PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. EGR issues
  2. EGR issues
  3. Lost my key to 08 Civic LX (Manual), Fob battery is dead
  4. 2004 Civic LX cranks no start.
  5. K swap
  6. Blinking Engine Icon On Position 2
  7. Heater Hum noise only when on High
  8. 2013 Honda Civic Brake Lights Always on
  9. Considering a 2012 Civic HF
  10. 2009 Civic making strange noise
  11. J35 Throttle Body to OEM air tube assembly
  12. 2012 Honda civic take 2-3 times to start
  13. Need Help with 2013 Honda civic lx 5 speed
  14. Westar Rock Auto Mounts
  15. Car radio stuck on H boot loop (honda civic type r fk2)
  16. 2012 Civic Sunroof issue
  17. Strange scratching sound during cranking.
  18. FR axel won’t pop out from automatic Trans
  19. Where on the sunroof track is the "closed" position (9th gen)
  20. 2012 Civic SI / Intermittent A/C issues…
  21. Limp mode CEL p1780 p1747 p0722. Need help
  22. 2009 Honda Civic Coil Pack issues
  23. Engine light and vsa light
  24. 2007 Honda Civic Hybrid BRAKE SYSTEM light on
  25. What attaches to this bracket?
  26. Short rattling sound at a cold engine
  27. Gas question
  28. 2007 Civic fuel issue
  29. Tires Squealing On Light Acceleration From Stop
  30. 2008 Civic LX coolant leak from engine block
  31. Acura CSX compatibility
  32. 2014 Honda Civic hybrid oil sensor wires
  33. P0128 and Thermostat
  34. Replacing Mirror on 2006 Civic EX
  35. Honda Civic 2008 Dx Coupe
  36. 2013 Honda Civic Power Window Issue
  37. Is it dangerous to tie a box on top of the brake pedal?
  38. Help! Replaced Ignition Lock Cylinder, but Key Still Won't Turn
  39. Oil light flickers, oil pressure is good
  40. Code P0977
  41. Driver's Caliper piston dust boot seal, bleed screw cap, and cv axle boot are torn
  42. 2007 honda civic 1.8 EX operating temperature
  43. cargo measurements, 9th gen hatchback
  44. 2007 Honda civic si vs 2007 Honda civic dx ,ex suspension parts
  45. Hybrid Air Conditioning not working
  46. Help! Very low compression after clutch replacement
  47. Can't reinstall new serpentine belt - Civic 2009 R18
  48. 2013 Civic Oil Seepage Valve Cover Gasket PS
  49. Engine Swap
  50. Honda Civic starting issues
  51. Diagnose IMA problem
  52. OEM AC CONDENSOR VS AFTERMARKET
  53. 2010 Civic drivetrain noise getting louder
  54. Please help ! 2009 i-CDTI 2.2 Intermittent fail starting
  55. Car CEL with Evap Code P0453
  56. 2006 Civic Hybrid Immobilizer Issues.
  57. Civic 06 SI Lock Trunk (Handle+Power+Switch) - Honda (74851-SNR-C02) replacement
  58. my 2015 Honda Civic key FOB wont work after changing the battery. How to reprogram?
  59. 2010 Civic Transmission Leak/Spew
  60. My Car runs very rough for 15-20mins and runs just fine - what could be issue
  61. 2006 Civic SI Airbag light
  62. k20 rocker arm shaft diameter
  63. A/C Relay
  64. Help with steel tire and OEM lug nuts please, worried about incompatibility.
  65. Parts on hand
  66. Valve Cover Bolt Thread, R18
  67. JIC MAGIC AXLE BACK EXHAUST FITMENT?
  68. 05 civic lx special edition - Missing male o2 downstream sensor
  69. 2012-2015 does the EX model have vtec or all the same
  70. caliper not fulling releasing
  71. recommendations?? swap LDA-MF5 2007 Civic Hybrid (FD3)
