must turn steering wheel to crank start 09 civic
I just put a new battery in my car and I am having trouble starting it. Had problems before replacing the battery as well. The car wont turn over unless I turn the steering wheel to the left what turning the key to crank it. Can anyone help me with this problem?
Re: must turn steering wheel to crank start 09 civic
It sounds like you might have a faulty ignition switch in your steering column. If the wheel needs to be cranked to the left on starting, it might mean that you have a broken wire in the ignition circuit that is making proper contact when the wheel turns left. The engine, once started, wouldn't need the circuit to be activated as the ignition doesn't engage after the engine is started.
Does the key turn before you turn the wheel some?
wwzjd
02-11-2015 09:00 PM
