EG aouto to manual HELP.
Are there wires that are under the center console that were part of the auto trans that need to be removed..car has nor power to the starter now i start it by jumping the starter.help.....
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: EG aouto to manual HELP.
^ yes do that. you need to wire the 'park' position so you can start it. you can use 'neutral' wires also. and while your in there, wire the reverse lights. it's the two wires in the bottom middle under the two fat top middle park wires...the reverse light wires are small yellow and green i think...run these to the reverse sensor.
MyWhiteEJ6
09-29-2013 12:02 PM
jeunefred
06-13-2008 08:14 PM
x still jaded x
07-04-2005 10:49 PM
RuthlessEF-9
03-29-2003 09:43 PM
