PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Civic stalls
  2. what should he do
  3. 2012 Civic Shakes only on accelleration, and only 55- 70mph.. Guidance needed.
  4. Aftermarket headlights on 2012 civic, need some help
  5. vacuum leak? Misfire? Help:(
  6. Need help with Bushing
  7. Directed Plug & Play Remote Start T-Harness for 2013 Civic
  8. What can I do with the 2012 Civic Coupe EXL
  9. Honda was jumped but will not start
  10. Smoke and smell from engine with defroster use
  11. 2007 Honda civic 4 dr wiht AC - instaling alternator belt
  12. Instaling alternator belt ?
  13. 2014 Honda Civic - O2 Sensor and Catalyst not ready
  14. 2012 Civic Si (manual - Vtec) Battery/Alternator/Grounding Issue ? Thoughts?
  15. 07 Civic Sport 2.0L AC Compressor GUIDE?
  16. bilstein b14 shock on fa1 1.8
  17. Battery dissipates while car sits for week or more
  18. K24 12.5:1 cr in a k20z3 block
  19. Removing Delaminated Rear Tint
  20. New CV axles, calipers, rotors, pads
  21. Troubleshooting: Issues of the car staying running - 2010 CIVIC 1.8
  22. 2010 CIVIC 1.8
  23. new caliper/rotor/pads slight dragging
  24. 2015 Honda Civic shock absorbers
  25. 2014 civic ex AC noise in low
  26. Hondata FlashPro compatibility
  27. Hard downshift low speeds
  28. Car shows not ready for emission test
  29. 2007 CIVIC HYBRID
  30. Engine won’t hold idle and is running very rich
  31. 2013 Honda Civic keys stopped working
  32. 2007 Civic 1.8 ABS open circuit
  33. What brand caliper?
  34. Question about different types of spark plugs?
  35. key fob
  36. Sunroof Issues 2012 Civic SI
  37. having problem
  38. SRS Module
  39. CHSAS, VSA, TPMS, Power Steering lights came on after Clock Spring replacement
  40. civic 1.8L EXS 2012, need engine wiring digram electrical
  41. Soft Brake, overflowing MC
  42. Solenoid-only starter fix for AT?
  43. 2009 honda civic rpm changes up and down, only when cold
  44. 2013 Honda Civic Maintenance
  45. Electrical issue need your help
  46. Missing fuse box cover
  47. 2007 Honda Civic Hybrid Offered in Trade
  48. Honda Civic 2006 steering wheel issue
  49. Honda Civic Si 2008 O2 Sensor location.
  50. Stripped screw in fuse box
  51. Delay start on 09 Honda Civic
  52. 1st gear grinding problem from nuetral
  53. Is this a genuine Mugen Civic Si?
  54. Japan vs US parts
  55. Circle Piece on transmission
  56. CV Axle aftermarket brands
  57. 2016 Honda Civic 2.0l harmonic balancer
  58. 2006 accord idling issues
  59. Spark plug tightening torque?
  60. Map Sensor
  61. key stuck in ignition
  62. What it is making that steering noise?
  63. B pillar trim
  64. misfire in heavy rain
  65. How the heck would I fix this? 🤔
  66. Power wires through firewall
  67. civic 2012 - jump start wrong terminal - changed main fuse
  68. 2013 Civic inertia switch
  69. I need tips/tricks to remove a seized coil pack
  70. 2015 Sunroof Problem
  71. Premature brake pad wear?
  72. Seat belt chime stuck on 2007 Civic Si
  73. Engine VIN plate removed seller is being a dUck
  74. 2006 Honda civic hatchback acceleration problems
  75. tire wear "symptoms"
  76. Acceleration hesitation on 2nd or 3rd gear
  77. 2007 Civic hybrid not accelerating
  78. Cruise control installation civic 2014 in non oriel prosmatec
  79. Broken Exhaust Pipe
  80. 2007 Civic - Aux button not working
  81. Navigation bypass
  82. 2012 Hybrid Civic?
