leaking from shift linkage on gsr tranny
i got a big leak comming from where the shift linkage connects to the tranny,
and the when i let off the gas in gear i can hear the gears running. i filled it up but the leak is to big, so it just pours out in about an hour. what should i do to fix leak and stop this? the labor for a transmission shop is about the same as a new tranny. help?
Re: leaking from shift linkage on gsr tranny
replace the seal on the car, which seal? would i have to drop the tranny to fix this? or is is it a direct fix where the shift linkage connects?
D Tranny Guru
Well, I would think you would replace the seal that was leaking on the transmission and not the valve cover gasket/seal.
D Tranny Guru
Solbros Owns Me
If it is the shift shaft seal, just remove the pin, drop the linkage, remove and install. It may be an axle seal also...either will be done in the car.
Basic hand tools and jack stands you will have both jobs done in an hour or so.
^ as he said, very simple and the tranny can stay in, jack the car up pin point leak and replace appropriate seals. get a helms they are priceless.
1 Post
If its from the selector, you just replace the seal...
If its from the stabilizer, you'll either have to get the hole welded shut or buy a new tranny case.
I'm having the same problem right now I had to order the seal str8 from honda just to be sure I hope eveything goes well cus this leak is getting out of hand :/ good luck man
preludedriva
16
08-08-2007 03:48 PM
2000CivicEK
04-27-2007 08:51 AM
spreng87
10-06-2005 03:26 PM