  72. 2014 Civic running too cold after thermostat replacement
  73. EPS module interchange?
  74. Codes 300, 301,302,303,304, 128
  75. 2006 Civic Hard Shift Auto Trans
  76. 2007 Honda Civic EX starter
  77. DIY Transmission Flush Via Multiple Changes?
  78. SRS module fault (airbag light on)
  79. Please help me assess these problems under the hood of this '08
  80. Side break lights not working 2006 Civic hybrid
  81. 2006 Civic Si lower radiator support cover
  82. Which 1 of these is most likely the issue? 2008 [2.2 Diesal]
  83. Weird Misfire on partial throttle
  84. 2012 honda civic ex wont start
  85. All lights came on the hiway, then limp mode
  86. 2007 civic auto tranny
  87. Displaying Air Fuel Ratio on Tach
  88. Honda 2013 Civic EXL, Rear passenger noise
  89. 2015 CIVIC ENG REBUILT TO OEM SPECS
  90. 07 civic transmission won't shift when cold
  91. Po 172
  92. VTC 50° IN K24A TSX
  93. 2014 Civic LX Timing Belt Kit
  94. Factory Service manuals...
  95. Rough idle on 2009 Honda Civic hybrid
  96. Ringing Noise Drivers Side
  97. Windshield Replacement: OEM vs After Market
  98. Lower torque rod bracket oil leak
  99. Transmission chirp/bird noise
  100. Clean Throttle Body - N16A1 1.6 Diesel in Civic 9th Gen
  101. Valve cover gasket replaced 2x still leaking
  102. Is this pipe attached to the muffler?
  103. 2014 honda civic si left turn signal not working
  104. HAVING AN ISSUE WITH 2006 Civic Hybrid
  105. Help ... leak at the power steering pump connection
  106. R18Z1 swap options 2012 ex coupe
  107. Timing marks camshaft sprocket
  108. K20z4 o2 sensors
  109. Repair my '08 Civic Hybrid or buy a new car
  110. 2012 R18 K24 swap can it be done?
  111. 07 5 Speed Transmission
  112. 07 civic, help identifying part
  113. Clean up
  114. Triple tip exhaust
  115. 27-17 Steering angle sensor diag signal error (initial)
  116. 2009 Honda Civic Fluid Exchange & Coolant service cost
  117. Car Intermittently Won't Start
  118. N16A1 1.6 Diesel in Civic 2013 - Crankshaft Sensor Location PLEASE??
  119. 2010 Civic Si w/ TL Type S calipers
  120. Electronic power steering issue
  121. Honda civic heat and ac not workingb
  122. 2006 Civic EX very rough and stalling low RPM/idle
  123. Brake lights not working
  124. Horn randomly goes off on 2012 Civic EX
  125. 2007 civic radio code
  126. Civic Door Lock Cover Part
  127. Are there any decent body kits for a 09 4dr civic.
  128. Hybrid cooling fan issues
  129. '08 1.8L Coolant Leak near water pump
  130. Side Airbag possible reset Without replacement? 2015 Honda civic couple LX
  131. Bumper OEM PP or fiberglass
  132. 2012 Civic ex coupe downstream O2 sensor hardwire
  133. 2010 Honda Civic VP- Radio code
  134. Brake fluid leak
  135. Wires to fuse box keeps alternator from charging
  136. Engine Oil decreasing!!!!
  137. Engine Oil decreasing!!!!
  138. Dangerous Car Stall 2013 Honda civic 4 cyl.
  139. need quick answer Please
  140. 2007 Civic 5 Speed Transmission Issues
  141. Key fob remote works odly
  142. 2007 Civic Cooling Fans Not Running
  143. VTEC Oil Pressure switch (code P2647)
  144. Civic LX 07 ac compressor engages and disengages by itself
  145. K20Z3 Transmission
  146. Muffler rusted off can it be welded back together?
  147. oil drain plug
  148. 07 drivers' seat loose , .
  149. 2011 Civic electrical problems and buzzing sound
  150. Got a free 2008 Civic, Cranks but no start
  151. help! IMA meter sudden drop & related IMA problems
  152. Different spring rate on one side of the car, how should I adjust damping?
  153. code 53-11
  154. '07 DX-G Coupe (Canadian) in Nighthawk Black Pearl - clear coat gone
  155. ENGINE COOLANT TEMPERATURE SENSOR/COOLING FAN
  156. 2010 Shift Interlock Solenoid Replacement help
  157. 07 Civic Only starts with Jumper Pack
  158. 2014 civic humming over 40 mph ?
