Transmission & Drivetrain Gearboxes, Differentials, Clutches
Lightened Flywheel?
Old May 3, 2009 | 07:50 PM
quickspool's Avatar
Default Lightened Flywheel?
I recently aquired what I think is a typer flywheel that has been lightened since it's only 11lbs. Is there any companies that make a cast steel lightened flywheel? I'm also wondering if I should use this flywheel in my GSR turbo setup(full built) or stay with the stock GSR? Would like to get some advise(pros & cons) from anyone who has done this. The tranny has to come out anyways to get a Kaaz lsd installed so I'm wondering if this is a worth while upgrade. I put an 8lber in an old low boost setup I had and the car ran like *** when in boost and cruising at higher speeds. So thats why I'm weary about trying this agian but maybe its different when running higher boost. Any advise is much appreciated.
jaxx4k
Aug 3, 2004 06:52 AM
oneslodx
May 4, 2004 08:36 AM
ApexiChild
Apr 7, 2004 04:30 AM
S-Hall
Mar 23, 2004 06:46 AM
