PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Right side turn signals not working please help!
  2. 2011 Civic LX 4dr replacement headliner
  3. How to drain gas on 2007 civic
  4. 2015 Honda Civic Si Sedan Clutch Replacement
  5. Honda Civic Type R AC blower won't switch off
  6. startup delay
  7. 2007 Honda Civic Clutch problems (PLEASE HELP!)
  8. 2014 Civic EX - Elec. Window Switch
  9. 2009 Civic SI Clutch/Flywheel Question
  10. 37805-R60-U540
  11. Strangest sound coming from the rear suspension (loose change, bells, tambourine)
  12. 2012 radio issue
  13. steering noise
  14. Timing a k24
  15. 2012 Honda Civic power outage with tire rotation
  16. Changing Climate Control Light bulbs
  17. Tune up? What needs to be changed?
  18. can someone identify these clips?
  19. Stupid question
  20. Thinking about buying a new civic LTFT normal?
  21. Should coolant be up to the radiator cap?
  22. Honda civic i-vtec
  23. '12 Civic - larger battery ?
  24. 2013 Honda Civic doesn’t get power to horn , coils,stop lamp fuse . Crank no start
  25. 2015 Honda civic muffler
  26. 2012 civic coupe accelerating and deaccelerating
  27. Loose Master Cylinder Cap?
  28. Can someone identify these parts?
  29. 2008 Honda Civic only heats properly right side of steering wheel
  30. 2009 honda civic 1.8L.
  31. Honda civic 2008 Exi key broken
  32. Honda Civic touring 2015 - AUDIO OFF
  33. 2012 honda civic headlight low beam not working
  34. FA5 Making weird ticking noise from passengers side of engine bay during acceleration
  35. Intermittent speedometer
  36. Clock seting
  37. Civic Hybrid 2014 air-cond switch stick at fresh air
  38. Help with clock/usb
  39. Anyone want to help solve a puzzle?
  40. JDM Civic Hybrid Engine in US Civic
  41. 2012 Civic EX Ambient Temp Sensor
  42. Removing vtc actuator
  43. 2015 Civic - AC/Heat Blower Noise
  44. Rattling noise from 2006 Honda Civic lx
  45. Damaged Oil Pan
  46. Stripped spark plug threads
  47. cruise cotrol
  48. Duplicating car key with remote alarm
  49. [Civic 9nth Navi] - Honda Connect Replacement
  50. Parasitic drain issue and remote door unlocking behavior
  51. [Civic 9 Navi] - Honda Connect Replacement
  52. Strange Heater Noise but not blower suggestions?
  53. Car almost starting but won’t start all the way
  54. outer tie rod adjusment - alignment question
  55. Please help - almost done - Loose lower ball joint nut?
  56. 2012 Honda Civic rough shifting
  57. CIVIC SI COUPE 2010 SQUIKING SOUND ACCELARATION
  58. please help - red and tacky grease outside of wheel bearing
  59. ABS Issue
  60. Need help finding trans mount bolt size
  61. Heavy Duty Metal Protection ON EVERYTHING!?
  62. Door locks not working
  63. wrench size for front outer tie rods
  64. Brake Dust Shield Screw
  65. Cotter pin - Lower Ball Joint
  66. Best spray to prevent future rust?
  67. First time doing Front Wheel Bearing/Hub assembly.
  68. Leak near power steering pump
  69. Removing Wheel Hub Bearing, do i need to take out the snap ring?
  70. Clear coat issue - Fixing patches of damaged areas...
  71. 2009 SI problem rattling
  72. Fuse 29 and 31 Parasitic draw
  73. Help - Identifying cut wires To/From Alternator
  74. 2007 Honda Civic - Wheel Cylinder - Unequal Pressure?
