PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. I'm replacing my fender on my 2007 honda civic ex 2 door coupe
  2. Brake bleeding
  3. location of 2014 honda civic fuel filter in CA model
  4. HELP! Trunk stuck shut 06 si coupe
  5. 08 Civic Si cracked block--need info on K20A versions
  6. 2010 Honda Civic México Seat Belt Warranty
  7. Helpp
  8. Looking to buy Red Line MTF.
  9. Help!!!
  10. 07 civic no start.. mothers car
  11. 2006 Civic SI O2 upstream sensor location
  12. 2006 Civic EX 2dr - A/C gets warm at stoplights
  13. PW:JDM -Power Chamber Intake cause stalling?
  14. Which front end camber kit to buy
  15. 8th gen Civic speedometer removal tutorial
  16. steering lock
  17. Car won’t start
  18. 2012 civic exhaust fit on the sedan model and coupe model the same?
  19. 2013 Si Parking Brake Lever Cover
  20. Broken sensor wire
  21. Crazy Idea: Can you use sedan struts in a coupe for more firmness?
  22. 2008 Honda Civic LX Windshield wipers problem
  23. carpet missing under steering wheel?
  24. Driver side Dome light issue
  25. 06 Honda Civic 1.8 Knock?
  26. Missing V spring clip holes on the Brake Pad
  27. New to car mods - Looking for exhaust suggestions
  28. What's your opinion on Injen SP Series for 2013 Civic Si
  29. 07 SI wont stay running
  30. Crack in engine block, replacing engine question
  31. satellite radio
  32. stiffer motor mounts
  33. Honda Civic Si Shift for Ball and Spring????
  34. TL-s brembo or TSX wilwood calipers
  35. 2013 Honda Civic R16 Engine (TR Version) N/A
  36. Rear left passenger window will not remain closed
  37. Honda Civic 06 Condenser fan and AC clutch wont engage
  38. 2008 Civic A/C Clutch
  39. 08' FA5 issues, are they related? Sunroof, keyless entry, map lights, etc
  40. 06' Hybrid Front Upper Strut Bar
  41. Honda Civic Code 38-11
  42. mudflaps
  43. Where is the fuel pump relay or fuel pump fuse?
  44. new passenger side headlight wont turn on
  45. 2009 CIVIC ABS QUESTION
  46. Dash board assembly
  47. 2014 Civic SI
  48. Lower Control Arms for 14 Civic Ex-L
  49. Help - CVT fluid change, opened check plug first and didn't overflow with 4 bottles
  50. help, 2011 civic intermittently won't start
  51. honda civic 2010 driver side recall takata bags
  52. Subwoofer controls on 2008 Civic Si Sedan
  53. R18A1 Head Bolt Torque Specs
  54. Keyless entry remote not working
  55. 2009 Honda Civic LX - questions before buying
  56. 2013 Honda Civic Hybrid OBD Port
  57. Vibration when car is idling... HELP!
  58. Another help me fix AC with trouble shooting question
  59. Honda Civic clunk from brakes.. Please help.
  60. Coilovers
  61. P0685 ecm/pcm relay
  62. 2006 Honda Civic EX PGM-FI relay location?
  63. 2014 honda civic lx airbag light
  64. 2009 Civic LX SPCA Transmission Rebuild
  65. Civic 2007 Loses power and struggles
  66. Honda civic coupe tires
  67. 2015 civic(non navi)S7 Edge(s5 if needed) to hdmi
  68. Swapping driver's seat in 2010 civic
  69. 2006 si drive train into 2006-11 base model questions
  70. AC Compressor Growl. How likely is it that my system is contaminated?
  71. 9th gen SI CAI shootout by RC Autoworks
  72. ATF filler cap came off. Has this happened to anyone else?
  73. Oil smells like gas?
  74. What low-effort performance upgrades are available for a 2008 Civic Coupe?
  75. 06 civic si immobilizer disable
  76. need help with injector wiring please
  77. AC compressor PAG oil capacity
  78. 2009 Honda Civic LX Window Lock Button
  79. 2009 Honda Civic 1.8L loses heat after awhile.
