PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Tricky Misfires, part throttle only, cyl 1,2,3,4
  2. Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear
  3. Front Camber Cam Bolts
  4. Honda civic 1.8 vtec 2007
  5. 2011 civic si bogs when shifting into second
  6. Shaky tire on 2012 Honda Civic plz help
  7. open Stuck hood
  8. 2008 Honda Civic EX P2646 code
  9. Serpentine Belt 2014 1.8L
  10. Starter question
  11. engine and steering shake when reversing
  12. Are all 8G Civic sedan front LCAs the same?
  13. help! 2010 civic coupe versus sedans = bumpers will fit?
  14. 2010 civic coupe - interiors part fittings?
  15. 07 Si want to buy TE37 want to know fitment specs
  16. Need help/opinions please :)
  17. 2012 civic LX - Stereo Questions
  18. TPMS light on and off
  19. Valve Adjustment
  20. Keyless Entry (Proximity) Information
  21. Heat on & Error Code P0128 still
  22. Clutch replacment civic si 07
  23. Keyless entry on one door not working.
  24. Need help with diagnostic please
  25. 2007 honda civic ex 1 inch lift
  26. DRIP SIDE Molding shredded. What is it for and Do I need to replace it
  27. Electrical Question Parasitic Draw Fuse #29
  28. 2013 Civic Ex won't start. No lights (power), battery fine. Halp!
  29. Coolant bypass hose
  30. Grinding/Scraping noise at idle on 07 civic LX
  31. Scarping/Grinding noise at idle
  32. Automatic Transmission Oil Pressure Switch
  33. 2006 honda civic driver footwell soaking wet
  34. 2015 Civic - Transmission Reving up on start?
  35. K24z7 to k24a
  36. Bad immobilizer
  37. Leaking transmission
  38. drove over '15 fob, what best way to replace it?
  39. engine cuts out
  40. 2012 Civic VIN?
  41. 2009 Civic electrical issues- parasitic draw?
  42. Tire Sizes
  43. P0847 Which part # for trans pressure switch sensor
  44. Help!!! Engine connectors?
  45. JIS screwdrivers
  46. Trying to decide what Hondata to get
  47. 2007 Honda Civic Doesn't Start Dash Lights Dim
  48. 2006 Dome Light
  49. 06 Civic Hybrid Transmission not engaging at all
  50. PCV Valve cleaning, throttle body, maintenance
  51. Massive confusion regarding AC condensation drain.
  52. 07 civic throttle issues
  53. 06 Si Type R Seat Airbag light Fix ?
  54. Which ignition coils can I use for my 2010 Honda Civic Hybrid?
  55. Civic Electrical woes.
  56. Simple question (Throttle lag) Help!
  57. How can I use a child seat in the passanger side?
  58. FA5 "Mugen" Spoiler
  59. FA5 "Mugen" Spoiler
  60. FG2 Ball Joint Rubbing after BigBrake
  61. 2012 honda civic coupe 1.8l exhaust set up
  62. HFP muffler legal or not?
  63. Are my winter tire rims unsafe? Pics inside
  64. Window latch
  65. 2012 Honda Civic coupe 1.8l exhaust
  66. Replaced ELD, now won't start!
  67. recommend an compatable obd reader
  68. Honda Civic Vibration at 15oorpm
  69. Replacing gas accumulator on 2008 civic
  70. 2012 Civic Coupe - Suspension Torque Specs
  71. Revs surging
  72. 07 civic(manual) not shifting into gear when cold outside
  73. Lifting a 2006 Honda Civic EX 2-Door
  74. Brake pad advise
  75. 2006 Civic Hybrid vibrates when transitioning from full stop to drive
  76. How to Deactivate Alarm Without Fob or Key
  77. 2011 Civic Center Console Question
  78. 2013 honda civic foglight
  79. Honda Civic FB R16 165 HP
  80. A/C Pressure Sensor Replacement
  81. 2006 Civic AC question
  82. Over Torqued Transmisson Drain Plug, Options?
  83. 2013 civic inertia switch location
  84. Please help me disable the alarm beep!
  85. 2009 Civic SI Mod Request
  86. Brake System Light On
  87. issue with car accelerating while foot on brake
  88. 2007 FA5 Civic SI Budget Build/Restoration
  89. 2015 civic “spiral bevel gear” problem, There comes a sound like a whiste
  90. Front impact sensors
  91. Troubleshooting : Honda 2009 Civic backfires - No modifications
  92. Need help identifying an OEM Part
  93. performance upgrades...
