PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. TL type S brembo kit on 09 Si??????
  2. The car starts and then shuts off in 2 seconds
  3. 07 sedan with two faulty srs modules?!?!?
  4. Sirius/XM Radio Question
  5. Question about rough feeling with new tranny mount
  6. 2007 Civic starts and immediately dies
  7. need insight on immoblizer
  8. AT & MT CSX consoles...
  9. Changing 06 1.8L tranny mount
  10. Honda Civic 2007 si
  11. Replacing/removing steerig rack step by step 8th gen
  12. Thoughts on the Greddy SP Elite
  13. 2006 Civic EX Heater is stuck on
  14. Question about ECU remapping software
  15. Head unit will not accept security code
  16. Check system
  17. Common Error Codes on Honda Civic 2006
  18. Key fob won't work
  19. 2013 Civic Vibration When Idling
  20. Compressor Turns On When Defrosting Windshield
  21. Cold running engine temperature warranty?
  22. where is the starter, 07 Civic DX
  23. 2014 si clunking noise after initial start
  24. Best Exhaust for 07 FG2
  25. Honda Si 2006
  26. Broken right front engine mount
  27. Alignment off after axle seal replacement?
  28. This guy cannot even appreciate an 09 Si
  29. What kind of Oil do you use 8th Gen Civic (Non Si)
  30. Help: please evaluate how much should my car be sold at
  31. Intermittent SRS airbag light (2006 Civic) Solutions? TSB?
  32. Help with car repairs
  33. 2014 Key Fob too sensitive--drained car's battery!
  34. Temp gauge
  35. Miles on New Car before Purchasing
  36. Honda civic tourer led function
  37. Engagement ring lost in Honda Civic 2014 Trunk/gas release
  38. Airbag light on cluster
  39. Service code items
  40. 2013 Civic Si Intake Install
  41. 2008 civic constant vibration!
  42. Lca ball joint problem
  43. Mugen Rain Guard/Visor
  44. Help! Hit a raccoon, I'm screwed!
  45. Theia 2015 Si track/dd build
  46. 09 civic si starter problem.
  47. 2006 Honda Civic SRS Light Issue
  48. Alternator charging output vs. bad battery
  49. My 08 Civic EX Mystery
  50. Flashpro Help - Wont Rev past 6800rpm when boosting over 0.6 bar
  51. 08 CIVIC ALIGNMENT AND CAMBER PROBLEM
  52. 2008 LX 2-door back right wheel problem
  53. EPS problem.
  54. compatible tire size for 2013 civic lx
  55. Can anyone identify the outlined part in these pictures for me?
  56. 2007 Civic LX Ignition Switch Wiring Diagram
  57. Fd2 valve clearance
  58. hail damaged 2007 si
  59. 2014 Civic LX Catback Exhaust B Pipe Size Diameter
  60. 07 SI transmission whine
  61. Ciggarette lighter
  62. HELP Anyone LoL
  63. Next upgrade advice
  64. 2006 civic si no crank no start
  65. Brake Caliper Slide Pins..
  66. 2007 Civic FD2 Type R
  67. P V C location
  68. 2008 Honda civic lx engine swap
  69. Good To Use DOT 4?
  70. Need Civic Si OEM Axle Back 06-11 - I BUY ASAP !!!
  71. Transmission question
  72. UGH!! 2011 Civic Issue
  73. need advice replacing emblem
  74. Honda Civic 2006 Aux Adapter HARNESS
  75. lots of white smokes comes out of my civic.
