PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Blown Amp? 2008 Si SDN
  2. Tie rod time, need advice (08 si sedan)
  3. Purchasing a CIVIC
  4. Need advice for parts both internally and externally
  5. 2010 Civic LX Auto, Right Front Clunk over heavy bumps
  6. 2010 Civic LX A/T trany
  7. Fiji Blue: Fading Paint Issues
  8. Great Car so far!
  9. No Start...Intake Explosion
  10. Bumper Detached, will this cost a lot to fix?
  11. Cold Air Intake Install
  12. r18a turbo list parts
  13. Will these fit wheels fit on a FA5?!
  14. 12 Civic LX Ping noise
  15. '07 Si - Failed strut bearing
  16. Tire Help Please
  17. Type of auto tranny fluid for 2011 civic
  18. P0219 Over Rev Code
  19. from Bahamas needs radio code
  20. Certified Pre Owned Doesn't Mean What Honda Claims It Means
  21. 2007 Honda Civic DXG coupe MT problems
  22. Brake Clunk
  23. 2008 civic si trans noise
  24. <<<ALL Radio Code Inquires>>>
  25. 2006 Honda civic radio/stock amp question
  26. 2006 Civic: Manual VS Automatic (lower gear ratios?!?)
  27. Autel OBD II doest not fit Civic/06 port
  28. Navi help
  29. Backup Camera for '11 Civic?
  30. power windows not working
  31. Keyless receiver
  32. caliper slide pins
  33. Civic headlights
  34. Galaxy Grey Wheel Color?
  35. 2008 rear compatible
  36. On the fence. 06-07 Si or G35?
  37. civic lx versus civic si
  38. $$$ Official Jan-Mar 2013 WTB/WTT/FS Thread $$$
  39. '06 Civic Blend Door is jammed?
  40. usb cable in center console pairing with droid?
  41. Pass code
  42. Stereo pass code
  43. Choice between '06 RSX Type-S or '07 Civic SI
  44. Mods and Oem Parts
  45. Where can I find tachometer wire?
  46. Owner's Manual - 07 Civic EX Sedan
  47. 2008 Honda Civic won't build rpm's
  48. 2008 Civic Si Coupe Performance Exhaust
  49. P0301 now wont start?
  50. Skunk2 Cold Air Intake
  51. Noise from from left wheels ... not back rotor plate, like a spring?
  52. CIVIC 2006 SRS light on
  53. New Civic Accessories?
  54. Climate control lights are out! HELP
  55. 2006 Civic LX a/c turns on for only 15 seconds.
  56. S2CarbonWorks Review - Civic Heatshield Nice! Helpful
  57. Driver side Power Window Issues
  58. 08 Civic SI electrical problems?
  59. 5W20 vs 0W20
  60. 2012 Ex intake?
  61. what year is this si?
  62. USDM Type R and Mugen RR Front Bumpers?
  63. Honda Civic automatic gearbox at rest
  64. Pass emissions without cat?
  65. Difference in headroom between 06-11 Si coupe and sedan?
  66. How to get my civic si 2006 to have deeper exhaust
  67. Is there a difference between ex and si steering wheel?
  68. coolant mixture question
  69. Tuning thru OBD port
  70. Buy or Pass...Real Owner Feedback...
  71. 2013 HONDA CIVIC
  72. 2008 honda civic lx coupe need new bumper?
  73. Restoring Si Badges
  74. 09 Si: EPS Malfunction???
  75. how do i lower my si 07 sedan?
  76. Brake pads compatibility with my civic si 06
  77. Wanting to convert my 07 Fa5 for a 09-11 Frot Bumper and Grill
  78. Poor throttle response... 2011 Civic w/ R18
  79. Will the Sunroof from a 2009 Honda Accord Coupe Fit my 2006 Civic SI
  80. Honda Civic 2.2 diesel
  81. Too many electronics?
  82. s2000 steering wheel?
  83. HID setup suggestions for '08 Civic EX?
  84. Boomba mounts or Power Stick?
  85. 2008 EX Left Front Ticking Engine Off
  86. How much is a 2010 FA5 front end worth?
  87. Luck with coilovers
  88. VSA lights
  89. recalibrating throttle position sensor
  90. Any perfect fit lip for HFP Civic Front end
  91. upgrading 2012 civic audio system while keeping stock head unit?
  92. Suspension set up?
  93. 2006 Civic Keyless Entry Range Very Low
  94. Swap Question
  95. 16 inch tire size on 2007 civic
  96. Can I sell car here?
  97. SO my 08 fa5 ia consuming oil
  98. skunk2 o megan racing headers??
  99. Noise coming from front springs
  100. 2011 Honda Civic-fuse question
  101. I drove my 2007 EX without any oil for several hundred miles
  102. ebay hfp style polyurethane lip kit
  103. Bit the Honda bug and finally bought an SI :)
  104. anyone know what kit this is si 4 door
  105. Buying 2006 Si
  106. URGENT HELP NEEDED - Locked out 2012 Honda Civic
  107. 2012 civic coupe si
  108. Radio display issues
  109. If anyone is interested in 2007 Civic Si 4 door with a JDM Conversion
  110. emission light
  111. 07 Sedan EX - Eibach Lowering Springs
  112. exhaust picture request
  113. New Clutch Ideas...
  114. 07 si on 16's
  115. FA5 to FD2 Conversion Inquiry
  116. 09 Civic Hybrid Rear Brakes Dragging Intermittantly.
  117. FA5 TSB or something else?
  118. 2006 Honda Civic MPG
  119. Timing belt change for 2008 Civic?
  120. 2008 Civic door locks jammed
  121. Gf's car is poo
  122. 07 Civic Sedan - Stalling and Shutting off
  123. 2011 Si Shock problem
  124. Buying an '09 LX-SR--have only seen love for the Si here!
  125. 08 si dd mod list. Thoughts?
