- fuel flood when stop at ligth
- Amsoil
- Transmission Fluid Exchange
- spark plug replacement
- What is this hanging from the bottom of the car?
- Civic 2010 front bumper on 2007 Civic sedan
- Help me Please. Si 2007 Coupe
- Reprogramming Shift Points in '12 Civic?
- Radiator/ Condenser Fans
- 06-11 SI Tachometer/Odometer help!
- Seeking advice add a little power to my 2013 Civic?
- GoPower Cam install on R18 and no run!
- VSA problem
- Air Conditioning
- Strange smell & leaking in
- 2007 Civic Air Filter Box Removal
- fd2 conversion
- 2008 civic AC ACCUMULATOR/DRIER
- 2007 Passenger Power Window Switch Faulty
- iphone 4s won't connect
- Straightpipe?
- Drop springs
- Civic door lock
- Lowering Springs
- Skunk2 Intake Review
- Koni Str.t with Stock Springs
- Car shaking
- Rotors for a 2010 Civic Already?
- 2007 Civic auto transmission problems
- 2009 Civic Rear Bumper
- Honda Civic 2012 radio issue
- I'm back!
- Best exhaust?
- New to Honda Tech
- Door Lock Clips
- tire noise 2011 civic si
- 2008 Mugen Si
- 2008 EVAP codes after AC repair
- Help! My key won't turn!
- 2013 Civic Si
- civic lx 2009 4dr - constant hum in the speakers
- 2006 Civic AC Compressor Clutch
- radiator problem blown head gasket??
- running car with leaked compressor
- 08 fg2 turbo questions
- CAR IS SQUEAKING!
- School me on stock stereo head units
- MAINTENANCE MINDER
- 2011 Civic SI 4DR Front Bumper Replacement
- hold on car.
- Passenger seat occupancy bypass
- some wisdom of the honda gurus...
- Glass pane rattling sound coming from new 2013 Coupe LX??
- Brand new 2013 Honda Civic Coupe LX - PLEASE help
- HELP!!! I need a ect connector to a 2009 honda civic
- 2006 Honda Civic transmission Fluid ?
- New to this!
- Radiator Support Cover Noise
- ABS, Traction Control, ABS-Only At Highway Speeds
- SI or..
- 07, no noise, and half second crank
- Service Schedule - Miles or Maintenance Minder?
- Spoon fd axle back question...
- Will they fit? 2008 Civic Sedan with 18x8 (+38) and 9 (+44) & 225/40/18
- Wheel Bearings? HELP - 2011 Civic Si Sedan
- Squeal noise
- Is this a good deal?
- AC issue Civic 2009
- Pulley...to fix or replace? Which is the right option for me?
- Help! [I Need Help About a Oil Leak Issue]
- OBD II Connector
- Tire noise on 2006 Honda Civic
- AC clutch field coil problems
- 2006 Honda Civic Problem
- radio code
- Steering Wheel shaking at highway speeds
- 07' CIVIC SI TIPS NEEDED
- Wrecked. Frame Damage? Bought certified
- 08 lowered
- 08 civic si drive by wire TB clip broke
- 2006-2008 Civic rear control arm / rapid tire wear settlement letter
- 2007 Civic EX A/C issues
- Civic Si cold start noise
- My Review of the Honda Civic 1.8 i-Vtec Executive
- suggest Inexpensive power upgrades for FG2
- 06 Honda Civic gets stuck in gear (automatic)
- 2006-2009 service manual
- 2012 coupe si race carz
- 2008 Honda Civic Cold Start Noise?
- tune up
- 08 Civic Si 2.0L 4cy V-tec AC/Overheating problem
- 08 Civic SI 4Cyl 2.0L V-tec Overheating/AC Problems
- 2006 Civic Air Con - Re-Gassed but still not working
- 2009 honda si oil burining, is it normal?
- 12 Civic LX problem, custom settings blacked out
- Pending code
- what wire / sensors are these ??
- No codes, but still hesitating 95 civic
- Just picked up a 2013 Si.
- Deceleration Isnt Smooth
- 2012 honda civic license plate lens installation
- 08 si full mugen conversion kit
- Is it worth replacing exterior parts on a Civic SI Mugen with non OEM parts?
- 2010 si
- Whining sound 2009 Civic SI - what is it?
- 2013 Civic Grill change
- Brake Issue
- please help 2010 si!!!
- New 2008 Owner.. idle a bit low in stop lligth
- 2013 Si dropped on H&R Sports
- 2006 HCH CVT different than 2007+?
- Clutch gets progressively worse as I drive.
- 2006 AC Compressor Diagnosis
- 2009 Civic Coupe making noises
- 2013 "USB ERROR"
- 2008 si cambered
- Front lip for 2008 civic SI
- Selling 2008 Honda Civic Mugen SI
- 2010 si fuse
- Coilover help
- Difference In FPR size 06 vs 11 car stuck in limbo
- 2007 HCH replace control arm bushings?
- NEED SOME HELP ON BUYING AN FG2
- Stock alarm not activating help!
