clutch sensor wiring issues
hey guys am new here but you guys are the only hope i got i have a 2008 civic ex it was auto change it to manual change the ecu and wiring harness to manual when and bought a harness for the dash from honda they sold me the same dash harness and told me the manual and auto uses the same dash harness now i dont have any clutch sensor wire are clutch interlock wire no reverse light please guys help can you guys walk me through how i can wire this please am begging
Re: clutch sensor wiring issues
There is no clutch sensor, they are switches.
There are two sets of wire harness that have the wiring and connectors.
1. Engine compartment wire harness. The portion of the harness wires that goes into the cabin under the dash has the following connectors:
- 2P Yellow connector that plugs into the Clutch Interlock Switch.
- 3P Gray connector that plugs into the Clutch Pedal Position Switch.
2. Engine wire harness. The 2P Gray connector plugs into the back-up switch (reverse) switch on the manual transmission.
thank you tech 8 you answered what i needed to know honda gave me the instructment harness instead of the engine compartment harness thank you again now i know which one to get i will order it tomorrow honda tech is the world best forum thank you guys again
verbal axesassin
10-04-2005 06:03 AM
