- HELP! No tail, brake lights/No power to under dash Fuse box!!
- Electric Power Steering Failure 2012 Civic
- 9th Civic Si - k24 problem areas?
- 2006 civic dead battery
- Does 9th gen Si still burn oil?
- 2012 Civic Head Rest/Restraint
- 2006 Civic Radio works but no sound
- Dim headlights on 2013 civic
- My 2012 si
- Rich smell from exhaust and decreased MPG
- Key
- Steering Rack knock
- Faint fuel smell through the vents
- Need to remove the door trim to fix the door lock
- K series transmissions.
- OEM Nose Mask -Warning Fitment Issues
- 2011 Civic EX Coupe electrical ghosts.
- 2008 Honda Civic Ex-L flickering aux power
- AUX Cord in 2007 Honda Accord Question!
- Oil Adapter Sandwich
- Rear wheel bearings
- 2007 Civic ex sunroof
- 2009 Civic Cruise Control problem
- transmission sounds and jerking
- 08 EX Civic Coupe Drivers side replacement mirror question
- 2016 Civic Debut
- Unsupported USB drive
- ATTENTION weathertech window visor owners! (si sedan specific)
- 2013 Civic Si - Driving with Traction Control?
- Annoying rubbery type squeak
- Front right end Rattle Diagnosis
- Fn2 workshop website, missing.
- 5th gear too soft or I miss it completely
- 2008 Civic Air conditioning Problems:blowing cold(frigid) and cool and warm air
- 2011 honda civic lx automatic looking into swap.
- 2007 Honda Civic Hybrid, IMA has gone bad, and regular battery keeps dying
- 2006 Civic Hybrid Electrical Problems
- Transmission solenoid issue
- 101000 miles on brakes...
- 2009 r18 engine compatibility question
- cluster si in dx
- 2008 civic si speedometer only reads 0 ????????
- 2012 civic si coupe
- cleaning A/C filter, what the heck is this?
- 2006 Civic EX Issues
- Honda Civic 2006 ignition cylinder
- Honda Civic EX injecters
- Tune specific octane rating
- 2014 Si Lane Watch Delay
- radios anti theft.
- 08 Si engine swap?
- Just had new honda clutch installed...
- 2015 civic SI, wheel/tire question
- Is it my Alternator???? SO CONFUSED...
- 2008 civic si
- Mugen GPs fit a 9th gen?
- 3 Oem Thermostats which one should I use
- Photo shop help!!!
- Hit a curb, car won't start
- Civic 2008 DX/EX Strut compatability
- Lightweight flywheel - Fidanza?
- 2016 Civic interior/exterior/underside - pics & vid
- 2007 civic - Ecu does not support mode $06
- 2009 Civic in limp mode - error codes
- 2006 EX clutch bleed issues
- Steering feels super-light after wheel alignment
- 2006 Honda civic ex rear control arm design!
- Thermostat Service
- Torque Specs for r&r starter and exhaust 09 honda civic
- underbody panel
- Setting up anti lag
- oil burning in 2012 civic si
- Need a little advice.
- FA5 - FD2 conversion PasswordJDM /ZESTJDM
- Civic 2010 Turn Signal Location
- Wheel hub and bearing replacement.
- need carfax report on 2006 civic
- Cracked Engine Block Resolution (06 4d EX)
- 2006 Honda Civic Si Emergency Trunk Latch Fails!
- 2015 honda civic full coilover suggestions needed
- Please Advise on A/C Issue!
- Clutch and/or engine acting wierd
- 2015 Si HDMI port/MHL adapter and Galaxy S6 HELP
- Broken trunk torsion bar in 07 Civic
- 06 MT Transmission housing stuck
- a/c compressor pulley making noise
- Are my coils fried?
- Replacing ignition coils in '12 Civic
- Which aftermarket rear UPA for Si?
- Aftermarket seats???
- 2006 Civic Sedan - AC pumping using defrost
- No start after power probing a/c switch....
- 2007 Honda Civic Si- Dead-end hose from crankcase breather?
- next gen 2016 Civic interior loses tiered design
- New here, First Honda
- Manual Transmission for Civic '06
- Alternator or Battery Issues (07 Civic LX)
- Rear Caliper Seized?
- I have no idea what is wrong with my civic- BY FAR THE WEIRDEST CAR PROBLEM EVER
- 2015 si coupe
- Survey for Syvecs ltd about plug and play FN2/FD2 ecu
- RickSpecd 8thGen Kraftwerks Powered Civic Si - A Must See!!
- Honda won't start ;(
- front brake pins 4dr EX 2009 civic
- 2013 Civic driver's side mirror light lens crack = $650 fix?
- How to identify 8th gen HFP suspension?
- Canadian Civic SE, timing chain?
- 2010 Si coupe head gasket, drop the motor?
- 2012 Civic sdn Dash rattle
- A/C Cutting off (thermal switch?)
- Turbocharged 480HP FG1
- FD1 vs FD2 vs FD2R Chassis
- I am writing from Argentina, Buenos Aires
- Reset Error Code
- Power outlet fuse
- Possible Clutch and/or Tranny issue? Hard to put into 1-6, but easy to reverse.
- 2008 si sedan
- Disable seatbelt chime/notification 2014 Civic SI
- 2009 Civic EX - Doesn't start right up... Sometimes.
