- Tire Size
- check engine light trouble
- 06+ si turbo
- What do you 8th Geners get for mileage?
- Fuel for Civic SI
- vibrating noise
- New Skunk 2 IM for 06 + Si?
- BEEP SOUND
- URGENT!!! P0812 code ,Gear Indicator LED will not light up in Reverse on cluster
- DIY: Beaks Rear Lower Tie Bar Install
- FOUND IT
- Honda "Customer Service" with my 2006 Civic Si
- a/c fan slows-dealer clueless
- wont go into 2nd, or 3rd at high rpms.
- What combo
- O2 defouler
- 8th gen civics at I.A. 09
- Flash pro w/ turbo or SC, Drivability problems?
- where do i buy..
- Time to park...i think
- to buy or not to buy...
- 100+ hp setup question
- 09 vs 05 SI
- i need new tires!
- Type-R tail lights
- Oem Clutch/Flywheel Torque limits
- Help..What does the VIN mean?
- grinding noise on cold start?
- JDM windshield banners???
- Hard brake pedal, no stopping power.
- 09 civic si "HOW TO BREAK IT IN"
- 2008 Honda Civic Si N/A with Mods FlashPro Dyno Tune Results
- G-Force CatBack Exhaust
- disappearing/reappearing squeaky clutch
- installing extended wheel studs
- Changing Automatic Transmission Fluid
- Am I Rice If...
- PC Card
- 07 LX hesitation
- OEM Cat vs HFC
- Just Bought an 06 Si.
- 09 Civic SI break-in period
- EVO2 vs. Vibrant?
- CEL question
- Takeda intake review
- Where can I find Type-R FN2 Mugen strut Bar?
- CT S/C Starting issues?
- Looking for a Cat.
- FG2 rear seat side coat hanger spring broken
- Short Shifters vs. Mugen OEM Shifter
- OEM Honda Carbon Fiber looking dash pieces?
- Stuck Oil Pan Drain Plug- where to get new Pan or fix?
- 09 honda civic si warranty
- Will it fit?
- wheel gurus!
- major problem
- Extending My Warranty
- Speedo Adjust
- '06 Civic not starting
- Injen AFR Vs. Fujita AFR
- 2008 fg2 TW.. BWAAAA PSSHH!
- skunk2 springs and skunk2 shocks setup?
- 06+ Civic Si background & tuning info in one place
- help with my fog lights
- My New Car
- need help civic 06 up front toe hook
- USB connection in a LX-S, is it possible?
- APEXI is low-balling me! >:(
- Can't seem to pass 300 miles on a full tank.
- K20Z3_IPS K2 8620 248hp, 175tq Hondata Flash Pro Tuned
- Comptech Superchager Pricing Question
- anyone think a comptech supercharger worth it?
- Three Questions
- mugen intake?
- theft rate for the newest generation SI's?
- SRT Turbo Kit Video and Specs
- Car cracking out. Help please!
- P2R Throttle body spacer for the R18
- 09 civic sedan front grill
- D*R*L
- Need Advice on Cooling System Overheat Symptoms!
- Help decide between Civic LX-S and Si
- My new '09 4 door Si-Security check-
- HELP 08 civic hybrid getting bad mpg
- installing new suspension
- Hello
- DIY: 07 Civic Door Panel Removal - Pics!
- installing HIDS on 06 SI
- My Bad Experience with Corsport!
- Hidden Hitch's
- performance parts
- FG Civic Si vs Euro Civic Type R
- PCT CTR ECU?????
- new guy
- K-Series Engine Code
- Engine Races and car lunges forward with foot OFF gas at stop
- Time for a Tune-UP
- 50 Years of Honda
- mid wing
- 2009 Honda Civic-Si and Red Lining
- Car was towed and wondering if doors unlocked
- SRS light on dash
- Question about my 2008 Honda Civic EX
- ?'s about the catless Vibrant header on an 06
- R18/k24 SWAP!!!
- carb swap
- Wheel paint color?
- Lowering
- fuel pump fuse
- Using silicone hoses under hood?
- MTF filler bolt locale?
- Gas guage problems?
- VIBRANT CATLESS HEADER INSTALLED!
- found the problem
- how loud is a race header?
- K20z3 Injector Flow Rate????
- Look what came in the mail (Hondata Inside)
- Help needed on brake job and questions - 06 Civic LX
- Flashpro release date
- stripped bolt!! help!!!
- tein s techs vs eibach sportline springs
- how do you disable seatbelt chime?
- WTB: 2006-up Civic Si Stock Intake (DFW)
- Help with 08 civic sedan si rear bumper!!!
- APEXI Replacement Filter Question
- Tanabe USA Looking for Cars for R&D Testing
- "Help" Noise in rear suspenison
- Converted the SI to E85 this weekend.
