Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD Install?
Old Apr 18, 2009 | 08:41 AM
SpoonCivicSir20's Avatar
No Sales Forums
Default LSD Install?
Been looking for some descriptive write up's on the install since im about to purchase one hopefully today, but havent had much luck except for a few pictures. If anyone has any good info or knows of a good write up let me know. Also can it be installed without pulling the whole tranny?
thanx
Old Apr 18, 2009 | 08:43 AM
No Sales Forums
Default Re: LSD Install?
Just found this write up on an older type r, can i relate even tho there different trannies? same perspective?
http://hybrid.honda-perf.org/tech/lsd/index.html
Old Apr 18, 2009 | 10:32 AM
Aquafina's Avatar
You can use that write up. No need for threadlock though.
You have to pull the trans.
Old Apr 20, 2009 | 10:31 AM
Hobkins's Avatar
https://honda-tech.com/forums/transmission-drivetrain-127/difficulty-level-installing-lsd-2536448/
And then at the very end of my thread there someone posted a very helpful video. I just installed my obx lsd friday night... Eassssy. Remember this video is for b-series tranny.
http://articles.evans-tuning.com/200...-differential/
Old Apr 20, 2009 | 01:45 PM
Aquafina's Avatar
Ugh. I wish that vid would disappear.
Old Apr 20, 2009 | 02:55 PM
No Sales Forums
lol why is that??
Old Apr 20, 2009 | 05:34 PM
No Sales Forums
just got a Kazz last nite with less then 500 miles on it and new bearings, speed sensor and ring gear for 600 shipped!!
Thats a bad *** install, any difference between that and the k series?
Old Apr 20, 2009 | 06:52 PM
Honda Bull's Avatar
The shifter mechanism is external to the transmission on the K, making it a bit easier to close the trans up. Beyond that, K's and B's are pretty similar. They run a lot of the same clearances.
Old Apr 21, 2009 | 01:25 PM
No Sales Forums
dude on k20a.org said id need a press to put the countershaft back in?
Old Apr 21, 2009 | 01:49 PM
Honda Bull's Avatar
You won't be touching the countershaft though, besides setting it aside for you to get to the differential.
Old Apr 21, 2009 | 02:13 PM
No Sales Forums
sweet!! yea im not sure if it was suppose to come like this but the differential is already bolted up to the gear, so i can just swap mine out of this assembly without swapping anything right?
Old Apr 29, 2009 | 10:11 AM
No Sales Forums
ok got the tranny out finally and all the bolts loose from the casing, is the shift assembly suppose to come out first? Not sure if im missing something bc the only bolt i didnt take out yet is a big allen nut which im in the process of getting. Does the assembly have to be out in order to get the casing off? Any help is needed ASAP. Thanx
Old Apr 29, 2009 | 10:20 AM
No Sales Forums
found out i just have to wiggle it ALOT til it comes, and that allen head is 14mm and needs to come out to get to the snap ring. Went over some info i found on here.
Old Apr 30, 2009 | 07:20 PM
No Sales Forums
Some pix of my LSD Swap, let me know if you have any questions. This was a pain in the azz, only bc i did it by myself. LOL
Old Apr 30, 2009 | 07:21 PM
No Sales Forums
everything seems to work fine and go into gear except for 5th gear?? GRRRR good thing i dont use 5th gear, only 2nd and 3rd but still id like to know why??
Old May 1, 2009 | 09:17 AM
migs's Avatar
You assembled the transmission incorrectly.
Old May 1, 2009 | 10:31 AM
No Sales Forums
how so? all gears were in nuetral when i put the shift assembly back together? I kept all the shafts together so they just dropped right in place. Put the reverse gear and rod back on, lined it up for the bolt to go through the outside of the casing. I was told it might be my cables binding up bc previous owner had a similar problem. Not too too worried since i dont use 5th when im racing, only 2nd and 3rd. But incase i ever use the tranny later down the road ill have to look into it more.
Old May 1, 2009 | 03:45 PM
No Sales Forums
Ok false alarm!! I feel kind of dumb but just found out i DO have all gears, the whole time i was pushing the shifter up and over to the right too far. LOL DURHHH
HondaTeKnology
Mar 16, 2008 07:38 PM
h22_crx
Mar 19, 2006 03:09 PM
h22_crx
Jan 11, 2006 09:41 AM
h22_crx
Oct 18, 2005 12:28 PM
krbobcat
Dec 20, 2002 05:16 PM