  83. Left blink fast - no clicking
  84. Power steering
  85. Electrical Issues
  86. 2008 Civic Crank no Start
  87. clutch hydraulics
  88. 2009 Civic Type S - Dash cluster issue
  89. A/C Intermittent Cooling
  90. Honda Civic 2012 Reverse light bulb change
  91. K20 swap
  92. 2006 Starter Install issue
  93. A/C compressor change
  94. A/C Repair or no repair
  95. Can you put a 2009 Civic Hybrid Battery in a 2008?
  96. Rattling noise while driving, Happens in all gears except Neutral.
  97. A/C Clutch not spinning
  98. For Those Struggling With Weak Summer A/C Performance
  99. 2007 Honda Civic LX Sedan 1.8L engine
  100. Civic 2013Check brake, power steering, VSA, ABS
  101. 2008 ac help
  102. Stolen key
  103. Help, what version of K24 !
  104. 2007 Honda Civic LX 4 Door Sedan - 1.8L engine - Broken alternator cable
  105. Leak... passenger cv axle joint
  106. Flasher relay
  107. ACG 15 A fuse blowing
  108. 2009 civic SI air conditioning
  109. Infotainment boot loop
  110. 2013 Honda Civic 2 Door SRS Code 11-11
  111. 2007 Civic LX 1.8L Transmission Speed Sensor Location?
  112. Car won’t start after SRI install
  113. Paint to match Atomic Blue?
  114. Car won’t shut off intermittently
  115. '09 AC clutch relay keeps blowing - common causes?
  116. Radio/speakers quit working? HELP
  117. steering wheel wiring diagrams
  118. car battery dead not keyless entry won't let me in car nor will the key inside
  119. SOS
  120. Brake Drum Problems After Rebuild
  121. Mechanic found several codes....
  122. 2007 civic D and engine light is on
  123. Accessory Power Fuse - CONSOLE COMPARTMENT
  124. 2010 Civic AC issue
  125. need answers
  126. Difficult no start 07 civic ex
  127. Seat fitment
  128. 2015 Civic LX acceleration problem
  129. R18 theoretical ECU swap
  130. Weird ghost noise comes and goes
  131. To Ethanol or Not? Female here; have patience please
  132. Bucking when accelerator pedal is lightly pressed
  133. Help me honda civic 1.8 p2647 code eror(only scaner)
  134. Hond Civic dtc error - help
  135. Speedometer/ dash / ABS lights/ ac issue.
  136. R18 and GSR trans
  137. Replacement Catalytic Converter
  138. Intermittent No-start. Starter Spins
  139. Bad Competition Clutch? Stage 4 6-Puck
  140. Troubleshooting: unknown noise coming from possibly brake caliper area
  141. About rear brakes and drums?
  142. Driver's Side mirror replacement
  143. Key stuck, also stuck in park
  144. Hood Cable came off
  145. 2006 Civic EX Coupe 5 Speed Hard Shifting
  146. What intake would be the best for my 2011 Honda Civic EX Sedan??
  147. **08 CIVIC HYBRID FACTORY NAVI**
  148. Spark plug gap size
  149. 07 civic ex LIMP MODE
  150. Transmission Bolt - Missing bolt on transmission
  151. ECT "unplugged" turns both fans on '07 1.8L
  152. DRL lightbar replacement
  153. Popping Noise??
  154. 2007 Civic Oil leak from left and right corner of exhaust manifold.