  76. Honda Civic Europe 5d
  77. What is this metal grinding noise of the hub/axle joint of 2009 civic?
  78. hybrid automatic door locks over and over
  79. 2011 Civic Si Sedan
  80. 2014 Honda Civix LX
  81. Buying 2007 Civic Si
  82. Anyone running the Rick Spec's Intake?
  83. 2009 Honda Civic Clunk when braking... Suggestions Please
  84. 06 civic power window issue
  85. Need info on finding CARB legal upgrades for a 2014 Civic SI
  86. Hard steering problems, alignment or steering rack?
  87. Custom LED Tail Lights - Need Help
  88. Your 1st drive in an FG2 SI.
  89. What to Lube Injector O-Ring When Installing
  90. 2014 Honda Civic Si review
  91. Good Steering Wheel Covers?
  92. 006 charging problem
  93. 08 Civic coupe EX is very loud
  94. 2008-2011 civic sedan
  95. Retrofit Cruise control
  96. Speaker problem?
  97. Do we need the fly by wire adapter for nx kit? (For the 2006+ si)
  98. a/c compressor wont turn off
  99. Revs increasing while shifting HELP!
  100. 06 Civic Si Squeaky/Popping Clutch
  101. 06 Civic Si Squeaky/Popping Clutch
  102. Honda civic FN2 timing chain?
  103. 2012 Civic Passenger Airbag light turning on
  104. HELP! Problems when viewing 1.4 civic type s
  105. this weird noise from civic 2008 ex
  106. VTEC engine on a non-SI Civic?
  107. Need help Identifying this part. plz
  108. Best/favorite floor mats for 2014 civic coupe?
  109. 2008 civic AC problems
  110. No Clutch Pressure/Power Bleeding?
  111. 2014 Si sound system
  112. 2010 Civic, a/c compressor won't ever shut off... ever.
  113. Factory Interior Illumination Accessory?
  114. 2010 civic swap into 2001 integra
  115. 2007 Civic EX automatic door lock issues
  116. some kind of screeching noise from my car
  117. Hello all! looking for SRS help, 08 sedan
  118. MTF
  119. Whirring noise! Help!!!
  120. [ HELP in a Relay harness ] What's ground wire?
  121. AC Compressor
  122. Seat position 2014 Civic
  123. Honda Aux Input / No Sound From Left Speakers
  124. TSX TB swap help: RPM Jump/Cruising Idle Surge
  125. Paint impact on car's price
  126. School me on 2012+ Civic Si and/or fg2-fa5
  127. Difference between TR0, TR3, and TR6 part codes?
  128. canadian made help
  129. cold air on 2014 bond civic si
  130. 2006 Civic LX sedan
  131. Need help deciding
  132. Trailer hitch for 2014 Si?
  133. New Car Purchase
  134. Skunk 2 headers just sitting in garage...
  135. How to adjust the high beam headlight for a Civic 2008 LXi 1.8L Japan model???
  136. 2009 Honda Civic Air Conditioning
  137. 8th gen poping noise, need help!
  138. Check fuel cap msg
  139. Back in the Game
  140. 2014 civic touring headlight
  141. Headlights Changed ?
  142. Si doesnt want to start
  143. Having trouble playing recent Amazon MP3 files on my 2008 stereo/Nav system
  144. 06 Civic Si - Idle noise while in cabin
  145. New daily driver!
  146. Si Wheels
  147. Know this part? 2008 si
  148. 2008 civic maintenance
  149. Car wont start without starting fluid!
  150. Official HPDE/Time Attack/Racing Thread
  151. Need advice on having awesome exhaust sound in 08 Civic LXi 1.8L
  152. Running on 17s 08 Civic
  153. Starter DIY Disaster..Help!!
  154. 2008 Honda Civic DX 4dr blower motor not working help me!
  155. 2008 Civic Si radio issue
  156. Faulty alternator?
  157. 09 civic si cel cause of gas?
  158. New Engine
  159. 9th gen civics??? where is that section?
