Transmission & Drivetrain Gearboxes, Differentials, Clutches
torque steer w/ mfactory diff help!!
Old May 23, 2009 | 04:46 PM
si90rex's Avatar
Default torque steer w/ mfactory diff help!!
car drove fine with b16 and open diff. sent the tranny off to gear speed got mfactory diff. put my new ls vtec in with the tranny i did a self alignment cuz i put new tie rods on. i didnt have a problem really. got it aligned and it rides straight with no load. put it in gear and put ur foot in it and it pulls to the left. it only pulls to the left when throttle is applied. if u let off it corrects its self and goes straight. i have changed:
axles
tires
double checked suspension bolts
i filled the motor mounts solid with liquid urethan
idk what else to do beside the diff. i had this problem with the car before but it was an axle that didnt pop back in the cv joint new axle fixed it. the alignment i got i found my tire went flat later that night so would a low tire throw the alignment off?
thanks for any help.
Old May 23, 2009 | 09:31 PM
locash's Avatar
Default Re: torque steer w/ mfactory diff help!!
Uh, a low tire will cause the car to pull.
Try again with same tire pressure in all 4.
Old May 24, 2009 | 07:20 AM
si90rex's Avatar
i checked all 4 when it started. and a low tire would cuz a pull all the time not just when its under a load. coasting it goes straight.
Old May 24, 2009 | 06:47 PM
lsrcrvtec's Avatar
buy a traction bar
Old May 24, 2009 | 07:25 PM
si90rex's Avatar
Originally Posted by lsrcrvtec
buy a traction bar
theres no reason to buy one. its pulls with any kind of load. fulll or partial throttle.
Old May 25, 2009 | 10:36 AM
Mista Bone's Avatar
D Tranny Guru
Likely your self alignment is at issue or bushings are bound up.
Old May 25, 2009 | 12:42 PM
si90rex's Avatar
o about that, i did the self alignment just to get the car to the alignment shop. it was fine till after the alignment was done but the alignment sheet shows every thing to spec. when i first bought the car i swap the motor had issues with the pullin so i had it aligned. nothin so i got new axles and the problem stopped. it seems like the same problem but i changed axle and nothin helped. both times the car drove fine until i an alignment, then it pulled.
the axles i changed out were old ones i had laying around the shop. so im gonna warranty out the axles and try new ones.
Old May 25, 2009 | 01:12 PM
Evs-One's Avatar
Solbros Owns Me
Alignment would cause a pull at all times, unless you have a severely defective bushing, that is throwing off caster/camber on throttle.
Remember, toe will not cause a pull- it's a tire wearing angle....camber and caster will cause a pull. Toe can cause the car to wander if the specs are that far out of wack, but I doubt that's the case.
Check your brake calipers and sliders, make sure you don't have a sticky one....I haven't seen any issues like this with any helical diff first hand
Old May 25, 2009 | 05:39 PM
si90rex's Avatar
I had the car aligned a year ago and after the axle was replaced it was fine all i did was put new tires on and tie rods and had an alignment done. i just set the toe the best i could to get it to the alignment shop. it pulled to left ever so lightly, after the alignment it was like this. its fine in neutral but in 5th gear the steering wheel turns left about 5deg, 4th more 3rd about 25 and 2nd or 1st at least half. this is acceleratting and deccelerating. brakes are good, no drag.
Old May 27, 2009 | 06:25 PM
si90rex's Avatar
new axle, and changed motor mounts. still pullin GRRRRRRR!!!!
Old May 28, 2009 | 07:52 AM
si90rex's Avatar
i called gearspeed today and asked about the diff. noise it should make or shouldnt make. David suggested a few supension parts i should double and triple check.
Old May 30, 2009 | 07:04 AM
punkrockkiel's Avatar
i dont know what OEM spec's are but vw's vr's like 1/8th in toe out and -1.5 camber and it kills all the torque steer with a diff. and vr's have torque, so its proven
Old May 31, 2009 | 09:01 AM
si90rex's Avatar
the only thing i can think of is the drivers side control arm is either flexing backward or the bushing is bad.
Honda92Prelude
Mar 20, 2013 02:40 PM
pereyragary
Sep 8, 2010 11:31 AM
carcious
16
Apr 28, 2009 02:25 AM
B18c1vicrx
Honda S2000
Sep 30, 2006 02:39 PM
JDMJONES
Apr 8, 2004 07:27 PM