  159. 07 civic & 09 accord rims
  160. Engine Swap
  161. Anyone know how to fix this leak, and if it is easy?
  162. 2010 Honda Civic lx tuner
  163. Possible use?
  164. K24z7 gearset question
  165. Lower Mileage vs higher spec? Which to choose?
  166. 2007 civic speakers
  167. Radio on, display working, but no sound
  168. Dashboard warning lights
  169. Install screen on Honda Civic
  170. Slow Crank even with jumpstart and new starter
  171. 2008 honda civic
  172. 2007 civic front speakers ,
  173. type S oil pump on k20z3
  174. Clutch pedal bracket
  175. Low beams not working but Highbeams do
  176. 2008 Civic - ideal alternator output voltage?
  177. Trunk Release Handle Lock won't turn
  178. Start With No Keys - 2012 Civic SI
  179. Civic 2009 CEL blinks mid ride
  180. Hybrid - Installing used AC compressor. Oil?
  181. 2009 Civic - Steering Wheel shakes when accelerating/braking after new brakes/rotor
  182. Speaker Issues
  183. High rpm idles (up to almost 3)
  184. Heater at max only works on defrost.
  185. Shift knob stuck on?
  186. 2014 HONDA CIVIC CVT FAILURE. Need advice
  187. Size spacers needed for willwoods
  188. AC Help with 07 Civic 4 door
  189. 06 Honda Civic Ex - Crank, no start
  190. 2008 Civic Battery Drain Mystery
  191. Easy Fix, right?
  192. 2014 civic will not move in drive?
  193. 2007 Civic 1.8 O2 sensor, sensor 2 harness wire to connector, correct placement
  194. 2007 civic 1.8l lazy at 3500 rpm’s?
  195. 07 Civic Hybrid - prepping used AC compressor
  196. 2012 CIVIC HYBRID fans PROBLEM
  197. Wheel bearing help
  198. HUMMING noise in rear
  199. 2015 civic key wont turn
  200. help with identifying plug on charge harness
  201. Fuel Pump
  202. Please help!!!
  203. 2007 Civic EX Misbehaving washer motor
  204. Looking for a diagram or guide
  205. 2012 Hybrid Blowing Inverter Transistors
  206. How to disable alarm system?
  207. 07 coupe SI engine upgrade
  208. Advice Needed
  209. Civic 2007 I-shift (ATM) Transmission/Clutch issues / algorithm adaptation
  210. Ep3 hesitation when changing gear in vtec
  211. Rubber plug sitting on engine block. What is it?
  212. Power steering Pump Diagnostics
  213. Maintenance & Fuel Economy
  214. Maintenance Schedule?
  215. 2012 Hybrid side mirror wiring
  216. Positive terminal vs wire touchin the car
  217. Fog lights for 2015 civic si
  218. Honda Civic 2008 leaking oil parts people don’t know what part it is
  219. Coolant reservoir always empty
  220. 2012 Honda Civic engine misfire help
  221. Key fob for 2010 Civic DX-g
  222. Replacing exhaust tip - Flanges & Gaskets?
  223. Windshield washer reservoir Civic Coupe EX-L 2009
  224. 2008Honda Civic Coupe
  225. Busted off piece of the block while removing the timing chain cover. Any hope?
  226. 08 Honda Civic driving rough
  227. 2006 Civic electrical gremlins.....
  228. HYBRID battery replacement
  229. 2014 honda civic ex eletrical issues help!!! Please and thank you
  230. Emergency! Heat stroke!
  231. Civic si mugen?
  232. Advice on broken exhaust
  233. Factory Navigation Replacement
  234. 2013 Civic EX-L Slow Acceleration / Lag
  235. How many miles you guys have with CVT transmission?
  236. 2015 Honda Civic EXL - Am I missing underhood splash guard?
  237. keyfob remote not response but car cranks and starts
  238. No low beams and high beams driverside
  239. Honda civic 2009 1.8i VTEC VXI rear brake fuse
  240. Removing vtc actuator bolt
  241. Can't find the sensor!
  242. Honda Civic 2009 [Brake is spongy]
  243. Buzzing sound in steering wheel when i turn the key
  244. 2013 civic HYBRID - Check brake system, check IMA system, check charging system
  245. No start, no crank, and no lights on the dashboard
  246. Random rough idle issues
  247. 07 civic 1.8 missfire
  248. trunk is stuck
  249. Finishing timing chain
  250. Right side turn signals not working please help!
