- 2008 manual Civic sedan knocking noise when moving
- 09 civic si hi-beam issue
- K pro Flash pro is there a difference? if so what ?
- Intake Fitment
- Replacing 2006 Cruise Control Switch
- A/C Issue Civic SI 08
- Installing aftermarket fuel pressure regulator
- New member with 9thgen civic
- Bad gas mileage; 08 civic Si
- Drag radial recommendations???
- Fog Lights on 09 LX
- 2012 civic or 2011
- 2008 civic si wheel value question
- 2010 Honda Civic EX front brake pad interchangeability
- So my battery died the other day but
- Where to get pre-painted body parts for FG2 Habi Red coupe
- 06 Si Cobb
- K20Z3 Intakes
- FA5 Track Experiences
- brake pedal and steering wheel shake
- 2007 Civic Hybrid Rattle
- Work Emotion CR Kai and TPMS
- 08 Civic sedan, need suggestions 4 more power!!
- New to the Tech but i got questions if u got suggestions
- Blue smoke from exhaust after replacin valve cover!!!
- Mugen Civic Turbo! - Videos inside
- Honda Civic buying advice help! best bang for the buck!
- Problem with my 08 si
- Aem SRI heat soak?
- 2009 champ white
- question about body work
- Delete
- Cam Retainer bolt stuck into the head!!!
- Torque Spec For Rear Shocks...
- my 07 si setup
- Hybrid Racing Civic Master Cylinder Upgrade
- Returning H-T Member.
- Full-Race 3" exhaust 06 SI
- Civic SI ´07 aceleration issue/hiccup
- 2006-2008 Civic suggestions
- 2009 civic si vs. crv turbo
- Import DPS / 4130 Fabrications / RSTech - George's 2007 Full-Race Si 422HP!!
- 2006 honda civic a/c question
- A/C clutch or pressure relief valve
- 2007 Honda Civic Alarm problem
- Getting My First Car
- key dilemma
- Blown Engine? Please help!
- Buying Advice
- slow 06 si
- My 2009 FA5 dyno tuned! Dyno sheets inside!
- Bulb model for halo projector headlights
- OEM Tires: trashed at 27k. Advice on replacements?
- 2008 Si remote keyless entry issues
- Pic request: Si's on Sawblades
- Help Odometer jumping (p0720)
- Need to order some front pads for a 2012 Civic DX. Where did yall order your pads at?
- Vibration
- help with 2008 si 4 dr
- H&R OE lowering springs. Upside down?
- Tune up and headlights
- passenger side window switch
- 2008 Civic A/C issues
- Thinking spun bearing?
- battery issues (slow start)
- New member New CIVIC SI
- DEQ
- 06 civic si clutch
- New civic - poor handling? Tires?
- sway bar for 2012 civic lx?
- 2006 Civic Cyl 1 Mis fire- ALL 4 white tips
- 06 + civic sedan mpg
- What to look for....
- Passwordjdm power chamber intake ?
- So there is no Interior Sub-section on H-T...
- Trying to find Si owner
- 95 LX won't turn over after disconnecting negative cable...
- high performance clutch
- Exhaust choice 08 si
- my new 2012 si.
- My pre turbo build
- 09+ Si Short Throw?
- CASTER PULLING RIGHT..COMMON ISSUES?
- $$$ Official September 2012 WTB/WTT/FS Thread $$$
- spark plugs?
- need info
- F&F Type 2 Coilovers
- Greddy turbo kit
- 11" wilwood BBK
- Where can I find OEM 2012 Civic EX parts?
- EX w/ ABS vs DS front hubs
- 8th gen camber kit
- FA5 Stock Navi Looking to get aftermarket system
- R18 replacement Ideas
- Intake suggestions
- any way to add a spoiler?
- Horn not working
- New and Got my First Honda (Civic LX)
- Suggestions for my 2011 Civic Lx Coupe
- AC inspection and car detailing
- Camber kit
- lowering spring help
- Emissions
- 09 Civic, loud screech when in reverse (automatic).
- 08 si o2 signal stuck lean help!
- removing quarter panel taillight
- My new addition
- PC Card Adapter Assistance....
- 08 SI
- 2007 civic clicking noise when pressing clutch
- 2007 Civic EX exhaust system
- Just got Tein springs,
- Rough Idle after driving around ... thoughts?
- My Civic SI
- Type r rear end on a 08 si 4 door
- A/C Compressor Clutch Engaged All The Time??? HELP!
- EK gauge cluster not working
- Help: 2006 USDM SI all chassis Bushing replacement
- Just bought a 08 SI
- 09 civic si turbo or super charge????
- 2 questions
- 08 SI Sedan Roof Rack ?
- just wondering
- great luck
- Extended Lugs on oem wheels???