  126. $$$ Official OCTOBER-DECEMBER 2012 WTB/WTT/FS Thread $$$
  127. Replacing O Ring on pipe coming out of water pump
  128. brakes
  129. Radio Problems - Please HELP
  130. I need help for radio code civic 2006
  131. Drivers window not working
  132. 2oo8 Honda Civic DX steel rim size.
  133. clutch sinks in at high revs
  134. changing to neutral
  135. 8th gen Si paint warranty extension
  136. blinking check engine
  137. over heating
  138. My First Civic...
  139. Costco won't install Michelin Defender on my civic dx-g
  140. Noise from Torque Converter / Flexplate area
  141. 06 Civic EX 4Dr Shaking up and down Front Right Suspension Strut! New Strut No Change
  142. Misfire after weapon R intake instal 08 si
  143. Need opinions on my first vid guys!
  144. vaccuum explanation
  145. Just bought a civic si 06 hfp. Rev hang ):
  146. Suspension and wheel setups.
  147. 2007 civic si engine dont go over 3000rpm!
  148. Rotors FYI
  149. Skunk2 alpha question
  150. Leather Seats
  151. new car coming thursday
  152. Used Honda Accord, or Honda Civic?
  153. coilovers
  154. Wow!!!
  155. "using" coolant
  156. Just looking for suggestions
  157. Shaking / bumpy passenger side tire
  158. Time For New Stopping Power!
  159. Hitch Install (Curt) On My 08
  160. EX vs DX/LX SEDAN SPRING RATES? Different part numbers
  161. Looking for these fog lights. Help
  162. Fitment of RR Replica S/S
  163. 2012 civic sedan bumper
  164. Some Kraftwerks Supercharger Builds @ Import DPS
  165. indicators after jump starting
  166. 05 civic tranny vs 2012/2013 civic tranny
  167. 8th generation rear lip spoiler template
  168. Swapping tires okay?
  169. Work in Progress. 2010 FA1
  170. 2007 Honda Civic EX - A/C troubles
  171. 09 si grill question
  172. 2007 civic - How to remove wiper blades?
  173. code A 13
  174. Skunk 2 alpha to stock exhaust ?
  175. Question on brake bleeding and caliper replacement necessity
  176. 2012 civic coilover question
  177. New owner of a 2007 Dx
  178. guys i just bought a 2012 yesterday
  179. HELP ME CHOOSE THE BEST COLD AIR INTAKE FOR 2012 SI
  180. Fuel delivery
  181. Need some help with my '97 coupe
  182. Suggestions for coilovers!
  183. Suggestions for coilovers!
  184. OE or AM rack and pinion
  185. Volk Racing TE37TT Progressive Model Sneak Peak!
  186. 2007 SI- Headlight Issue
  187. 2008 civic front end damage...how to fix
  188. swap motor and cluster...?
  189. Coolant leak
  190. gas mileage issues
  191. Skunk2 new CAI
  192. Looking for Si parts for 2010 civic.
  193. check engine light
  194. 2006 civic lx
  195. 06 Si Starter?
  196. 06 civic si excessive fuel consumption
  197. Posted my car for sale, if anyone is looking for a 07 FA5
  198. Auto door lock in 2010 Si?
  199. failing A/C unit
  200. 2007 ex coupe exhaust repair
  201. K24 potential?!
  202. 06 civic wheels
  203. dbw
  204. 2008 Civic EX-L Randomly Beeps Once
  205. starter problem - honda civic 2007 1.8 liter AT sedan
  206. PARTS FOR 2010 CIVIC SEDAN
  207. 2007 Honda Civic Si Sedan Bump Stop?
  208. Fiji Blue 8th Gen
  209. 09 Fg2 help
  210. 2007 Honda Civic EX Turbo?
  211. 06 si clunking
  212. Just bought 07 Civic Si sedan
  213. Horn and Lock Beep Issues
  214. 2006 Civic Odd AC Problem
  215. Any yall runnin Autozone brake pads?
  216. 07 Civic Hybrid wouldn't startup after AutoStop
  217. 06 civic fan onall the time
  218. Evasive FA5 Civic Si
  219. 2006 LX Dash
  220. Model Differences
  221. Is this 2006 Honda Civic EX Coupe worth the value?
  222. battery/notification light question
  223. newbie- Just purchased
  224. Jet Chips ECU
  225. 09 Si, Header question
  226. Some one please help turboing my 2007 civic si
  227. 2007 FD2 conversion
  228. Fender Help Please
  229. Anyone pay out-of-pocket for a 3rd gear repair?
  230. New/Used 2010 Civic Si clutch issues
  231. 2006 Civic Si Sedan foglights WANTED
  232. F/s CIVIC SI ALL MATS
  233. 5 SPD to automatic conversion
  234. Change greeting
  235. Parts for 2011 Si Sedan!! (For Looks!)
  236. 2011 Civic with brake issue (?)
  237. 07 FA5 vs 09+ FA5 rear upper control arms?
  238. 07 civic si sedan un even rear tire wear
  239. Front camber!
  240. Should I? 2006 Civic Si
  241. ECM Replace Honda Civic 2007 FD4
  242. 2006 Civic LX A/C Issue
  243. Heavy Vibration in engine, struggling rpms when accelerate
  244. 8th gen seat fabric..
  245. Need suggetions for wheels!!!!!!!
  246. A/F RATIO SENSOR AND SUB-HARNESS TSB PROBLEM
  247. Air Conditioning sometimes work sometimes does not
  248. A/c problems 06 civic
  249. Si or EX
  250. 07 Si Crank Pulley Wobbling