  155. Civic ex 2014 Android Bluetooth pair???
  156. ignition keys won't turn
  157. Replace timing chain or not?
  158. 2006 Civic Transmission Issue
  159. Exhaust Question
  160. Should I buy a Honda Civic 2014 lx or Honda accord 2014 lx
  161. Is there a radio harness out there??
  162. Plastics for 2015 Civic Coupe EX
  163. 8th Gen Si - Mainteneance items query
  164. 07 civic
  165. Why does my 2007 Honda Civic Coupe rev at 5 mph when slowing down?
  166. CV Axle Removal Problem
  167. Clunk & rattle after rear shock install
  168. Civic SI ticking noise
  169. Best model, year to buy for cheap beater
  170. KYB Strut Assembly HELP
  171. AC Compressor
  172. Civic 2007 LX new key
  173. automstic drain and fill
  174. Doors unlock when walking near passenger side
  175. No wipers
  176. Acceleration shuddering, loss of power.
  177. Suspension Fitment
  178. Best aftermarket brand coil strut assembly 2007 civic
  179. power steering bleeding problem
  180. Weird noise
  181. Ambient air temperature sensor ?
  182. Replacing Car Battery - Viper Alarm Question
  183. Crimestopper Remote Start 2011 Civic Auto
  184. Whining noise that gets louder with higher RPM
  185. 2007 civic dx transmission rebuild
  186. 2012- 2015 trunk lids
  187. Creaking & Popping Noise
  188. 2013 civic si coupe side curtan driver airbag replacement
  189. 2007 Civic EX - Rear control arm replacement
  190. 2012 Civic tachometer wiring info needed
  191. 97 civic ex pic valve snapped off!!
  192. How often do you change your oil? 2013 Honda Civic
  193. Low gas mileage 2015 civic CVT transmission
  194. Maintenance minder repeated alerts
  195. 2011 Civic Si Headliner
  196. Issue after oil change and tire rotation
  197. Burning Oil??
  198. 2009 Honda Civic EX Coupe sound system
  199. 2006 Civic wipers come on when headlights or RT turn signal is on
  200. 2012 Honda Civic DX - No Voltage to L/R Brake Lights (not a bulb issue)
  201. 2013 Civic EX Sedan - Tranmission (?) Issue: Lack of Acceleration/Downshifting
  202. Troubleshooting: 2006 Honda Civic - immobilizer issue
  203. 2008 Honda Civic DX-G Right Rear clunking noise.
  204. 2014 Civic Interior Lighting Upgrades
  205. Need help please
  206. 2013 Honda Civic 5 Speed
  207. New Boots on Old Axles?
  208. First Problem with my Honda..
  209. 2006 R18 decided to start cracking
  210. DO 11' CIVIC EX SEDANS HAVE A K-SERIES?
  211. Recommendation
  212. Looking about buying '12-'13 Civic SI questions?
  213. Surging below 1700
  214. 2012 civic navigation replacement
  215. 06 Honda Civic weird cabin noise
  216. Looking for thoughts/opinions on possible CSX swap
  217. Skunk2 Muffler popping?
  218. Looking for good aftermarket engine mounts
  219. Rubber Seal Coming out of Windows/Windshield
  220. Control Arm question
  221. DRL Warning Indicator
  222. Honda civic 2011 Trunk latch sensor works wrong way
  223. 2006 Civic EX Coupe - left mirror glass replacing
  224. Car engine making "whining sound" sound when revving down
  225. 2007 FD2R Civic Type R will thicker rotor fit?
  226. Right Blinker not indicating on Dash - 06 Civic
  227. 2014 Civic lx crank no start after sudden death
  228. Lady with questions- bear with me. Cracked Block on 08
  229. Anyone on here with boosted 9th SI???
  230. VIN decoder for a 2007 Honda Civic EX?
  231. SMOG Readiness not complete.
  232. Need help please...
  233. over heat
  234. 9th Gen. Civic Sun Visor
  235. Hit Curb at about 25-30mph
  236. brake beep & light
  237. Cracks but won't start after clutch replacement
  238. ECU compatibility
  239. civic mk8 2010 blown back up fuse
  240. 2010 Si - ECU Tunable?
  241. 8th gen Civic (non Si) starter tutorial
  242. Trouble with steering
  243. No lights on dash nor ac after wires touch
  244. Multiple Sensor Issues
  245. civic sedan different from civic si sedan?
  246. Rear Control Arms
  247. rear seat belt
  248. 2009 Civic Hybrid 1.3 AC Bypass belt??
  249. What is this line and where can I get one.
  250. Honda civic no start after auto to manual SAP 2007
