InlinePro T4 manifold
Re: InlinePro T4 manifold
Maybe as far as the turbo is concerned. Not as much the manifold. Turbo cams don't have as much duration, so overlap is reduced. You don't need or want as much overlap as you would want in an all motor car. The issue is when making big power, if the turbo exhaust is too small it could cause too much back pressure and overlap wouldn't be good. Thoughts?
This is what I'm talking about. I guess I wasn't specific to what I was asking.. I've should of said .. Has anybody used other cams bigger than Type R/CTR and not had any back pressure issues with the said manifold above ?? I know with the smaller InlinePro manifold, the A/C T3 version. You can't use anything bigger than GSR cams or it will cause back pressure issues.