  94. 06 civic LX 1.8L L4 hesitates, intermittently stalls jerks
  95. TPMS Sensor Broke
  96. WOnt start intermittent
  97. 2013 hybrid with IMA light, "check ima system" message
  98. Help...relay signal
  99. Old head here...question regarding CVT's.
  100. Do Honda Civics 2012 have timing belts or chains?
  101. Engine lost power between 20 kms and 30 kms
  102. 2015 Civic Ex-L plug
  103. 2015 Civic Ex-L
  104. A/C compressor and fan cycling issue 2013 Civic
  105. AC Compressor replaced but....
  106. 2008 Civic EX air conditioning help
  107. 2006 LX not starting all the time.
  108. Filler neck replacement
  109. 2009 hybrid conversion
  110. boost
  111. boost
  112. P0420
  113. boost questions!
  114. AC suddenly not working very well
  115. Eibach Pro-Kit higher than stock (?)
  116. 07 Civic EX new rear shocks KYB GR-2 Excel G Stiff ride ??
  117. 07 Civic si CV axle help
  118. 2012 Civic ex Not Wanting to start quickly. Please Help
  119. 2013 civic which to choose +35 or +42 offset gor 18x8?
  120. Civic 2013 transmission
  121. difference between radios
  122. faceplate code location
  123. Use of an ODB Scanner to find MPG in 2010 Civic model. Is it possible?
  124. 2007 Honda Civic Vtis FA1
  125. AC Compressor Cycling
  126. 2006 civic
  127. Loud warbling noise from left side of engine bay on startup
  128. Honda Civic MKVII 5door Front & Rear Speaker Size ?
  129. Speedometer increasing randomly at a stop, beeping sound
  130. HONDA CIVIC 2009 LX SEDAN QUESTION
  131. NEED HELP w getting a water stain out of seat
  132. Looking to do seat swap, need help
  133. tranny missing a bolt
  134. At what age and mileage did your TPMS sensors fail, or have they not?
  135. Civic si ecm and immobilizer issues.
  136. 2004 civic hybrid oil leaking from Aluminium lipped cover
  137. what modifications will void drivetrain warranty?
  138. Code 83-11 Permanent - PCM Malfunction
  139. i need to do a clutch but i dont know what clutch to get
  140. Civic 08 L13A7 error P0606
  141. Droop’s FB6 Build
  142. Need help with smoke/grinding issue ID on video
  143. Civic Hatch 2010 front grill/mask
  144. KTuner V1.2 install & Basemap
  145. Climate control lights
  146. Check system flash
  147. Air Conditioning not cold when hot outside
  148. 09 Civic HVAC or A/C Compressor Problem.
  149. Aux/Bluetooth radio adapter
  150. another air con issue
  151. break fluid replacement
  152. F20C swap fwd base lx conversion?
  153. Idle Misfire/Knock
  154. 2011 Civic si rear deck speakers into
  155. Honda Drum Brake Upper Return Spring Wrong Location?
  156. Can someone tell me where this plug goes?
  157. Stuck windshield wiper arm
  158. Oil leak between oil filter and VTEC solenoid
  159. AC compressor not turning on
  160. Alternator replacement
  161. Hybrid groan when accelerating from dead stop on incline
  162. Blowby or Normal Crankcase Pressure, K20Z3
  163. 2007 Civic Ex Coupe Radio Replacement
  164. Low Gas Milage Honda 2013
  165. 07 Civic EX Shock absorber hell....
  166. 2006 Honda Civic not starting
  167. 2008 Civic Si Sedan Question.
