Transmission & Drivetrain Gearboxes, Differentials, Clutches
Which trans is better?
Old May 9, 2009 | 02:16 AM
Elite2000's Avatar
Default Which trans is better?
Is b.16 trans better than a GSR, or vice versa? Is hydro trans better than cable?
Also is it possible to convert a cable trans into a hydro trans?
Because I bought ah LS motor and the guy I bought it from said it's a Ls cable trans contverted to a hydro trans? Confused?
Old May 10, 2009 | 03:25 PM
Elite2000's Avatar
Default Re: Which trans is better?
Bumpppppppp
Old May 10, 2009 | 10:01 PM
oneoffaccord's Avatar
gsr is better than a b16 tranny. gearing is way better, almost close to JDM ITR. hydro trannies are easier to come by and have less miles than cable. you can convert a hydro to a cable by getting a hydro-to-cable kit from lets say hasport.
Old May 10, 2009 | 10:11 PM
MFactory's Avatar
Which tranny is better depends on your application. For general purpose though, the B16 is the better of the two.
JDM '96 ITR Tranny (i.e USDM ITR) = B16 1/2/3/4/5/FD
JDM '98 ITR Tranny = B16 1/2/3, GSR 4/5, 4.785 FD
Old May 11, 2009 | 03:53 AM
Elite2000's Avatar
Thanks I'm building a LSVtec and I don't want to use a LS cable trans, Im think of picking up a b16 trans because I herd the gearing ratio is better?(corrtect me if I'm worong)
I'm looking for somthing that will give me more on torque with a faster accelration..
Old May 11, 2009 | 04:15 AM
MFactory's Avatar
Yes, the B16 has the shorter gearing which will give you more torque and faster acceleration
Old May 11, 2009 | 08:36 AM
DC206R's Avatar
b16 has shorter gears than the gear. Like everyone else knows GSR trannies have good gearing all around. Its good for N/A builds and Turbo builds. B16 trannies have pretty short gears so it would be ideal for your LS-V build if you dont mind driving in Vtec on the freeway
Old May 11, 2009 | 10:23 AM
Honda Bull's Avatar
I believe you're leaving out a certain final drive out of the equation here.
They are both excellent choices. Depending on what you want, the GSR or B16 may be a better fit to your goals. But they both work incredibly well in various circumstances.
Old May 11, 2009 | 02:57 PM
Elite2000's Avatar
Thanks for all the feed back, but is hydro trans that's beter cable?
PRLSV
Jul 2, 2012 01:52 PM
JPerkMr954
Jan 28, 2011 04:37 PM
scooterbuilteh2
Jan 9, 2010 04:38 PM
B16-CRX
Jul 14, 2008 08:53 PM
