How engine-specific are B-series clutches?
I have a b16a I need a new full clutch kit for, and I found a couple kits I liked, but they were all for b16a2s, or b16s from the 94-97 integras, or 93-95 del sols.
I know honda is pretty specific with certain parts, and i've heard they change the spline styles all the time. Do i need to find a clutch kit for specifically the 92-95 b16a, or will any work.
(If it changes anything, I'm getting all new clutch, plate, and flywheel)
Re: How engine-specific are B-series clutches?
Do you have a hydraulic tranny? Or cable?
If you have hydraulic trans, you can use almost every clutch from a B-series.
My 97 b16a2 have exactly the same clutch as a Integra R and CR-V (97-01)
Just dont get one for a 90-91 Integra or older gen B16 trans. They are small spline and will not work with your set up.
The only time the spline count was changed was in 92 which has the same splines as all of the hydro b series made until the k series came.
91 and older uses small spline
92 and up use bigger spline
You really don't have to order specifically for your car
yep...you can even use 92-93 integra clutch kit except the throwout bearing has to be changed. I'm actually using a pressure plate from 94 GSR on my 90 integra and just bought an OEM replacement clutch disc for a small spline.
FutureCivic
01-21-2007 08:02 AM