  160. Pyper
  161. Drove through large puddle, now a/c does not work?
  162. OEM FD2 exhaust manifold install
  163. FN2 civic type R
  164. '08 Civic AC Problem
  165. Regular or Genuine Brake Fluid?
  166. DTC 32-10
  167. Important: Idea need members feedback!
  168. My 2008 civic coupe ODO, SPEEDO, TEMP METERS MISTERIOUSLY DOESNT WORK
  169. Civic FD3 noise from Power Steering Gear Box
  170. Ac + dealeship?
  171. a shirt caught on axil
  172. '08 Civic AC and Making Noises
  173. Fuse box under hood , front of car
  174. Body kit problems
  175. 2010 Honda Civic LX Reverse Lights Not Working
  176. 09 CIVIC SI POPPING SOUND WHEN PARK AND TURN STEERING WHEEL
  177. 09 civic si,ac compressor not engaging
  178. 08 si coupe help
  179. Installing Fog Lights On 2011 Civic?
  180. "check fuel cap"
  181. MY FG1 COOLING FANS DOESN´T START
  182. How to install Isolation Solenoid?
  183. 2013 Civic Flooring
  184. Low Tire Pressure Warning
  185. ac condensor fan stay on when ac turned on
  186. What would you do with $13k
  187. I just lost 5mpg going to a 5 pound lighter volk wheels how is this possible
  188. Honda Civic Sports 2013 model
  189. r18z1 specs
  190. Turbo Civic Type R
  191. 2008 cranks, won't start
  192. 2009 Honda Civic FA1 License Relocator
  193. Air only blowing at feet help?
  194. TL-S brake master cylinder into FA5 sedan
  195. Replacing starter on 2007 civic.
  196. 1.8 LITER UPGRADE WORTHY
  197. replacing plastic over speedo
  198. Brakes
  199. gps navi for 2014 civic si
  200. Honda Civic 2007
  201. What's the best way to make my 2006 ride smoother?
  202. Dealership informs me I need an engine replaced at 200Kmiles??help
  203. '14 Civic Coupe - Question about visors
  204. new and need help
  205. AC blockage under dash
  206. rear pads not contacting whole rotor
  207. 2013 Civic Loose Steering
  208. Knocking sound from rear tire in 2009 Civic EX
  209. Radiator fan staying on continuously
  210. What is this thing on the Lower Control Arm
  211. Need to change light brown transmission fluid? (pic)
  212. civic 2009 dash dump 93c76
  213. Hello, all. New kid on the block, here...
  214. What is it to love anymore ? Si rant.
  215. Collision - Front Left Wheel Bent at Angle
  216. 2007 Civic SI Coupe OEM Clutch Kit
  217. RPF1 Valve Stem Install
  218. Hub/wheel question (new rims with pic)
  219. 2007 Civic EX - change rear drums to disc?
  220. 2008 Civic - No heat from AC
  221. Honda Civic 2007 automatic misfires cylinders 1 and 4
  222. Adjust idle speed
  223. Reverse lights not working!!
  224. ambient air temp sensor
  225. 2014 Civic SI Coupe vs Sedan?
  226. I need help.. my center console is broken. (2010 EX)
  227. Rims and Suspension
  228. 2010 civic si throttle help?
  229. rear drums - how long until replacement
  230. New Si... What next?
  231. fuel meter problem pleasse helpp
  232. Automatic Door Lock Issue
  233. Cigarette Lighter won't work
  234. Civic LX uses EX brakes - what gives?
  235. K23a1 Head onto K24Z7
  236. New rims advice !
  237. R18 trans. filter size, want to use a Magnefine
  238. New Ktuned 3" exhaust for the FG2/FA5
  239. IMA issue
  240. Engine light came on after header install
  241. Will a 07-09 cvt hybrid transmission fit in my 06 hybrid
  242. Dashboard color
  243. motor mounts
  244. Radio quality
  245. Honda is covering the failing paint
  246. 2007 Civic LS engine overheating issues and question(s)
  247. Cvt transmission failure help
  248. 2007 EX: Power Steering Leak
  249. radio button illumination not working
  250. HELP! Right Front CV Joint/Shaft Replacement
