View Full Version : Drag Racing
- Took the b16 EG to the track for the first time
- Ignition Question
- Is 15.6 with I/H/E on my si?
- car hopping at launch??
- JG edelbrock
- NHRA adds Sony
- Question for those with extended wheel studs
- 95 gsr (boosted)
- Putting on extended studs- having problems with stripped screws.
- 12 Second 2k Civic Si
- went to the track not so happy
- Direction to go.. have sleeved h22
- Gearing...
- Cam Timming
- RPM FALLS back at 5500 rpm???
- 99 Integra GS vs 91 Camaro RS
- Here is a pic of the Autronic SM2 and CDI from Strader Performance
- Rear motor mount hitting cross member
- Having Wheel Hop Problems need advice...
- msd digi. 6 users where did you hook up the 2 step wire at?
- 92hatch Gsr NOS
- Crx roll cage: Dallas area. Where to get one?
- How can I get my B18 EG into the 13's
- B16 Stroker
- Engine Management?
- Saturday Racing sound/muffler rule. Anyone had a problem?
- what psi do I run slicks at?
- first time with boost (track times inside)
- What are your times on 1/4 with Del Sol B16 engine?
- Suggestion: ALL-MOTOR forum?
- n/a vs f/i??
- Should I worry about breaking anything on slicks?
- I'm Pissed Now,Allmotor92Civic where is my stuff at???
- Do smaller tires affect your mph?
- 12 second traction problem from street tires... how to solve?
- what slicks should i get?
- Welded diff.
- 20x8x14" slicks good for my setup?
- track times 03accord
- Pics of my new 6pt Cage.........LOTS of pics
- My times
- tuning meth vs. race gas
- do you get higher trap speed with slicks compare with street tyres ??
- You think this street car can handle some track cars.
- pic's request...what kind of drag rims are you using
- Best Stand Alone For ITB's
- Dyno Graph of an ITR with Stock Cams and Pistons
- Christmas Tree Rules
- New Track Times
- Post your D16A6 1/4 mile times!!!!!!!!!
- STR signs Laskeys
- New JUN III Cams + Stock ECU = ?
- This sucks!!
- b18b eg coupe vs. rsx type s
- Anyone drag with victoracers?
- IDRC Champ money
- Best Value Head Work
- Smaller tires and effect on final gearing
- how do i know what size slicks to get?
- integra or civic spring?
- Axle saving launch
- post up what vehicle you guys use to tow the race car to the track
- 22x8x13 slicks question
- 2nd gear burnout advice
- 8.90@163 mph - 6 Speed Supra, stock independent rear suspension (video)
- 13.6 in a turbo 1.5L vtec stock tires
- Possible Times
- launch help...
- Wheel backspacing
- Whats the best slick size for a.....
- Import Shootout 27th of April
- Minimum weight for na cars in nhra street fwd?
- New shop opening in SOCAL... Max's Engineering
- GOOD RUN today
- driving a sohc turbo
- 1/8 mile to 1/4 mile time conversion?
- our all motor ,daily driver was runner up in t4 class at ndra this past weekend in dallas
- Weld Draglites, two thumbs up!
- NOS install?
- Drag strip locations in Texas?
- Rear Wheelie Bars and Soft Suspension?
- y1 Tranny lsd's What fits?
- Big Block EP - K24 Frankenstein (Dyno results and pics)
- 60 ft times with/without wheeile bars
- draggin in tennesse
- Damn, 10.25 in NHRA All Motor is hard as hell to challenge for a FWD ....
- Size of slicks
- Vtec Controller?
- The Fast & The Furious... Amish
- ** how to tell if someone has LSD? **
- weight reduction
- great drag video
- another et ?
- Pacific Performance Has entered the Board
- ouch big blow for idrc
- Good place for Head in MD
- NDRA Nopi Dallas Texas STR Team
- Speed Machine
- who should install my cams??
- d16y7 mini me turbo.
- does anyone have a footage of kenny tran's new car running?
- act clutch
- what size slicks on an HX wheels on EK hatch?
- Got slicks now.... what wheels to mount?
- my times in bendover UT, oops i mean wendover
- what size slick should i use for 300-400whp
- wut do u guys think about R&D dyno service
- VW vs. all other imports May 4
- 1/8th mile times in my B18C1 I/H/E CX hybrid
- your setup and horsepower numbers? time to brag people :)
- San Antonio event: Poor attendance, new best time 4me
- Need help!!! info on Crower IBEAM rod STRETCH LIMITS!!!!
- Burn-Out etiquette
- Odd Question: N/A or F/I better for gas mileage?
- My thoughts on the Dallas NOPI Event
- Where to buy stock look Fiberglass hood for a Civic?
- Big Thanks to the STR gang.
- rear skinnies? What size do you recommend?
- Need some advice on a project..(maybe)
- Need advice on a drag wheel
- Used Slicks??
