PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. R18A1 Transmission Question
  2. Which are the best cushions and coilover or fullcoilovers for civic SI 08
  3. 2015 Civic Driver Side Brake Lights Not Working
  4. front & rear bumper covers for 2006 civic
  5. Testing AC compressor coil
  6. Crunching sound from right rear only
  7. TITANIUM EXHAUST FOR FG2
  8. Bought a used engine for my 08 civic
  9. FB6 Civic Si rear suspension?
  10. 2012 Civic LX center console USB not responding.
  11. 2008 Honda Civic A/C Clutch Removal
  12. Engine shuts off with Valet Key
  13. Car Idles Rough When AC is on. AC won't turn off.
  14. 06 Civic Turn Signal Relay Location
  15. Transmission
  16. 8th Gen Civic SI front seats air bag removal
  17. TSX Brakes with Mugen GPs, will it clear?
  18. 2006 civic SI key programming
  19. New to the 9th gen
  20. Where is Radiator Fan Switch Sensor on 06 Civic?
  21. 2015 honda civic A/C doesn't work
  22. final drive question
  23. Cylinder head replacement issue
  24. Throttle Body Actuator Pinout Description Help
  25. 07 Civic A/C doesn't work anymore
  26. D light blinking, BRAKE light and ABS light is on (both) CIVIC LX 2010
  27. Flashing parking light?
  28. Flashing driver's front parking light?
  29. Electrical system charging issues
  30. Automatic Skipping Gears
  31. FA5 Tire Recommendation
  32. 2006 civic lags when slamming gas pedal down?
  33. Hi, rocking seat csx 2008 (honda civic 2006-11)
  34. transmisson
  35. 06 Civic AC not working properly
  36. need a new hood for a 2013 honda civic sendan
  37. Paint Chalking / Clouding warranty : advice needed
  38. Rotor advice needed
  39. Throw out bearing making noise
  40. 2011 Honda Civic 1.8 Rattling when A/C kicks in
  41. Advice
  42. Civic upgrade advice needed
  43. Replacing windshield trim
  44. Slow Crank / Fail Start Every 5 Startups or So (Video Inside)
  45. 2006 Civic EX - No Start | Locked ECU
  46. Fd2 headlights for right hand traffic
  47. Honda Civik, 1.8, year 2008
  48. 09 Civic Coupe - Window Issue
  49. What Civic to get?
  50. What are the risks in storing my 2008 civic hybrid?
  51. 09 civic si "Engine Light"
  52. Electrical problems
  53. 2011 FA5 Weatherstripping Issue
  54. 2011 FA5 A/C problem
  55. Help please
  56. 2010 Civic AC
  57. Help?!?
  58. 2008 Civic making strange noise
  59. 06 civic si coupe air bag code 82-12
  60. headlights fd2 type-R
  61. 2006 Honda civic ex 1.8 manual...HELP!!!
  62. Anyone know what this is...greatlu appreciate it
  63. 2007 Honda LX why rear brake lights stay on
  64. 06-11 SI starter bolt size
  65. Transmission
  66. OH HEY everybody, long time no see... *sigh*
  67. My car makes a sound when shifting
  68. How to get 300 hp all motor?
  69. 2006 civic raised a p2647 and p2649
  70. Disconnecting Viper 5902 caused A/C to fail. Why?? How??
  71. i have Enginer light + plus oil light + D4
  72. Skunk2 Ultra Street Intake Manifold
  73. Fuse Diagram legend
  74. 09 Honda civic hybrid ac blower resistor problems
  75. Outrageous AC quote
  76. VSA and Power Steering Light on
  77. Power steering pump mishap
  78. Fried ECU after SCS Mode in HDS?
  79. water pump/timing belt
  80. How to put car in "learn" mode.
  81. keyfob programing
  82. Unable to shift out of park
  83. evap temperature sensor should turn off the compressor when the evap freezes over
