Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
trans cooler
Old 09-02-2017, 01:26 PM
PhoebeK's Avatar
Default trans cooler
i have a 2009 honda civic with a creamy substance in the radiator. Im trying to find out if i order a new radiator (specifically this part number 19010-RNA-A51) does this radiator have a trans cooler? Does the 2009 honda civic even come with a trans cooler? also besides changing the radiator what should i do?
Old 09-02-2017, 01:38 PM
holmesnmanny's Avatar
Default Re: trans cooler
the lines for the tranny attach to the bottom of the radiator to cool it
Old 09-02-2017, 01:42 PM
PhoebeK's Avatar
wouldn't this cause water to go into the transmission??
Old 09-02-2017, 08:21 PM
JRCivic1's Avatar
Do you have an automatic transmission ???
First, the fluids should NOT mix. If they are mixing inside the radiator, then replacing the radiator would in theory fix the problem. It is more likely that you have a head/block/head gasket problem allowing coolant and oil to mix... causing the milky fluid that you are describing.
Old 09-03-2017, 07:08 PM
PhoebeK's Avatar
thank you, yes automatic transmission
Pilot34119
19
07-29-2017 06:53 AM
tundra2000
09-06-2010 05:57 PM
BoostedH23Accord
Transmission & Drivetrain
11-14-2009 08:40 PM
burntkookie
07-25-2009 06:10 PM
tommyt761
10-12-2006 01:00 PM
Quick Reply: trans cooler