- 07 Si Starting to Rust
- 2013 Civic 3000 miles towed to dealer
- Clicking sound coming from cluster
- HELP 07 Civic stereo/gps CODE
- 06' civic trunk squeek
- 08 Honda Civic Salvage Project!! (Air bag question)
- 08 Civic, A/C compresser won't come on, freon is full.
- looking for a new project car
- work emotions
- Skunk 2 Alpha Header vs Invidia Race Header
- How to fix some paint damages on a budget?
- Suspension for daily driving lx?
- Looking for a dual exhaust design
- 06 Civic Engine Coolant Sensor replacement
- Rough Idle on '07 civic
- fn2 exhaust muffler
- JDM CTR front end conversion 08 Si
- Good place to source a hood?
- Immobilizer brake code help
- Side view mirrors for 2008 Civic
- Amsoil Synthetic any good??
- 2008 Honda Civic Ex won't start
- Civic Si EPS malfunction
- 06 civic 1.8l sedan LT-I Australian -> grinding noise getting bad
- New Brakes and Rotors Scraping
- new owner 06 civic EX ..exhaust??
- Crashed '06 Civic coupe - estimate please?
- Please disregard
- passenger side rear power window and power door lock both quit working
- Thoughts on intake resonator delete? Honda civic Si 2006
- 06 civic lx coolant leak
- Fuel Guage
- 2010 Honda Civic - Won't Start
- What to do if lost lug nut key
- I need help COD RADIO CIVIC EX 2006
- 07 SI foglights
- 2007 Civic
- civic 2007 Replace Engine Car won't start!
- 2006 SI No start
- 2007 EX Fuel Gauge Problem
- 2013 civic si sedan thoughts?
- civic 8th gen wheel sizes. Rims.
- Which one I should buy? 06 EX sedan or 10 LX sedan
- Why is my wheel sticking out?
- 2006 Civic EX Engine Clicking Noise
- Bought a new 2013 Civic - Rust already?
- bleeding clutch
- Si Suspension Question/Advice
- Help Looking for Driver seatbelt and buckle 09 civic and roof linar
- Seat covers
- Coolant Leak by EGR
- 2009 civic ex-l sputters
- HELP!!! Fg2 vs fa5 fender
- $$$ Official Jul-Sep 2013 WTB/WTT/FS Thread $$$
- How do you reset computer for AC system to function
- 2006 civic ac working intermittently
- 2009 Civic Hybrid side airbags deploid
- car enthusiast
- FA5 Brake Suggestions
- Identifying this noise....
- Bought a 2013 Civic... and it's making a loud clunking noise!
- pro s v2 rattling coming from passenger rear
- need help asap
- Topping off the Oil
- My Supercharged 2010 SI
- Headlights ajustment
- TSX TB Install Issues
- 2009 civic 5 speed auto/will not shift into fifth gear
- turbo kits
- 06' Civic EX - Radio Doesn't work after Battery Replacement
- 2009 Civic Sedan EX Auto
- help with cat
- J's racing 3 point strut bar??
- car is extremely jerky when its cold! 2011 Si
- How do you Change the skirt/boot on a 2008 Civic coupe ex shifter?
- Wiper relay
- DIY: Fix your sun visor with a Large Binder Clip
- 8th generation horn replacement
- 2006 Civic Airbag Harness Broken
- Honda Civic 2012 remote starter
- Do I Really need a new ECU???
- ABS code after replacing wheel bearing
- warranty and aftermarket parts
- good intake?
- Cracking, grinding noise when turning left
- Front rotors on 2010 dx-vp
- K20a3 in 2007 civic Si
- red over lays on tail lights & black tint on head lights
- NEW
- Bought an 09 Si
- EMBLEMS
- Replace Radiator 2006 Honda Civic 1.8L
- Spammer alert ( moderator action required)
- k20z3 getting old questions...
- civic steering wheel problems
- Connecting a phone to Honda Civic CDTI
- TSB
- 2006 civic will not start!!!
- Front Lip Options.
- hard to shift on high rpm?
- Windshield wipers stopped working
- Rough shift from 1st to 2nd
- 08 Civic Si Coupe Skunk 2 Exhaust Question
- PIC REQUEST, 08 FA5
- JDM FD2 Parts
- 2013 Intake Preference
- 09 honda civic si revers problem
- 2012 Honda Civic 4dr Wiring Diagram
- Honda Hybrids reliability
- 2 abs codes - 2006 civic ex
- Just wondering
- will this rims fit
- 2013 civic owners are lucky :(
- both my cig lighters broke can someone help?
- 07 Civic SI Engine Room Harness
- Installing a Tachometer on Si
- Red Line Synthetic Gear Oil for civic si 06
- Lost both keys to 2006 civic
- Help with VSA Light!
- 2008 Civic Lx Bad Idle Rough Idle when warm
- what do you guys think about this? a good buy?
- Should I get a Civic Hybrid or Honda Fit? Need advice from Civic and Fit owners
- Climate Control removal help needed!
- Newbie has questions, what generation is my Honda?
- 2013 Civic SI turbo kits?
- I’m looking for a "light size" manual .
