Transmission & Drivetrain Gearboxes, Differentials, Clutches
Binding gears?
Old Apr 12, 2009 | 08:52 PM
Hanmin's Avatar
Default Binding gears?
Stock ls tran, did a first gear pull, and then it grinded going into second. Right after that when I put the transmission in and out of first, it has a really sticky feeling, hard in hard out. After I let it sit and drive it it goes back to normal.
Any idea what the problem is, oh yeah really bad grind to third, every single time... over 2.5k and whenever i downshift.
Old Apr 12, 2009 | 10:40 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Binding gears?
how old is the stock clutch?
Old Apr 13, 2009 | 08:30 AM
Hanmin's Avatar
idk, pretty old, but not worn out. Still has life left=].
Old Apr 13, 2009 | 10:55 AM
Mista Bone's Avatar
D Tranny Guru
just because the clutch "has life left" doesn't mean the problematic springs haven't come loose.
Old Apr 13, 2009 | 12:15 PM
Decatur Racer's Avatar
could bad springs cause vibration while letting the clutch out l
Old Apr 13, 2009 | 05:20 PM
Mista Bone's Avatar
D Tranny Guru
yep!
Old Apr 13, 2009 | 05:28 PM
like it just started doing it all of a sudden rough going in and outta gear.. It makes the whole car shake like a bad motor mount or something
Old Apr 13, 2009 | 11:10 PM
Hanmin's Avatar
Tranny was leaking oil, I guess you can figure out the rest... Bad seal where the axle goes in.
sxm5369
Sep 14, 2007 10:05 AM
jakedoza
35
Sep 22, 2005 09:08 PM
dan89crxsi
35
Oct 25, 2004 03:17 PM
B-B-K
Jul 27, 2004 10:47 PM
3rdGteg
Mar 14, 2002 08:14 PM