  84. Wobbly at 80kms, but smooth after 90, and only on acceleration...
  85. honda civic
  86. 2006 honda civic
  87. 2008 honda civic won't start
  88. OBDII code reader won't communicate with Honda Civic
  89. AC problem in Honda Civic
  90. Clonk / thump noise
  91. 2006 Civic performance enhancenments
  92. Wing mirror
  93. ATF Change with Limited Service History
  94. Honda civic A/C nightmare
  95. My Honda Civic Sedan 2007 says the gas tank is empty even though it is 3/4 full.
  96. Automatic/manual
  97. changing the cabin air filter
  98. stephanie
  99. Excesive fuel consumption 9MPG, civic 07
  100. modifying honda civic si
  101. Sand in the valet key lock by door
  102. fob
  103. where is the keyless control module 2008 Civic Sedan
  104. ECT #2
  105. 2006 Honda Civic 1.8l coolant issues
  106. k20z3 with a k20z4 transmission.
  107. 2009 Civic trunk locked.
  108. 2014 Civic Si Rpm idle up/down
  109. Side mirror repair
  110. Interesting No Start Issue
  111. 2009Civic LX - Replaced alternator , good battery , Battery light ON/OFF HELP!!
  112. Tim LX Civic-07
  113. Squeaking when in gear, disappears when clutch is engaged? (06 Civic EX Coupe)
  114. Possible Civic purchase.
  115. Anyone know who makes 06-11 Civic Sedan Driver Side Airbag
  116. Location
  117. Bolt flange for caliper pins
  118. Emergency Brake light on & beeping
  119. Dead battery
  120. Flashing D4
  121. What other gen wheels will fit.....
  122. Sensor on transmission leaking transmission fluid
  123. What are these wires hanging from the A/C Compressor?
  124. honda civic 2008 passanger door occassionaly wont open from inside
  125. 2014 civic
  126. Bypass Air Conditioning button on the dash?
  127. 2006 tensioner bolt problems
  128. 09 Honda civic running sluggish , not accelerating
  129. Honda Civic VSA
  130. k20z3 with rsx oil pump...stock oil pan....oil capacity?
  131. Engine fail accelerate
  132. Vehicle emissions test after new battery install
  133. Honda Civic 2008 airbag light on
  134. Honda Civic 2007 EX DRL
  135. Looking for torque specs for rear hub assembly.
  136. 2013 Honda Civic EX power window fuse question
  137. Changed plugs. Now vehicle will not start
  138. srs light on, dealer can't diagnose
  139. 2006 civic si - Buzzing in Top left speaker
  140. Accelerating problem
  141. Motor mounts
  142. Car Not Staying On
  143. 2006 Civic/CSX noise during acceleartion
  144. Overheating in Traffic
  145. Engine and transmission mount for Honda Civic Hybrid 2008
  146. honda civic fd3 hibrid swap k20z4(fn2)
  147. K20 & K24 transmission
  148. flashpro bolt on calibration
  149. 2007 Honda Civic EX COUPE - Replacement Front Struts
  150. Replacing front end bushings
  151. Exhaust system cross-year Question
  152. Honda Civic 2014 EX audio upgrade
  153. Considerable Decel Drag
  154. Honda Civic 2015 50-State Vehicle
  155. Smog Civic 2015 EX-L
  156. 2006 civic si coupe fitment help
  157. Civic 2009 central locking not working for very first time in a day
  158. Don't forget to clean your Mass Air Flow sensor
  159. Can't pass smog. Catalyst not ready
  160. Honda Civic LX 1.3L Sedan Transmission Rebuild Kit
  161. Dashboard alarm after crash
  162. After upgrading the intake, ECU need tune?
  163. coolant housing tube replace repair photo
  164. R18 build ability??
  165. Gauge cluster and fan problem
  166. Help! MY 08 CIVIC WONT START AFTER DRIVING FOR AWHILE
  167. Fuel pump/relay issue
  168. Honda Civic Issues after Rain
  169. Piston won't retract-2006 Honda civic
  170. 2012 Honda Civic low speed wobble
  171. 2007 Civic SI: Steering Wheel Light! EPS (electric power steering)
  172. 2007 Civic - No spedo/fuel/temp
  173. 2007 Civic EX Sedan Questions
  174. Fuel and spark no start
  175. Fd2 key fob 2006
  176. Civic si 8th gen Stalls out coming to a stop.PLEASE
  177. Stretched out motor mount
  178. mods suggestions for a newbie please?
