stiffer motor mounts
I'm not Rick!
what motor mounts can i put in the SI so i can delete the torq mounts?
theres a few brands. or basically anyone that's got stiffer bushings?
i see one thread where trq mounts wernt needed since he replaced the 3-4 mounts with stiffer aftermarket ones.
Re: stiffer motor mounts
My Si has Innovation mounts on at least two of the mounts. It did away with the upper engine side torque mount. There is also a bit more vibration in the cockpit now that I fixed the mounting bolts.
Dinks did not do it properly and the stud was broke and the bolt had a 1cm gap on the motor mount side.
This was for the 2008 Si.
You can see the result of the engine side motor in the What did you do to your.... thread. I posted pictures of it when my idler pulley decided to quit on me.
https://honda-tech.com/forums/honda-...today-3313514/
D16SohcVtec
08-12-2008 08:03 AM
Bbasso
03-04-2005 05:48 PM