- 28 inch slicks/ final drive????
- URGENT need to see about purchasing fiberglass front end IN FLORIDA
- 12 sec. sohc non vtec
- what options on broken bell housing?
- 12's possible with this setup????
- suspension question
- new best time
- street car or track car? need some opinions
- Traction control arms?
- JDM ITR vs. JDM CTR pistons...whats the difference?
- need some suggestions
- My slow B16 times!
- 11.59@118 on all stock ls head and block
- Where is good place to order roll cage?
- ADVAN full slicks...
- tech problem!help!!!!!
- what are you ex motor people runnin'?
- Hot-Rod class: Who lifts for shifts?
- Next california speedway or california raceway 1/4?
- got my z10 traction system today
- good for a high 12 sec pass?
- Who has the fastest cars East vs. West
- Comparing Drag Slip Times ... Take a look ... interesting stuff ?
- moroso oil pan
- Slick's went flat
- double clutch vs. granny bangin
- need help with sespention!!!!!!!!
- Our Shops All Motor Car 1st pass!
- What is the best performing header out there?
- I have a fully built NA b16 but how much power?
- tunning with race gas ???????
- Import Scene these days?
- Who is quickest on street tires?
- Hondata
- ZEX Dry nos system
- What is street legal?
- 2nd night at track times new best time for me and my buddies car
- Weds. track times. finally got into the 14's!
- crx track times
- header-tech header
- My timeslips from Weds night at Sac raceway 4/9/03
- how much money to run 12's
- 12's at least?
- Need help on my fuel management!
- 16" drag slick?
- My Sohc timeslip
- What's the best tire to use for street/strip?
- what size slicks on an EG hatch?
- greddy times inside.. 99ls
- new 1/8th mile track coming to San Diego
- Does any company make 22*8*14 slicks??
- Can I hit 12's with some improvement
- To the DA's, attn: bottlefedintegra
- WAHOO....DR's coming to Australia!!
- one piece front ends on east coast??
- Trany ?'s need help and opinions
- possibilities of low numbers? and question on slicks?
- how much power do you have and what size slicks do you use?
- Bisi..This ones for you!
- Best turbo kit for a 2000 SI
- My Header Tech Numbers
- Stupid ricer question
- Coupes weight??
- Who's using methanol in all motor this year?
- Optimum Slick size??
- Lightest Weight Possible for EK
- 11's in a full weight, stock motor Integra?
- What axles are everyone running???
- my new set up (11's allmotor daily driver)
- Who has the fastest NA street honda? ?
- Unleash the furry!!!! hehe
- erick aguilar runs 10.00 @ around 133........anybody got any info????
- sunday
- Florida events in May...?
- Sohc for strip
- 13.1 @111.78 On street tires
- M/T vs. Goodyear Slicks
- Making your own Lexan Windows??
- H22 timeslip... how can I improve?
- 12.6 gsr hatch
- Fiberglass body panels? where to buy??
- rear bumper diffusers or holes cutout on rear bumpers??
- what is the potential of this g2 integra
- wtf ??????????ericsracing(green monster)
- CMI - SAC RACES ( Race Information For Sunday April 6, 2003 !!)
- Drag Slick sizing (already searched)
- Accel DFI GEN 6 Please help out!
- some times
- englishtown survival series results 4/6/03
- 22x8x15 mt slick for sale.
- 22x8x13,should i worry about breaking axles?
- How old are some of you drag racers?
- Here is what im trying to do with my car....
- Jimfab Bars
- New times on Friday
- From Bisimoto (I hope I'm allowed)
- nhra florida event....
- Removable Steering Wheels..
- Ok ran the car last night im guessing needs tuning bad
- Header Tech header....12.7 All motor Integra
- CMI See you there, what you planning to pull and what car?
- VHT Trackbite..u guys use this stuff?
- PIR tonight....Lets see some honda's out there ;)
- Honda Slicks
- Thoughts on Yokohama A032r's for the track..
- Pulleys...
- Anybody wanna show pics of there new set ups for the year?
- What kinda 60's u guys cuttin on 555R's?
- Cold SparkPlug For Race Motor
- 13" Drag Slicks. ( question )
- scattershield required 11.99 or quicker
- Looking for any gossip on these new drivers...
- Question about burnout box????
- What better guys...Drag turbo or Fmax turbo....hard to pick...
- new clutch help et?
- re: Racer X Sponsorship
- Roll Cage
- Speedpro/fast engine manegment data logging
- ran my almost stock 95 gsr at sacramento raceway yesterday
- 1/4 mile time ?'s
- 100shot NOS heads
- Motec m800 windows based software
- J/C- What does everyone think about E. Bergenholtz?
- damn crazy motor
- Gary's new setup
- anyone know who Jason Perez is, in SoCal?
- sponsorship proposal??
- I've got a fun one, Let's see your Truck/Trailer.....
- Lexan from MB Products