  179. 2006 honda civic lx sedan service bulletin 10-048
  180. civic 2013 remove oil pan
  181. civic 2013 remove condenser fan
  182. 2010 Civic Fog Harness help
  183. Part
  184. Seat belt tensioner codes
  185. R18 engine, which is Piston #1?
  186. CEL - limp home mode - no code - D3
  187. starter went bad
  188. 2006 civic ex rim bolts
  189. 2006 Honda Civic Si -EMERGENCY- Won't do anything
  190. 2007 Honda Civic Coupe Ex
  191. key flashing dashboard
  192. Motor Mount for SK2 Alpha Header
  193. 2012 Honda Civic shifting issue
  194. Clicking type noise coming from suspension
  195. ProTubingLab.com
  196. Synchro decisions. 4th gear grinding.
  197. 2006 Honda civic ex tail light problem
  198. what shocks should I go with?
  199. 2012 Honda Civic ABS Pump & Dead Battery. VSA/ABS/Power Steering Lights.
  200. POS HONDA SI
  201. Cooling fans.
  202. 2013 civic si minor customization *please help
  203. 2014 civic si torque mount replacement
  204. 2012 Civic no start issues. Electrical?
  205. Picked up a 2006 EX with AT
  206. 4th grinding
  207. SRS light / curtain issue
  208. What's the RPM at 70 MPH on 6th gear 09 Civic Si?
  209. Clutch broken?
  210. Honda Civic FD1 (1,8 2009) overheating!?
  211. civic 2009 1.8L radiator fans + AC clutch engage for 5 secs every minute
  212. 2013-15 Civic Dash in a 2012
  213. Difference between 2014 civic so coupe and sedan fenders
  214. Idle Problem: '99 Civic EX
  215. 06 si k24a misfire after new head gasket
  216. Brake fluid - Clutch Fluid
  217. No power after replacing altinator 2013 Civic
  218. Did they fix the R18?
  219. 2009 honda civic lx coupe automatic
  220. Civic 2.2 pulls to the left
  221. Proper front parking/turn signal bulbs to use
  222. 07 civic engine block
  223. Stuck Tensioner Bolt on a 06' Civic.
  224. k20 motor swap
  225. k24z7 Future Rebuild
  226. 07 Si EPS issue
  227. Help! Shifter broke off while going into gear (2007 Civic SI)
  228. Honda Civic lx r18 build
  229. 2006 Honda Civic Si - Wheels and Rims Setup
  230. Looking for a 2012 - 2014 civic si
  231. 2006 Honda Civic Si - K20 Swap
  232. SSD Navigation System
  233. Help with timing issue
  234. Clacking Noise at 3-4000 rpm 2011 Si
  235. Sticky Shifter button
  236. Key stuck in ignition - tried several options, still nothing
  237. can you see the hood of your car
  238. Code p0498
  239. Popping/clicking noise coming from front suspension
  240. Civic 8th Gen Genuine Tie Rods doubt
  241. 2010 Civic VP Questions
  242. Does Maintenance Minder on Honda Civic cover all Maintenance?
  243. Advice/Guidance on Purchasing Snow Tires for Honda Civic 2015 SE
  244. Fg2 oil.help
  245. CIVIC 2012 Stalling
  246. Just got an fg2 need some input please!!!!
  247. Service Manual: Coolant flow diagram, etc
  248. PLEASE HELP URGENT!! Transmission problems need solved
  249. How to Remove trunk (boot) hatch inside panel
  250. size and weight between L15 and R18