  168. Is Spec-D a meme?
  169. What is cruise main light on dash board ?
  170. 2008 Civic EX longer turnover time
  171. Honda Civic 2007 Coupe 1.8L - Cranks but won't start
  172. 2007 civic si engine swap questions: locked my motor and need a new one
  173. 10th gen EX-T/SI or 8th Gen SI for power later
  174. 2006 Civic AC Intermittent Cooling
  175. Recharging AC system
  176. Cool air (not a/c) not working.
  177. HOW MUCH OIL DO I ADD
  178. 08 civic throwing map sensor code after cleaning in throttle body
  179. 12mm screw + caliper pin stuck together (06 Civic)
  180. Reliability of A/C system in 8th gens?
  181. Clicking noise while driving.
  182. sluggish starts
  183. 2008 Civic AC blows cool at night, hot during warm weather
  184. 2013 civic AC not working
  185. 2007 Honda Civic AC Not Working
  186. 2013 Honda Civic Sedan maintenance question
  187. Problems playing music and charging my iPhone X simultaneously (Honda Civic 2013)
  188. Push button problems
  189. Emergency brake not working after caliper replacement
  190. 2009 Honda Civic Rattle Noise
  191. Trouble deciding between Stock air box/ CAI/ SRI
  192. 2008 Civic AC very slow to cool
  193. 2013 Civic LX Automatic - vibration at Low Idle. Seems to get better when A/C is turn
  194. 2010 Civic EX belt Change
  195. 2009 honda civic coupe
  196. 08 civic lx coupe condenser
  197. 2012 Civic HF shop manual for DIYer?
  198. Disable 2009 Civic Alarm?
  199. Rough Idle, Battery Dying, Belt Problem. I could use any help
  200. turn signal issue
  201. honda civic 2009engine won't start-went thru water
  202. choosing shocks 2009 honda civic natural gas
  203. 2012 Honda Civic EX source button and radio console buttons not working
  204. How complex is the rear trunk lock mechanism?
  205. Audio off, screen stuck
  206. A/C Frustration need help 08 civic
  207. Front Speakers Not Working
  208. Honda Civic 2007 Brake light
  209. Can I run a K20a in fg2 si?
  210. civic no power
  211. fiberglass fenders and bumper
  212. 2009 Civic left front turn signal blinks fast
  213. 07 civic si engine locked
  214. 2012 civic rear passenger side window doesn't operate
  215. SRS light intermitent
  216. Key reprograme
  217. How to avoid "ricey" sounding exhaust systems?
  218. Surging RPM while driving at cruising speed in '07 EX
  219. I turn key and 8th gen civic does not even crank.Turn key second time car starts up.
  220. Can a mugen spoiler go on a 2012 Honda Civic si ?
  221. 2012 Civic Car dies when turning and adjust steering wheel
  222. I have Honda Civic 59 plate and it has failed its MOT due to rear bearing.
  223. 2008 honda civic ac
  224. 2010 Civic LX question
  225. 2013 Honda Civic Brake Bleeding Sequence?
  226. 2012 Civic A/C evaporator and expansion valve replacement
  227. HCH 2007 Jerky Acceleration (not hybrid battery related)
  228. No refrigerant, but my AC compressor still kicks on and stays on!
  229. Civic throwing codes P0523 and P2647
  230. Tree branch broke windshield, now car won't start!
  231. How to move seat belt.
  232. does my car have gps
  233. HELP!! 2009 civic si Lowering Springs
  234. honda civic radiator support
  235. 2008 SI - Coolant & Condenser Fan NOT Working
  236. Civic 2008 Si Performance Mods
  237. Has anybody experienced this? 2011 Civic EX
  238. Clutch Delay Valve -2010 EX
  239. Automatic transmission filter
  240. What center cap will fit this Honda wheel?
  241. Side door body trim
  242. Help
  243. Amber faults displayed
  244. Radiator Cooling Fan Issue
  245. 07 Civic Si - Driver side window
  246. 06 civic si srs code doesn't exist?
  247. Help me be a Slam Boi
  248. 2013 Civic VSA/ABS/Power Steering Nightmare!
  249. Battery light issue 2006 Civic LX
  250. 06 Blend Door Actuator Replacement
