- ..::ViNZx_xD FD2's Official Track/Show car Build Thread...Work in Progress::..
- srt or full race turbo kit?
- VTEC Decals
- RRC Manifold
- transmission problem 2008 civic si
- Maintenance Minder 101 - Dispell or Reinforce the Rumors Please
- hand tighten oil filter?
- Considering a 09 Civic Sport sedan..
- Turbo vs. Supercharger.
- Where is the aux jack in 2007 honda civic sedan?
- SEMA 2012 Civic Builders Announced!!!
- 2009 honda civic front bumper
- Race header help
- 2006 si
- '08 Si wai problem
- Si fuel economy
- Horn no longer sounds when remote locking
- any thought good / bad
- What is my first must do?
- high octane
- My car won't shift out of Park!!!
- Del Sol Seats in 2007 SI Sedan
- beaks back lower tie bar install
- 2012 SI
- Gas Mileage and new tires???
- trading my trunk ???
- 06 civic keeps overheating
- Civic si HEADERS
- A/C (air conditioner) does not work when running AFM tune
- Starting Civics Without Key?
- 06 Civic LX AC turns off when headlights turn on
- Removing the civic emblem
- question about racing a 2009 stock civic
- question on wheels
- how much power will i be making if.........???
- going purple ??
- (Short Ram Intakes) AEM vs K&N vs Fujita (etc).
- Sound during drive n reverse mode
- 09+ grille swap on 08- civic si
- Cold Air vs Short Ram
- Apexi WS2 Exhaust Question
- Funny light on Dash
- small dent on my honda civic 2009
- Sun Visor Settlement
- 2007 Si coupe, no start
- 2008 civic si foglights
- '06 Honda Civic HVAC Cabin Air Filter Replacement
- FA1 build!(?'s)
- $$$ July-September 06-11 FS/WTB/WTT $$$
- Help i have transmission problem!!!!!!!!
- 8th Gen Civic has two bearings in each front wheel hub...should I change both?
- i need help please!!!!! [Transmission Problems]
- cant reset oil maint light
- Weird pull..
- cd player in honda civic 2007 won't load cds
- Skunk2 muffler sound vs. Full catback on '11 Si
- 07' Civic Seems Choppy?
- hard shifting under acceleration 08 si
- What's the issue with a flex pipe on a header?
- NEED HELP ON PRESERVING ENGINE AND TRANSMISSION LIFE!
- 2008 LX driver door assem
- Tire rubbing
- Cobb or Hondata
- check out a video I made of my car :)
- 07 Civic Si coupe wont start. Help.
- Lockerloop.com
- Unable To Play MP3s On My 2012 Civic
- Clicking noise when 50mph+
- takeda intakes
- Sickest weighted shift knob for the 8th gen civic...
- New to the forum (and to Civics)
- Edmunds: 2012 Civic Si v. 2000 Civic Si
- weird issue with 2009 Civic LX coupe...Please Help!! :(
- Check Fuel Cap Light
- 2008 Honda Civic Front Bumper Grill question
- Engine Swap '07 LX
- (((2006 Civic Hub rememoval?)))
- NEED OEM RADIO WIRING HARNESS!
- OEM Yellow Fog Lights
- That Blue Tape
- New 2010 honda civic si
- 8thgen Civic Video Contest
- a2 head in 08 civic si
- anyone wana trade apexi exhaust for a louder one
- Shot of steam...help 2009 Civic
- posting just to post
- 2009 Civic, wierd sound in idle, help?
- Engine sounds different, should i be worried?
- engine oil and tranny oil recommendations
- 2006 Civic Coupe brake job
- Honda adds second shift: 1,000 employees to build Civics
- maintenance questions - timing chain replacement? what else?
- Lube 2008 Civic Hybrid
- New Civic Mugen SI Owner
- Please help
- CiSi rip???
- Authentic CTR knob?
- Please Help Diagnose This Problem
- QUICK! Need torque specs for 2010 Si
- Worth reshaping a totaled FD2 ?
- Rack and pinion replacement
- 8th Gen Honda Civic Radio Code Thread
- Good deal or bad Idea? 07 Si 360HP opinions please.
- Honda 07 civic passenger window wont roll up
- suspension help
- Brand New K20 Head Under WARRANTY
- fg2 key
- BC stage 2 cams
- Skunk2 Lowering Springs
- New Member
- 08 Civic Si Cluch
- 06 Civic Si rev hang problem
- 06 SI axle the same as ex ?
- Interior LED Kit
- 2007 Civic Clutch issues
- 06 Civic Turn Signal Problems
- quick headlight question?? is 2 and 4 door the same??
- GP Thunder 3500k
- Anyone using a Moddiction shift knob?
- New Member
- Car won't start
- Best rear sway bar and simple handling mods?
- Civic in U.K. = Civic in Japan ????
- 09-11 civic ? belt noise, knock sounds?
- Go Power K20 header
- How wide can I go on stock rims?
