass) vs Audi S4 PBIR Moroso
- U.K. FWD Drag Series Final Round 2013
- Fuel Injector Clinic returning to sponsor World Cup Finals this weekend at MIR!
- lil guy sfwd build
- New member to the 9 sec All Motor
- K-Power vs LoCash IFO AZ Oct2013
- Official Results: 18th annual Haltech World Cup Finals "Import vs Domestic" at MIR
- Switzer GTR testing 1/4 mile
- Sport Compact Shootout November 16th
- IFO Dallas roll call
- E85 fuel cell question...
- WCF Import vs Domestic @ MIR on November 1-3, 2013
- roll cage rules
- lsvtec build
- WCN DVD Preview
- 3 piece end .
- Edlova Fulltime-fabrication/Hiboost new pb 9.20 & 9.29
- S300 V2 extra input datalogging issues
- Who is taking home the WCF Silver Cups?
- MIR WCF coverage inquiry
- D3 Performance Engineering @ FL2K13 Street Car Shootout + More
- Hotels filling up FAST for WCF!!!
- FTW PURPLE.....
