Honda Civic 06 Condenser fan and AC clutch wont engage
I have a honda civic 06 EX, the first problem was that the fans would turn on when AC was off. So, I took off the AC compressor Clutch relay and the fans turned off. But, now when I put the relay back into its spot, the AC clutch and the condenser wont turn on at all. Now, the ac clutch will only turn on if I jump it and the condenser fan will only turn on if I jump the condenser fan relay. I thought it was the ac pressure switch and I changed but it still the same. When I jump the ac clutch relay, the motor loses power and the car will turn off. What is the problem?
Re: Honda Civic 06 Condenser fan and AC clutch wont engage
textbook Omron relay failure
https://www.rockauto.com/en/catalog/...sor+relay,3180
you need the Mitsuba relay and you'll be good to go
jhiz
06-22-2004 08:37 AM