- Where I should mount the VSA Motion Sensor
- 08 civic Squealing on back wheel
- 3 inch exhaust in my Civic Si?
- Down Pipe
- 07 fa5 noise under acceleration......b
- Honda emblem advice.
- 2008 Honda Civic Compressor out
- Oil change questions.
- A/C conversion kit for a 06 civic DX??
- just purchase and 08, trunk and automatic lock problems
- core support
- Civic Paint Oxidizing
- Apexi N1 Dual Muffler on 2009 Civic SI sedan?
- Steering rack
- headlight question
- Leaking main seal
- Where to find ???
- Blackworks Coilovers - rear not low enough
- 2006 Accord Window Problem
- bolt pattern of 06-current civic
- Feedback on Megans Racing Street Coilovers please
- Getting Wiper Blades BACK ON
- Can i use rsx axles and front rotors on 06 si
- SI Exhaust vs EX exhaust?
- DIY walbro fuel pump 06+ Civic all models
- CIVIC get special treatment from State Trooper
- Import DPS - Kraftwerks Powered 2007 Civic Si with K-Series Race Kit 407HP
- Lowering my Si...
- Rebuilding a Type S 2007 2.2 Non GT
- Stupid Question Re: 2006 Civic Fuse Box
- Motortrend first drive of 2012 civic
- 9th Gen 2012 Honda Civic Officially Available Today
- Are all 2006-2011 Si "the same"
- Record for quickest 8th Gen Si w/full interior?
- 07 si squeeking and creeking ? HELPPP!!
- car tape unlock code for honda civic 2006
- si sedan pulls to the side..
- Seat belt slack
- 2006 Accord Coupe door won't open from inside
- Putting 15" alloys on SE Civic 2011
- feedback on ebay lip kits?
- quick timing question
- 09 Civic burning smell inside cabin
- crappy paint\ clear coat failure
- IF YOU HAD THE 3RD GEAR SET REPLACED ON YOUR 8th gen Si...
- 06 civic tensioner problem!
- What to look for when buying a civic si?
- New wheels Potentially Enkei PF01's
- Starting Problem With Civic 07
- SI ON BATTLE LOS ANGELES (MOVIE)
- 2007 Honda Civic loses power
- Front camber kit only, but with an s2000 alignmnet
- Loose/imprecise steering
- Civic si sedan what do I need to know?
- $$$ April-June 06-11 FS/WTB/WTT $$$
- ARP Extended Wheel Studs
- Waxing Polishing Compounds Suggestions?
- Best Injectors size 15 psi
- Owner on here? few questions
- Civic Cub Caps
- Dealer making me replace axle...
- problems with buddy club n+
- new lip on my 09 civic 4dr
- The Dark Night JRSC Build Thread..
- I need 06 civic SI front spindles can i use one from an RSX?
- Question about Before starting
- DC HEADERS?
- Civic tpms
- 2008 FG1 Coupe Rear Window Visor/Deflector?
- maintanenace plan for warranty
- First Civic (and Honda) what should I know?
- 2012 Civic model break down... info inside...
- Honda civic rust protection
- New here and newer civic
- OEM Honda Touch Up paint question!
- Fuel system cleaner, what do you use?
- Anybody know who owns this car?
- 5zigen rim size
- lowering my 2009
- ABS light on after replacing real hubs
- Cleaning your windows with....
- HELP with lowering intake and more !!!!!!
- 2006 Civic cupped tires.....warrenty question
- Changing the auto-open locks
- Is this right?
- Am I a fool?
- Springs, got a question??
- keyless entry
- Re:less than an inch drop. do i need a camber correction ?
- Help with dash lighting
- 2008 Civic SRS code 2-7
- Putting Ex HFP suspension in my Si
- 2012 Civic Si receives 2.4L engine, new HF model intoduced
- 2006 Civic Rear Control Arms - Again
- Am I screwed???
- Inquiry about my 06 Civic EX Coupe.
- 09 civic help!!!
- Short Shifter SI 08
- Intake question.. Suggestion
- Which is a Better Setup?
- Installing Civic Si Steering Wheel on '09 Civic EX
- P0776 error...06 ex auto fg1
- Strange buzzing noise on startup
- 07 hfp come gun metal?
- What's wrong with this picture ??
- 06 Manual Ex Check Engine Light and Code A134
- Lucas oil additives
- Sudden revving while stopped - 2011 Civic
- Black Widow 321hp 226tq on e85
- Transmission pull on 06 up SI ?
- New to the forum... well, new to Honda too
- Chewed sensor wiring, what does it do?
- 06 Civic LX fit Si lowering springs?
- SRS Light on Even w/All Airbags and New SRS CPU... Help!!
- GGC|grocerygettercrew.com Featured FA1 Civic
- buddyclub N+
- Picking up a new '11 Si sedan tomorrow
- How wide is too wide on wheel sizing?
- Need Some Help
- Burning smell coming from engine or under car.
- 2012 Civic Going On Tour... To all dealerships...
- "Bubbles" in the back window ...non-tinted
- Need help with exhaust