  80. Car won't start, Starter issue? Bad battery?
  81. Hard to Diagnose Issue! PLEASE HELP!
  82. Dimensions of splash guard clips
  83. Trunk lid sensor location for FA5
  84. How to disable ot replace TPMS brain
  85. Valve cover gasket
  86. Doors Not Unlocking
  87. 2006 honda civic oil leak passanger side
  88. CA Smogged with Hondata Flashpro and Catless header!
  89. Front end stability on LX-S
  90. Transmission problem
  91. 8th generation Civic AC compressor clutch
  92. main audio controls not working
  93. None starter
  94. Honda CIVIC 2007 OBD Communication Issue. Can't read codes
  95. No fuel, No spark, No immobilizer light
  96. 2006 Civic Manual Clutch not releasing
  97. 2007 honda civic eg windshield wipers stopped working
  98. Serial numbers of car and parts
  99. like hissing noise
  100. 2015 Civic oil separator/ catch can
  101. Honda Civic (2006-2016)
  102. 8th Gen Wheel And Tire Thread?
  103. Troubleshooting: 2007 Civic LX - Low beams not operational
  104. Tell Us What You Did To Your FG/FA/FD Today!
  105. alternator small wire goes to power or lamp????
  106. Ball Joints/Brake Pads
  107. 2012-2015 civic (any major issues?
  108. 2006 Civic SI no movement when in gear
  109. Cruise Won't Engage when Head/Parklights On!
  110. Underside Splash Shield Scraping - need advice for fiance
  111. inside weatherstrip and trunk lid light
  112. snow affecting battery?
  113. 2014 Civic - Ball Joints
  114. How to adjust preload on a multi-link rear suspension
  115. 8th and 9th gen CMC thread
  116. 2012 Honda Civic EX trunk wont open
  117. Harmonic Damper Removal
  118. 2010 Civic Front Bumper Stolen
  119. 2011 civic axle seal still leaking
  120. 2010 Civic engine temp gauge has flipped upside down!
  121. Shudder when engaging clutch
  122. Civic FG1 engin swap R18A1 5AT => R18A2 6MT
  123. Electrical Issue 2012 Civic
  124. Need help with my 2014 Honda Civic LX Sedan
  125. must turn steering wheel to crank start 09 civic
  126. Adding a car play unit to 2015 Honda Civic-EX
  127. How does this motor mount look? Need advice on whether or not to replace.
  128. Cleaning the dash board
  129. Is anybody else working on a 8th Gen Civic
  130. will an 04 motor bolt into an 06..
  131. Dirty looking water dripping from drivers-side wheel arch
  132. Throttle/CAI Intake issues?? 2006 civic si
  133. 2006 honda civic hybrid manual
  134. CT supercharger owners?
  135. 2015 Honda Civic LX - detect odometer fraud?
  136. Should I change 170k mileage transmission fluid or not?
  137. No SD card
  138. 2008 Honda civic timing chain
  139. 2008 Honda Civic sedan
  140. 2010 civic theft
  141. ambient temperature control
  142. 2012 Civic need help after presure wash
  143. speedometer and tachometer wires diagram
  144. Stereo, white back lights and HVAC lights...
  145. clutch sensor wiring issues
  146. honda civic 2006 overheating at low speed
  147. 2015 Honda Civic LX - when to change fuel filter?
  148. Holey Cold Air Intake batman!!
  149. 2015 Honda Civic LX - battery replacement w/ OEM or 3rd party part?
  150. Expected longevity of a head gasket repair -2012 Civic w/ 92K miles
  151. 2015 Honda Civic - brighter halogen headlights?
  152. Audio controls not working
  153. Transmission issue???
  154. 2015 Honda Civic LX - Quietest Tires?
