2009 CIVIC ABS QUESTION
I have a 2009 civic that feels like ABS activates under hard braking. No pulls, no codes. I disconnected one sensor to disable system and it went away. Any ideas on how to pinpoint the issue?
Jeff
Jeff
Re: 2009 CIVIC ABS QUESTION
check for any stored codes after plugging it back in and clearing the codes before driving it to get it to replicate the issue....see if a code pops up
if you get one, check the wheel bearing, if it's good, check the connector, if it's dirty, use mass air flow sensor cleaner to clean it, clear the codes, see if it comes back, if it comes back, replace the sensor
Folks on another Honda specific site have said that this is a sensor issue. In the thread it was found out to be a ABS sensor on the rear passenger wheel hub. A code reader would be a benefit, but taking it to a garage will be the best answer.
wildoutwhitegsr
09-02-2016 04:33 PM
Progen
12-27-2013 02:26 AM