- skunk2 shocks?
- f2 rear LCA's...who wants em?
- New Gauge Pod Solution
- DEALER AND WARRENTY WORK
- exhaust install help, rusted bolts
- Grounding or Fuse Issues
- Eibach Sportline Install - Before and After
- Hiccups
- Intake on a 09 Automatic LX
- oil life?
- Speaker Wiring
- SOCAL HONDA/JDM MEET TONIGHT!!!! EL MONTE
- RRC type R IM
- Aftermarket Turbo
- so water leaking tru speaker cover on a 08fa5
- My Fad52 :)
- Honda Civic 1.8 Sport 2008.
- Exhaust
- extended warranty
- 06 Hybrid
- Eibach Springs Creeking...
- Si Exhaust?? Anybody got one laying around they want to SALE!!
- GPS Navi Code given by Honda Not Working!
- DIY 09 Cargo net install
- Foglights with parking lights.
- Cobb Thread Closed?
- is it coming (CTR)?
- Honda Civic Security Alarm Question
- Seat belt locked up.
- 4th gear GRIND with amsoil fluid help
- Do you think there will ever be a civic with dual clutch?
- Royal Purple oil change
- my 09 has paint peeling!
- errors p0342/p0102/ o2 sensor
- COBB AccessPORT for 2006-2009 Honda Civic Si Available NOW!
- Si exhaust??
- 2KRacing.com we are a new Sponsor, Great to be here!
- Grinding noise from brakes while driving
- Airbag Light Came on after hard bump help me
- keyless remote programming
- My 07 NHBP Just Blew Up!!!!...(pics Inside)
- Very slight engine seepage/leak. I'm concerned! :(
- Girl in need of help, Will 2008 SI Sway bars fit a 2008 LX ??
- need new tires
- Engine Stall
- so how long do you think...
- RRC Manifold question
- 2009 Honda Civic JDM type RR sky
- Ups man stopped by to bring me a new toy!!!
- Does a turbo eat up more gas?
- anyone using a test pipe?
- 2006 Civic Lx Speaker Upgrade (stock system)
- Slight "clunking" noise from front passenger side of car!
- 2006 or 2009 Civic?
- 06 Si Coupe Rim specs
- Smallest wheel size that will fit on an 07 Si
- DVD Dashboard console?
- Skunk2 Lowering Springs
- Importing issues with Canadian Acura CSX-S
- BCRH - VIBRANT HEADER WITH CAT DELETE
- low clutch pedal???
- HKS Sport Ti catback!
- Wheres the Si Forum ?!
- Kill Switch
- Honda civic 2006 coupe..bypass lighter to stay on
- HID question plsss
- HID Question
- Wheel Suggestions
- Blowing smoke
- Tire Question
- Pioneer AVIC N2
- Stereo - Scan Facility
- Modified exhaust ticket help
- what kind of civic do i have?
- Hey hey!
- Wheels, Tires and Drop?
- New Guy from South florida
- ex seats in Si coupe?
- Aftermarket steering wheels?
- Check it out (pic)
- CAI install question, 07 FA
- question for those with seibon hoods
- Help! Rear speakers don't work
- Takeda Intake for '06+ Civic Si released. Steep power gain claims!
- pc card.
- what rims for civic?!?!
- 2006 Civic Coupe Driver Fog Light.... someones got one laying around!!!
- Car Cover Fit for couple
- please help if you have seen or had this problem!!
- Wheel stud removal on SI
- 06 civic si opinion
- Corsport Adjustable Endlinks
- Anybody Knows?
- HFP suspension kit vs aftermarket suspension kit?
- 2009 Civic LX Coupe manual
- Race header problem
- stock replacement clutch or high performance?
- ramps...
- Windows Mobile 6.1 + Honda USB port?
- Pre-order flashpro now from evans tuning
- Speedometer Plastic Cover?
- Rear Bumper removal
- Circuit Diagram - Fog Lights * Need help*
- Who Should win?09 SI VS 06WRX 2.0T.Both stock.
- weird rattling noise
- Cannot start my engine!! no because of the Battery! Help ! thanks sosososo much!
- Car randomly stalled on me...HELP ASAP
- new guy
- Honda civic 2006 coupe....accelerates for no reason
- R18 AC Compressor Bracket
- k24 swap!! ...help!!
- New - Hondata FlashPRO
- Hondata announces the FlashPro
- disconnected battery now stereo wont work. HELP!!!
- HELP WITH AEM F I/C "piggy back"
- Resolved!
- good websites
- Red Lug nuts on steelies
- Lowering Spring questions
- After SUPERCHARGE
- Automatic window up problems... anyone?