- Woosh sound when shifting
- Help need advice
- Does this sound like a good buy? (2007 Ex)
- 2012 dx rimmed up and slammed
- Civic Si OBX Catback
- Coolant question
- Wrecked my 8th Gen SI. Does this look like a bent tie rod?
- Hard Parked FA5 FD1 | FD2 | Work
- Rubbing noise at low rpm in first gear.
- New member TW Fa5
- DC5r Brembo's on 2012 civic Si, Searched and can't find a definite answer.
- fa5, opinions on powdercoating?
- 2007 Civic Auto Tranny Issues! its not even thai!
- 06 civic si Dc header CEL
- Civic 06 Radio code
- PANIC:2011 Honda Civic with 1000 miles won't go
- oil change intervals
- 07 Civic Si Sedan...? 16" Acura RSX wheels
- Lockout on si to prevent shifting from 5th into reverse?
- 10 Lx: Where is the fuse for the 12v acc port?
- '07 Si Retune
- wife need a new clutch 77k 08 fa5
- header gaskets and bolts?
- Power or Looks? Just a quick question..
- tuning question
- 06-11 Civic Si OBX header
- Painted my hood and spoiler black
- Window tints
- Honda Civic SI 2008 replace amp
- 08 trans
- If you came from an EP3, represent!
- Best SRI w/ Proven Dyno?
- 2008 honda civic si
- New 2011 Si
- Key fob silent operation, can't find help please!
- 08 Door Seals on Car (Not Door Itself)
- suspension
- 06 civic si Suspension question
- speaker question
- *HELP Needed 2006 Civic Si Oil Pan Removal *
- Hondata R18 Flashpro
- 07 si or 00 si
- Honda Civic Radio Code
- 2013 Civic Rumors
- Help me figure out this issue!! PLEASE?? (06 Civic EX)
- LOWERING MY SI 07
- JDM Type R tranny into '08 Si??
- 2007 Honda Civic (Basic) 4 door
- $$$ Official APRIL 2012 WTB/WTT/FS Thread $$$
- 2008 Civic EX 26k = new block
- After Civic Bruising,Honda Fights For Soul
- Lowering My 07 Civic Si
- 07' Civic SI-What type of gas?
- Injen SRI help
- New Guy
- How difficult is engine work on a '06+ Civic?
- camber kit help me please
- searching for a video
- Civic si 70mm skunk 2 question
- 07 Si brake swap ?
- NEED HELP!!!
- Hi. I'm new to the forums and need a lil help.
- 98 civic y8 head
- Newb with a 2006 SI
- 2008 Civic FM Radio Out/Defroster On
- 2012 Civic Questions
- Wife's 2006 Civic Front End Issue - Tech experts please help me diagnose.
- 06 civic si problem
- Rims for 2010 Civic
- HP gain needed...HELP?
- 2010 civic headlight adjustment
- 09 Civic Si Sedan help??
- Quick header question
- Bad day!
- Wrong Flash Pro!
- 2009 Civic Coupe how to fix clothes hanger clip
- 2009 Civic Coupe LX how to add factory navigation
- 2006 Civic FA
- junk k20z3 block
- Need some adivce on 07 Si going to look at in a hour
- GOT A Question
- New to hondatech
- Shortage of 2012 Si's
- 2012 Civic Insurance
- 06 civic si header problem
- K&N Typhoon Intake/Cold Air Intake questions
- Honda purchase
- 5-speed 1.8L LX/DX Sedan's...how well do they run?
- 08 civic si sedan seat belt locks
- 09 2dr si....lowering spring work instead of coilover kit???????
- Skunk2 Alpha header
- 07 sedan hfp front lip
- HID problem. High bream not working?
- Skunk2 short shifter adapter before & after pics
- Any boosted r18's here?
- 06-11 Si. Does it get stolen?
- Motor won't crank after putting new oil pan on?
- 2006 Honda Civic Coupe Sun Shade Repair
- 2010 Civic water temp sending unit debug
- Changing the Bluetooth Id
- Tire Advice for 2008 Honda Civic EX Sedan
- Rev Limit Change!!
- Intake Question
- How much nicer/better is an 06/07 than an 04/05?
- How much are they worth?
- Power steering pump whining after fluid change
- Civic 2006 - problem with master key and valet key
- I need to get approval from moderater
- Need help ASAP, gas ran out, now car wont start.
- 60k and price
- Car won't start, bad ecm/relay?
- 07 Si Turbo question
- 06 civic si hard to shift after warmed up
- 2010 Honda Civic runs cold in winter
- $$$ Official February 2012 WTB/WTT/FS Thread $$$
- Over Due Introduction
- 06 Civic EX Sedan- Left front clunk after power steering pump replacement
- Vibrant exhaust sticking out further when hot?
- 06 civic si turbo help
- Salvage title 07 si
- Trade 08 mugen si for 93 skyline
- Now to Honda and Honda-Tech
- EPS question
- 09 civic hybrid BUY or PASS
