Transmission & Drivetrain Gearboxes, Differentials, Clutches
wont shift
Old Apr 7, 2009 | 12:38 PM
mmmbrapND's Avatar
Default wont shift
My tranny just broke on the way home, and the linkage is still good, but I have never worked on a linkage tranny. But my opinion is somehow the shift fork let loose... It has the shift pattern, but everything is REALLY easy... and it wont "catch" a gear.
Anyone ever had this happen to them? What was the problem?
Old Apr 7, 2009 | 01:25 PM
mmmbrapND's Avatar
Default Re: wont shift
anyone?
Old Apr 7, 2009 | 06:14 PM
Mista Bone's Avatar
D Tranny Guru
broken parts inside the tranny.
Find a spare and install it, then you get to learn how to split open a tranny.
Supply pics, they are a great help for others and me to walk you thru it.
Old Apr 7, 2009 | 06:18 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
when i've dealt with this before, one of the tabs on the selector mechanism that links to the shift rod broke. did you actually inspect all linkage connections, shifter, and associated hardware to make sure nothing came loose?
how were you driving/shifting when this happened?
Lokisdope
Apr 1, 2008 11:29 AM
preludedriva
16
Aug 8, 2007 03:48 PM