  75. 2007 Honda Civic - Brake Adjuster - That Piece near it
  76. Cross threaded lower(shorter starter bolt) need help with size to recut threads
  77. Bolt for removing brake drums in '07 Civic LX 1.8L
  78. Lifting up rear of 2007 Honda Civic
  79. 9th Gen 2014 Honda Civic Si Sedan - How To Remove Dash
  80. VSA module, brake master cylinder issues??
  81. 2012 Civic Hybrid IMA/Charging errors
  82. Weird behavior, car wont start after service
  83. 2010 Civic no brake lights
  84. 2013 Civic Si Coupe Front Speakers Cutting Out
  85. Replaced ecu and getting no acceleration
  86. 8Th Gen Civic drink lot of gas
  87. Need Ignition Switch 2006 Civic EX
  88. 8th gen civic - first time wheel bearing and hub replacement
  89. 8th gen Civic - Squeaking brakes when pressed halfway
  90. What clutch should I get ?
  91. Honda Civic Hybrid 2010
  92. 2006 CivicEX Accelerates Abruptly When Braking At Slow Speed
  93. Which Standalone ECU available? AEM,Motec, etc.
  94. Location of Engine Coolant Temperature Sensor?
  95. What can I spend $4000 on for maintanance?
  96. ECU
  97. 2015 Honda civic 4-1799 1.8L rumbling at 2k rpm only.
  98. Civic Si flooded in NYC area help
  99. 2006 Honda Civic Downstream 02 sensor location?
  100. What model Civic do I have? It was originally a 2010 Civic
  101. Refrigerant pressure diagnosis
  102. Help: Rerouting belt to bypass AC compressor - [2010 Civic]
  103. Guys need some help - flood damage won't start
  104. Question About Exhaust that will fit a DX-G
  105. 2009 Honda Civic LX fuel supply line replacement.
  106. Trouble with rims….help
  107. 2009 Honda Civic ex 1.8 l
  108. 2009 civic si grinding noise
  109. Key won't turn Steering Wheel Locked.
  110. Parking Light issue
  111. 2008 Civic - Dash Light Issue HELP!
  112. Power Steering
  113. Steering column spring
  114. Honda Civic 2015 LX Transmission Fluid
  115. Help 2007 civic
  116. How important are mud flaps? 2010 Honda civic ex
  117. 2015 Civic Value Adjustment and tools needed
  118. 2006 Civic sedan LX 1.8L replaced motor mounts still vibrates
  119. Things to consider for a high mileage 9th gen Si
  120. Weird A/C Trouble 2010 honda civic ex
  121. 2012 honda civic ex 5speed transmission issues?
  122. How important is OEM for Tie Rod replacement?
  123. OBD 2
  124. Crank position censor
  125. 2014 Honda Civic - O2 Sensor and Catalyst not ready
  126. Max A/C Not working
  127. Visor "droops"
  128. Turn signals and hazards not working
  129. 9th gen si saggy door problem
  130. A/C 2008 Honda Civic
  131. How important is this hose on civic ex 2010?
  132. Unsolvable mystery, steering jerks left/right on irregular road
  133. Cranks but doesn’t start 2007 civic ex coupe and no codes
  134. 2008 CIVIC DX OVERHEATING WHEN IDLING BUT.....
  135. High Pitch Boise when Driving
  136. 2015 Honda civic 4-1799 1.8L loud rattle when accelerating low gear.
  137. 2013 civic si sedan ac compressor bearing issues??
