Transmission & Drivetrain Gearboxes, Differentials, Clutches
transmission problem
Old Apr 13, 2009 | 01:58 PM
curtiss_robinson's Avatar
Default transmission problem
I have two motors at home a d15b7 and d16z6. the z6 transmission case had a hole in it so i decided to swap the gears from the z6 to the b7 transmission. Test drove the car and it drive fines on accelerating however when i decelerate the gears will grind. Anyone that works on transmissions know the cause of this? I need help asap...this is my daily.
Old Apr 13, 2009 | 03:06 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: transmission problem
Gears won't "grind" on decel...
How did the bearings look?
Old Apr 13, 2009 | 03:58 PM
the bearing looked cool. the way that i can explain the noise is that lets say your motor is on in nuetral. Then you try to push the shift **** into gear if you push hard enough it will grind. Well this is the noise it makes when the car yanks, which it always yanks a little on deceleration. so Im think maybe the gears a mis-alllinged or maybe i messed up something with the shift linkage but then again every gear goes in smoothly.
Old Apr 13, 2009 | 05:08 PM
Mista Bone's Avatar
D Tranny Guru
failure to properly shim?
Old Apr 13, 2009 | 07:04 PM
well i do not know what that is, so i probably did not do that. I have no problem pulling the tranny off and fixing it. What do i do? or what is that? how positive are you that is the problem?
Old Apr 13, 2009 | 07:43 PM
Evs-One's Avatar
Solbros Owns Me
pick up a HELMS, tear it down, CLEAN everything, and start over. Thats the best we can say for you.
graftuner34
Feb 28, 2007 12:56 PM
flatblk
Aug 15, 2005 02:57 PM
