PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Changing ATF
  2. Code P0865 Problem
  3. Free engine replacement for 2006-2009 Honda Civics
  4. Need help with wheel and tire setup!
  5. 2014 Civic LX for 18.9?
  6. 2013 civic SI transmission on eg?
  7. 09 Passenger Door Locks - Factory intent?
  8. Where's My 2006 Fuel Filter???
  9. EGR 99.2% Error
  10. b16 or b18?
  11. Torque steer = broken torque mount?
  12. CIVIC EX 2008 , AIRBAG CODE ERROR (A2-10) NEED HELP
  13. Aftermarket brake manufacturers
  14. 07 Coupe / Sedan Motor Mounts
  15. Honda Civic 2008 Sedan Lx
  16. Can you fit a k24 tranny on a k20 block
  17. Civic ride quality???
  18. 2012 wire harness
  19. 2014 Civic; Spin-on oil filter & Timing chain ?
  20. NEWBIE HELP WANTED
  21. shifter question
  22. parts help
  23. Question about specific Exedy clutch kit
  24. 2007 civic CV outer joint
  25. help
  26. Checking Automatic Transmission Fluid level.
  27. Honda Civic 2013 - Strange internal noises and rearview camera appears when braking
  28. Fg2 headlight lenses
  29. Water in gas tank! Please advise!
  30. dw-1 vs z-1
  31. 2009 Honda civic lx SRS Light
  32. fuel inertia switch rest help
  33. 07 Si harsh starts, odd noise
  34. Form and Function Type II Coilovers
  35. 09 honda civic si goes into gears but wont move.
  36. This is probably on here somewhere but...
  37. 2006 Honda Civic SI
  38. 2014 Honda Civic EX+ iOS in the Car
  39. Aftermarket Wheels!!
  40. Civic ex sedan shift knob change
  41. Normal retrofit, no bells or whistles.
  42. Evap Monitor readyness and ebay HDS
  43. Honda trying to sucker me?
  44. 5/6,000 rpms- vtec
  45. i-SHIFT Transmission control unit problem
  46. Inner fender removal
  47. A/C not cooling as it used to
  48. 2006-2008 Honda Civic HID headlights
  49. Muffler question for a 2013 lx sedan
  50. fa5 exhaust on a fg2
  51. warranty question please help
  52. Snowbank and now no gauges
  53. 2009 SI - clunky shifts
  54. 2007 civic Si whine noise
  55. Problems after battery change
  56. Don Nguyen | Gloss black vinyl roof wrap - Covered up damaged/faded paint
  57. Reoccurring problem with windshield cowling
  58. Question about shift knob
  59. New to tuning
  60. New to the game
  61. Portable or in-dash DVD GPS, which one is more suitable for Newbie?
  62. 06 HCH throwing OBDII codes P0301, P2801, C3104, P2055, C155
  63. wheel area squeeks
  64. K24 into 8th gen civic ?.
  65. Cracked Windshield/Wiper problems.... are they covered by warranty?
  66. Got over 500 miles on a tank of gas... is this normal?
  67. Front ABS Sensor Removal
  68. 2009 Honda Civic engine problems
  69. Tire Pressure 16" OEM vs 17" Replacements
  70. How to understand 8th gen civic si had turbo?
  71. Starting up Autocrossing
  72. 08 HCH Battery
  73. Driving related question...
  74. door issue 09 civic si sedan
  75. 2015 Civic Type R
  76. Tell me about the Si
  77. Anyone driven the 14 Si?
  78. Where to start
  79. what size wheels are you running on your 2013 lx sedan
  80. k24z7 crank pulley question
  81. Alignment on 16" vs 17" Wheels
  82. 2006; 200K Miles and Birthday Parts
  83. Code Scanner
  84. best cat back exhaust
  85. 2006-09 Engine blocks
  86. 2015 CTR Petition for USA
  87. 07 civic Si wont start
  88. 08 type s parasitic draw
  89. 08 civic "frozen"
  90. Problem with 2013 Honda Civic si
  91. Need help deciding
  92. Honda Civic HB 2014 with A/T
  93. Yea Buddy
  94. brakepad and strut replacement on the Hybrid, anything different from a "normal" car?
  95. 2006 Civic EX COUPE, FAIL...
  96. Stupid question??
  97. Am I being ripped-off?
  98. R18 TSB
  99. void warranty?
  100. looking to buy new DD (15k budget)
  101. 08 DX lock problems
  102. 2007 hch hybrid battery
  103. Several Rear Window Defrosters Blow Out Honda Windows in Dallas December Ice Storm
  104. Just replaced my clutch master cylinder and slave cylinder. Passing on some tips!
  105. Squeaking Noise
  106. Adding features to a DX
  107. 2007 hch timing belt-change?
  108. Yellow Fluid Leaking
  109. 2013 Civic LX Radio Static when Charging Cell
  110. K24Z7 Carbon Fiber/Kevlar Spark Plug Cover
  111. Who can Tell me what color it is and paint code?
  112. Shop says it's the HG
  113. Paper clip method for CEL codes, 2009 HCH
  114. 1 Tester Needed For A Free Ralco RZ Shifter for 2012+ Honda Civic Si
  115. wheel vibration with winter wheels only after going through deep snow
  116. Factory honda warranty?
  117. 2007 HCH battery trouble?
  118. Need Help! 06 Civic LX wont start. Ant-theft problem?
  119. Speaker Size
  120. Engine Warranty
  121. Value of a clipped Honda Civic EX w Navi 2006
  122. 06 civic si. CEL
  123. First new car - 2013 EX w/Navigation
  124. H&R springs on Si
  125. Just sold my 12' Si
  126. Power while ignition is off
  127. New vs Used
  128. Dashboard Indicator Lights -- What's Normal?
  129. airbag light
  130. Wierd chain-like noise when driving
  131. What to look out for when buying an 8th gen SI?
  132. 06 civic hybrid. Can I install an amp and sub with the factory navigation system
  133. 2008 Civic EX coupe leaking coolant
  134. 2007 Civic Si. Please read.