  138. Immobilizer issues
  139. 2006 Honda Civic Body Repair Question
  140. A/C 2008 Civic
  141. 2015 Honda Civic SE (or LX) Key Reprogramming Issue
  142. 2008 Civic Dx SEDAN OVERHEATING
  143. ABC solenoid valve malfunction
  144. Drum brake, rear brake shoes thickness, 2009 Civic LX
  145. 2006 Honda Civic hybrid problem
  146. 08 Civic Si Sedan 2.0L misfire codes
  147. 2009 Civic Type r FN2
  148. Civic 2013 ex l ac relay
  149. 8th generation Backfire after warmup
  150. Front & Rear brake job
  151. Issues with my 2015 SE
  152. 07 civic broken wire on new starter install
  153. 2006 Honda Civic Engine Noise
  154. 2007 honda civic wont rev past 3500 rpm
  155. 2011 Si Sedan Radio/AC Lighting
  156. 2009 Civic LX, key foab
  157. 2006 Honda Civic ex 1.8 non vtech sedan
  158. 2007 civic EX sedan wipers
  159. Manual Transmission noise
  160. 2015 ticking sound when accelerating
  161. 2009 Civic LX, P0171
  162. 2009 Civic LX, AC leak in evaporator core
  163. C101 Plug/Grip pinouts Civic Si 8th Gen
  164. 2012 civic issues
  165. Honda civic 2014 spark plugs
  166. 2013 Honda Civic A/C leak
  167. I need your opinion which to buy
  168. A/c line freezing have pressure switch question
  169. Mildew smell from window after replacing molding
  170. Fuel pressure relief
  171. 08 civic coupe turn signal /running light issue
  172. Temperature sensor question
  173. Got a civic as a gift but it’s a hybrid-convert??
  174. Desperately need battery advice
  175. Fog light wiring question
  176. 07 si help with vsa
  177. Odometer stopped working - speedometer is normal
  178. Control Arm Bushing Advise
  179. Noise after bumps
  180. What Pulley Is This
  181. fan blower hight pitch noise
  182. Steering noise
  183. Battery : honda vs honda original vs manufacturer brand ?
  184. 07 civic lx manual trans fluid change
  185. 2007 civic lx coupe knock sensor replacement
  186. Intake throwing code and shutting off a long waits at red lights
  187. 06 si new engine
  188. Manually closing the moonroof on a 2009 Honda Civic EX
  189. Rubbing stock suspension issue
  190. 2009 Honda Civic limp mode problems
  191. hybrid 2007 in limp mode, p1287
  192. Belt doesn't fit?? Confused
  193. 2006 Honda Civic LX
  194. 2007 Civic LX Passenger Airbag light flashing off/on
  195. Picante's build thread! Lets do this again :)
  196. Loose squeaky rattling sound
  197. New axle seal leaking
  198. Emission Test Limits of Honda Civic
  199. 2015 Civic LX front rotor, 45251-TR3-A00 vs 45251-TA5-A00
  200. Opening back seat/trunk pass thru
  201. Rattling Noise 🤯 -VIDEO-
  202. Rusted NEW CV axles with play
  203. 2006 Civic hybrid door lock / FOB issues
  204. 2008 Civic AC Compressor replacement
  205. 2015 touch screen head unit wiring diagram
  206. I have a 2007 lx, I want yo tune it. Can I use the si Ecu from a 2007
  207. 2012 Civic LX noise check - normal or bad bearing?
  208. Coolant pipe name?
  209. Civic Seat swap for Accord seat?
  210. Horrible fuel economy?
  211. 1.3 electric gas misfire
  212. Add Navigation Package?
  213. alternator fails to fully chargebattery
  214. Mixed info about transmission filters
  215. Bizzare Stalling, rough idle, and partial dead pedal but No CEL
  216. 2013 civic coupe non si exhaust question.
  217. Engine noise 2008 Honda Civic
  218. Test driving an '06 Civic LX sedan, what questions should I ask the dealer?
  219. 06 Honda Civic ex swap help.
  220. Transmission Troubles
  221. Wont start
  222. Visual clues to R18A
  223. 2009 Honda Civic si remote start
  224. Honda civic lx 08 bank 1 lean
  225. 07 si help
  226. Concern
  227. Hit the brakes and dash lights up.
  228. 2014 1.8 L Civic
  229. 2010 civic lx
  230. Telling the difference between DOT 3 & 4?
  231. Immobilizer issues PLEASE HELP
  232. 2012 Civic LX Automatic Noise
  233. Radio Bolt for 2013 Honda civic 8mm
  234. Does Honda Civic 8th Generation Manual Transmission have synchronus Transmission?
  235. P0301
  236. Lightweight 18" rims
  237. 2013 Auto Civic EX - Kickdown/Acceleration Issue
  238. which honda civic year is the best
  239. Honda Link Screen
  240. 06 ex coupe suspension kit for front and rear
  241. Mods for a 2006 Honda Civic dx coupe 1.8L V4
  242. K20z3 bottom end - k24a top end
  243. new-to-me radio - the code retrieval tool isn't giving me the right code
  244. 12-15 SI Cruise Control
  245. 2013 Honda Civic (coil overs) suspension question
  246. Diagram Arnes Civic si 2015
  247. 2012 civic coupe exhaust question
  248. 2007 civic Si p2610
  249. 2005 Civic Lights flash Randomly after locking
  250. 2010 Civic Turn Signal
