Building a custom wiring harness
Hello I am building a custom wiring harness for my fully gutted no dash 1991 civic. I am trying to make a simplified harness along with a fuse box. I am planning on keeping the main relay. The car right now has a b20 and running a obd 1 p72. What wiring diagram for what car should I try and base this off of? Ive seen different pin outs for some things like the number 4 injector. https://www.autozone.com/repairinfo/...00c15280061b0f On this diagram it says that is a14 http://www.phearable.net/information...-pin-outs.html on this pinout it says that its pin A2. Do they both work?
Re: Building a custom wiring harness
But how does it make sense to try to base it off a obd0 dpfi harness when I am building it for obd1? Have to go thro twice the amount of work trying to figure out the obd 0 - obd 1 conversions. Also what do you suggest other then building a higherqaulity main relay using generic automotive relays. I want to keep the 3 second fuel injection prime and also keep it so when the car is not running its not pumping fuel, I thought about a main relay delete but decided it would not be safe if I was trying to mass produce my harnesses. Anyone delete the brake switch?
technicly I should be able to take a full chassis and engine harness off a 92-95 civic and have it be a direct plug and play into a mpfi d or b series1990 civic minus potentially some switches and the gauge cluster.
Anyone know what gauge to make the distributor wiring out of? I know like 3 of the wires have to be sheilded and ground, im not sure what wire to buy.
I did pretty much what you're wanting to do. 88 DP engine harness with a 90 MP chassis harness, all converted to OBD-I except I deleted the main relay and dash fuse box.
With the age of EF harnesses and the low cost to buy new harnesses, for what you're wanting to do I would just press the easy button and get a Rywire harness. You're going to spend less in the long run and won't have any trouble shooting to do after install.
lol 2500 dollars for a full custom harness on my 400 dollar car f that. I already have half of it built. just gotta run dizzy wiring.
Hey so ive been working on the dizzy wiring, I bought some sheilded wire to use. I read somewhere that you have to ground the sheild to the ecu maybe the logic ground? then it has to jump to another ground on the ecu and not just to a chassis ground, Can anybody confirm where to ground the shielded dizzy wiring?
komet 163
09-27-2016 04:50 PM