- Civic 2009 LX
- HFP slotted brake rotors
- 2016 Civic hatchback?
- Honda Civic 2009 cracked frame
- 2011 si rotational squeak help!
- 2008 Civic LX won't start
- Do 'newer" Civics have cableless throttles..
- 2007 civic engine replacement
- retrieving radio code
- Gauge pods
- New to Honda-tech, A quick hello
- Does Seafoam Actually work? (with PROOF)
- 2008 SI Fog light help!!
- Sticky Dash Issue - 2009 Civic
- Tires on 2008 Honda civic dx
- Weird Electrical Problem
- a/c blows warm
- fuel presure question?
- 2006 Honda Civic
- BRAKE Warning Light And Beeping HELP!!
- 2011 Civic Lx Hesitation between 15 and 20 mph
- 2017-2018 Type R Coupe Concept
- engine hoist point
- K&N Typhoon SRI not Beneficial/tuning question.
- need guidance on vibration/noise problem 2012 Civic EX
- Blown head gasket
- Production 2016 Civic coupe prototype spied in dessert
- Replacing clutch on Si
- 06 Civic EX Not Starting - Any Suggestions
- bleeder valve questions
- 2008 Civic EX-L sunroof
- Need measurements of trunk
- Looking for decent power lock/keyless entry set for 2010 Civic dx
- spoiler question
- Electrical gremlin 06 civic ex
- Need help figuring out my hp?
- Need some of you guys expertise.
- 2008 Civic EX no AC, no leaks.
- Guys I need help :(
- 2016 Civic Concept Pics
- Hondata tuning?
- Think I might need a new tranny
- 2009 honda civic DX-G Interior Light Issue
- HELP PLS, looking to make my civic sexy, noob at cars
- oil reset
- 2014 or 2015 Honda Civic Si Sedan??
- Airbag failure?
- 2006 civic lx engine replacement
- edge of rotor not making contact w/ pad
- 07 Si pampering
- Guys help! 2007 Civic!
- motherf!@#in 3rd gear!!!
- my new 2015 si
- looking for owner of my 2012 si NJ
- 07 Si Aux/XM button does nothing
- 2013 Si Accident
- 2007 Civic LX
- Looking for Stock 07 Honda Civic Si Wheels around St. Louis
- Should I get a steering wheel cover right off the bat to protect it?
- Will theses floor mats fit my Civic
- Gauging interest in FG2 civic coupe Carbon Fiber front lip
- Honda civic 8th Gen or 9th Gen.
- I just want to stream audio from my android smartphone in my new Civic EX
- How are you guys dealing with cloudy peeling plastic headlights?
- $$$OFFICIAL SUMMER FS/WTB/WTT Thread $$$
- Lateral Axle Play .. Normal ?
- Which of the Si's is a better deal?
- 2010 civic abs always engages
- 2006 Civic Hybrid - Where is mileage stored?
- Just picked up an 07 Si...
- 2009 Honda Civic problems
- need help tracking down a header
- Clutch components
- honda civic rookie
- Buying a 2007 Civic EX Coupe With 95K Good?
- Noise after clutch install.
- what oil to use for 09 si sedan
- 2006 Civic/Acura CSX Issue
- NEED HELP! 07 Si Wheel Bearing replacement
- 09 Si Issue
- 2013 Civic Hybrid
- Replace digital gauges with analog?
- Autoshift transmissions?
- Exedy clutch with stock flywheel question
- gauge cluster
- vacuum/boost signal 08 si
- Need Service Manual 2006 SI.
- low idle
- Steering feels loose even tho mechanic says it's fine
- 2015 Honda Civic Se
- NEED HELP! Borken Part While Scrapping
- 2012 Civic Si with P145C Code
- [2012 Hybrid] steering wheel audio controls not working properly
- 2014 civic lx brake problems and rev issue.
- I need help finding out( headers)
- 2007 1.8 starter
- Brake problems possibly abs
- Unsure
- Help please. Just got my new 2015 Civic EX Coupe. Break in questions/concerns
- 2013 Civic Coupe LX OEM Spring rates?
- 2008 Civic DX 17 inch rimes
- need help..shaking steering wheel
- Fuel gauge gone mad
- Energy Suspension Control Arm Bushings
- HELP! Stainless Steel Brake Lines on 2013 Civic LX Coupe?
- HID upgrade for 2008 Civic
- 9th gen rev hang
- Probably another clutch system question
- Honda si
- civic 2010 led connector help
- help help !Turn signals come up when braking
- Bad Acceleration and Steering After Hitting Potholes
- Help plz 07 civic electrical
- 2009 Civic Monitor Catalyst & Monitor EVAP Not Ready
- 2006 Civic Si Coupe brake light and horn issue
- Question about stock resonator on 06 1.8l sedan
- I need a wiring pin up diagram for my alternator asap (Honda Civic 2006 1.8 EX)
- Missing seat plastic piece
- 2011 civic si spoiler
- "PLEASE HELP"Deformed cowl? Include pics
- Flash Pro vs Any other ECU 9th Gen
- 17" Tires
- 2006 HC alarm not woking & MIL on
- Civic Hybrid, reversed polarity at jumpstart
- pinout cluster honda civic type s
- software update
- 13 Civic air bag light
- FD2 OEM Wing?
- turbo my 06 civic ex??
- 9th Gen civic sedans Lets see those Wheels !!!!
- Civic?