  155. brake pedal goes to floor when hard braking
  156. What's a she worth?
  157. FOB does not unlock/lock doors when pressed
  158. 2008 Civic won't start quickly
  159. synthetic oil
  160. 09 Si white smoke from exhaust
  161. 2013 Fuel Pump Quik Disconnect
  162. 2009 honda civic hybrid - harddisk thinking noise
  163. Cruise control won't illuminate
  164. RELAY
  165. 2013 A/C Compressor install
  166. HELP! Civic or HRV for towing PWC
  167. how many K's before you change trans fliud and filter on a 2013 Honda Civic
  168. Backup Cam hookup
  169. Bolt p/n or size please
  170. 2006 Honda Civic 1.8L P2422 fault code [Solved]
  171. Push clips?
  172. Conflicting information about battery power
  173. Dash and AC problems
  174. Loose steering/ play & popping noise on sharp turns!!!
  175. What is this on bottom of R18A fuel rail?
  176. is the engine working too hard?
  177. Do I need to replace my clutch?
  178. car lurching
  179. SRS error codes
  180. Replacing inner/outer tie rods
  181. Metadata for entertainment system
  182. 2010 Honda Civic Lx AC Issues
  183. 2014 Civic EX or 2011 CR-V EX
  184. No Heat 2009 civic LX coup
  185. 2012 Honda Civic Transmission Issues
  186. Honda Civic winter tires 15in
  187. Battery and oil light.
  188. Windshield Wipers - won't shut off
  189. Part selection (brake shoes, struts, and shocks)
  190. Sagging shifter boot
  191. Need some major info please and thank you
  192. Trunk Light - Which Fuse?
  193. Cluster Speedometer RPM Civic 8th 2008
  194. civic 2012 LX battery and alternator problem
  195. Appreciate help: 2008 Civic EX Door Lock issue
  196. Thoughts on this 2008 Civic to purchase?
  197. VSA, ABS, TPM, 2010 Civic hatchback 2.2 diesel
  198. 2006 Civic Si raddle sound
  199. VIN says I have Navi, but not showing up on the main menu
  200. Backlight on Radio screen does not shut off
  201. 2012 Honda Civic LX power steering problem
  202. 2011 Honda Civic Bad A.C. compressor
  203. Skunk2 Springs and Shocks
  204. 2006 Civic Immobilizer PM Request
  205. 2006 Civic Trunk Jammed
  206. Clutch/Transmission noise for 2007 Honda Civic
  207. anyone install Gull Wing door on Civic Si Coupe?
  208. 2013 ex civic terrible gas mileage
  209. HVAC PROBLEM
  210. SRS 3-4 code
  211. Check engine light after PGM FI update !! CIVIC 2006
  212. Back tire wear, wheel positioning and bearing issues - Drive By Post
  213. civic 09 automatic tranny problem
  214. spark plug
  215. Help W/ 09 Civic Hybrid Test Results
  216. Rear power window civic 2015
  217. 2009 Civic Hybrid CAT
  218. acorns on cabin air filter
  219. 06 si 02 simulator
  220. CIVIC 2007 steering wheel turning easily right
  221. 13 Civic EX Grinding Metal Sound - Pulley?
  222. Metal Scraping noise and horn-like noise
  223. Clutch recommendations
  224. Where do these hoses go? (Photos)
  225. 2010 Civic Lx Starter Issues - Trying to Solve
  226. trans cooler
  227. transmission fluid in the radiator
  228. 2010 Civic Windshield Oil from AC?
  229. Civic 07 Beat up from the Florida Heat
  230. 2013 honda civic lx 5speed manual
  231. Something dangling from side view of passenger side
  232. 2012 Honda Civic sunroof won't close
  233. Battery
  234. question on connecting rods
  235. 07 Civic Si clutch
  236. Steering Wheel Shaking
  237. 2013 Civic Window Rubber Gaskets Fail
  238. Caliper dragging after tire rotation. Can't get caliper off!
  239. Chinese Parts?
  240. No AC/Car wont start
  241. Will the Bosch 6714 Platinum properly fit a 2006 Civic LX ?
  242. hoy to find ih the temperature is raising or is normal?
  243. Trying to identify part
  244. climate control
  245. manual transmission
  246. 2006 Civic fender well replacement
  247. SI K24a2 Turbocharge Build
  248. Trunk floor very hot after driving
  249. Pic needed: Heater Hoses on Firewall 06-11 R18
  250. 2006 EX Automatic - Park won't start Car