  135. front bucket seats
  136. Honda Civic 2006 LX - Starting Issue, Where is Starter Relay?
  137. Skunk 2 Cold Air Intake w/ pics ... Install and Hints !!!
  138. honda civic 2008 car vibrate at stops and CEL P0497
  139. Time and cost to replace all motor mounts?
  140. Wheel/Tire size question?
  141. Does ANYONE know what this sound is??!?!
  142. Not sure if part will fit my car need help!
  143. 2007 SI OEM Wheels or Upgrade?
  144. Advice needed on Honda Civic factory alignment specifications
  145. air climatiser hondacivic2002??
  146. 2014 Civic Si
  147. Civic SI dies suddenly while driving!!!
  148. Quick help please! 08' civic Question!
  149. FD2 part numbers
  150. 9th gen si factory leather seats?
  151. Question about Pilot Bearing
  152. Strange Cold Start Issue
  153. Wierd sort of grinding noise when starting my car
  154. Shifting problem with my 06 ex sedan
  155. 2013 Civic's mystery carbon monoxide (CO) leak - any insight?
  156. 06 Si K24 swap
  157. CD player won't play
  158. 2012+ Civic R18Z1 flashpro
  159. 2007 si sedan, no sound problem
  160. Auto to Manual Swap in progress. Clutch pedal switches bypass or DIY?
  161. installing red JDM steering wheel badge
  162. Late 07 DXG Audio problem..
  163. Extra rims for snow tires
  164. air compressor
  165. tik tik sound from back wheels
  166. Whistling when the fan is on
  167. 2006+ Si Brake Rotor Dimensions
  168. Anyone know anything about lifting civics?
  169. noob question where can u drill for the turbo to run oil
  170. 2012 Civic Si Clutch Issues
  171. help with 2013 touring
  172. new to wheels!
  173. HFP Floor Mats for 2013 Si coupe
  174. A/C intermittent Issues
  175. Civic Type R FN2 exhaust
  176. FN2 stage 1 upgrades, need advice
  177. Front Window Defrost means A/C is on!
  178. need help with weird sound
  179. Need a cheap remote spare key
  180. need some help! Dimmer issues!
  181. Drive Gear light blinking
  182. Rebuilt Title Civic si
  183. car high beam won't turn off
  184. stereo/electrical problems
  185. New to Honda.
  186. post your setups
  187. Technafit Brake lines
  188. 2010 Civic Hybrid Turn Signal Socket?
  189. Civic pulls to the right during braking
  190. Honda civic 2006, wont start, help please!
  191. 2006 honda civic hybrid parts question
  192. FA5 Turbo Build, HELP!!
  193. R18 Header/Heat Shield Removal, please help
  194. john eagle honda in houston really screwed me over
  195. Maybe Hydrolocked, Please Help!!!
  196. 2009 Honda Civic Ex - Air vent cover question
  197. WTB Si axle back
  198. JDM front and rear conversion on 06 4dr si lightbulb socket quest?
  199. 2006 Honda Civic - Recent decline in gas mileage
  200. 2007 Civic Si
  201. Looking for a mechanic or garage who will install aftermarket parts in the GTA.
  202. Buy new or used?
  203. Clutch Kit Recomendations
  204. Remove Light Scuffs?
  205. $$$OFFICIAL JAN-MAR WTB/FS/WTT Thread $$$
  206. Indicator lights of brake systerm, door open and boot open lights wont go off
  207. 08' Accord Coupe Rims suggestion
  208. A question about wheels?
  209. EM1 CMC upgrade - Engagement Point?
  210. Anyone Been Redeemed Under the Rear Control Arm Class Action Lawsuit?
  211. Jump battery
  212. Lighting during night?
  213. Rear suspension squeaks over bumps on 07 Civic coupe
  214. Need help deciding on a Civic Si Sedan
  215. projectors
  216. 2008 Honda Civic Navi/DVD
  217. How do I change the 2007 Honda civic si radio welcome saying
  218. AC comes and goes
  219. 2006 Civic Rear Upper Control Arm Replacement
  220. A/F Sensor reading backwards???
  221. 8th gen civic si oem steering wheel
  222. FSBs and recalls done on "new" 2007 civic?
  223. civic 2006 horn wont stop
  224. Adding skunk2 exhaust tip
  225. Just got my 2012 Civic Si
  226. Question about changing tires
  227. Gross said all the snakes
  228. Undercover investigators spoke
  229. 2013 civic si hfp package
  230. Good transmission shop near Riverside?
  231. 2013 Civic Si
  232. Blown Spark Plug 2007 honda
  233. 06 or 07 Civic EX-Navi 4D Manual Stalls when I start it
  234. accelerator won't react on take off?
  235. Custom Wheel Fitment ?
  236. POWER STEERING LEAK
  237. Whose lowered their 8th gen?
  238. hybrid racing intake bog problem
  239. WHINING
  240. running too lean=bad??
  241. How do I run direct power through firewall for SiriusXm Radio?
  242. Little help!! what year Civic this mat is for??
  243. '07 LX: Cold Weather Rattle in Trunk(?)
  244. bogging issues after installing injen cai
  245. Megan Racing r18 "Header" WTF?
  246. 2013 Civic SiriusXM Lynx Installation
  247. 2013 Civic, need more headroom. Lower seat, takeout headliner?
  248. Ball joint issue on 07 civic?
  249. Rattling when applying brakes
  250. Power lock issue help
