Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help changing the final drive???
Old Apr 30, 2009 | 08:43 AM
psegs80's Avatar
Default Help changing the final drive???
I purchased a 98+ JDM Integra Type R with a Spoon 1.5way LSD.
I have a Complete 2nd gen b16a gears with no cassing (I have the shift forks and all)
I just purchase a MFactory 4.928:1 Final drive for a GSR/B16a/B16B/Type R with 4.40:1
My trany shop is telling me that the gears from my 98+ spec dont fit the new Final Drive from Mfactory???
Help
Old Apr 30, 2009 | 09:15 AM
MFactory's Avatar
Default Re: Help changing the final drive???
If you purchased part no. MF-TRS-02B49A, then no, it will not fit your '98 Spec ITR Tranny. The difference is with the countershaft 1st gear.
We have a specific fitment for the '98 Spec - MF-TRS-02B49B
Old Apr 30, 2009 | 09:44 AM
psegs80's Avatar
Can I put the b16a hydro gears on the shaft that I purchased because they are the right ratios???
I have been told ys but that I needed to take the gear selector for 3rd-4th from the non-type r trany???
Thanks
Old Apr 30, 2009 | 09:51 AM
MFactory's Avatar
You only need to change the countershaft 1st gear.
Old Apr 30, 2009 | 10:38 AM
Aquafina's Avatar
You need to use the B16 1st gear, which you should change the mainshaft as mixing used gear sets isn't good.
That or you can purchase an MFactory 3.07 1st gear for the 98+ JDM fitment.
The forks you have are the same.
d-yup
Feb 10, 2010 10:37 AM
CRVEF8
Sep 7, 2009 12:54 PM
Clerique
Apr 13, 2009 03:54 PM
Crisgo
Jan 31, 2009 08:37 PM
