PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. EPS question
  2. 09 civic hybrid BUY or PASS
  3. HELP! 2009 CIVIC SI PROBLEM RE TPMS & VSA
  4. 2008 SI sedan power steering failure?
  5. Mini me swap problem
  6. 2012 Civic Navi/DVD system
  7. fa5 owner introduction
  8. 07 civic lx ticking when started
  9. Brandons SKUNK2 Powered MUGEN SI
  10. civic sedan amber tail lights
  11. 2010 Honda Civic Transmission
  12. Bad motor mount? With pic's!
  13. 06 Civic Hybrid - Catalytic Converter
  14. Would you buy this? Need Advice
  15. New to HondaTech
  16. FG1 Si vs. DC2 Type R vs. DC5 Type S: Winner?
  17. Having trouble setting up bluetooth
  18. windshield swapping
  19. 2011 si
  20. Brake pads for least dust
  21. Radio Code Civic 06
  22. Need Sedan Si love!
  23. Need Help
  24. 06 civic lx tire?
  25. burning oil 07 fa5
  26. 2008 Civic LX 4 dr, Weird noise when in reverse.
  27. 07 fa5 , p0341 and vsa light on 106k miles
  28. who running a supercharger?
  29. Honda Civic LX-S 2010 start-up trouble
  30. 2006 Civic Clutch Problem
  31. Em1 cmc in an 07 Si
  32. 2006 Civic SI Clutch
  33. New member(9thgen)
  34. 06 lx rear spring swap
  35. What is causing my rear tires to wear excessively?
  36. GSR swap in 98 EX
  37. HID Conversion Kit for 11' Si
  38. 06 civic trans leak question
  39. Oh Crap! I "spinned" the Throttle Body and now Rev Hangs and Idles Iractic
  40. Hey, I need some info for an 06 civ ex
  41. 09 civic Si code scanner
  42. Automatic trans gear indicator light
  43. Noise from right rear 09' civ SI
  44. How do you replace the right front bumper on a Honda 2009 Civic
  45. K20Z3 swap into kit car: Immobilizer Question
  46. will a b18c type r fit into an 09 civic lx?
  47. 08 4dr civic sleeper build all motor
  48. map light acting strange
  49. 2006 Honda Civic EX stock audio issue
  50. spark plugs
  51. 2012 Civic SI "rev hang" petition up.
  52. seat belt chime
  53. Best wheel/tire size for tracking?
  54. Merry Christmass Fellow 06+ civic owners!!!
  55. 07 Si build advice
  56. Better gear oil alternative?
  57. lowering springs
  58. civic 2007 ignition lock cylinder
  59. Honda Civic 2010 lights problem
  60. Compustar CM4200DX
  61. SSR type-c Rs. Big brake kit?
  62. Spark plugs and battery
  63. Petition for Smog Exemption!
  64. transmission help
  65. k20 z1 oil pan on a si?
  66. 07 Civic Si clutch pedal spring replacement
  67. window visor install?
  68. NEED ASAP: used 06 Civic EX Sedan front license plate bracket
  69. 2006 Honda Civic LX Sedan AT
  70. Sport Shock/spring options for a 06 EX sedan
  71. How to slightly mod a leased 2012 civic si
  72. Header Question
  73. Test drove 2012 Civic EX - no interior lights
  74. limited slip differentials
  75. z3 TIMING CHAIN COVER BAFFLE oil pan solution
  76. cams question
  77. K24A2 cams in K20Z3, anyone done it?
  78. F20C/Factory Transmission in a 2009 Civic Si?
  79. not your average radio code problem
  80. 2012 Gen 9 Civic Preview
  81. new 2013 civic!
  82. 07 Si dash flicker
  83. Eibach looking for 2012 Honda Civic Si
  84. 2012 Civic Si (K24)
  85. 06 Hybrid Pinging
  86. 2010 Civic Seat Removal Help
  87. Fuel concern
  88. noise when unlock the doors using the remote
  89. Where can I buy a honda civic type R 2008 in California?
  90. 2006 - 2010 Civic Type R brakes on a FA5
  91. how much $$$ for new discs/brake pads?
  92. Honda Civic SI 2008 won't start up
  93. STRANGE SOUND COMING FROM THE ENGINE
  94. Break-in Ease of Coupe
  95. Honda Civic Overheating Filler bottle boils
  96. coilover question
  97. R18 to K20 swap
  98. coilover question
  99. Elec. Power Steering doesn't come on when it's cold outside.
  100. 8th gen Civic vs 9th gen Civic - Suspension Differences
  101. Rear Suspension Noise
  102. 09 front end on 07 civic sedan
  103. Cold air intake problems
  104. Funny brake noise
  105. Mystery Engine Harness, are YOU Tough Enough to Solve??
  106. Takeda vs. Injen vs. K&N
  107. VSA bad in winter?
  108. Radiator Question
  109. can anybody identify the brand of this intake?
  110. Radiator replacement
  111. Coils, Spark Plugs, Exhaust for a 2008 Si Reccomendations
  112. Honda Civic 07 COUPE replace wiper blades
  113. Red honda badges
  114. lost my audio code to my honda civic 2011
  115. Intake recommendations?
  116. Transmission Change for a 2009 Honda Civic, 20,000 miles
  117. Tire pressure monitoring system
  118. Honda Civic 2009 (frame)
  119. Vehicle doesn't exceed 40-45 mph
  120. Just bought a 08 LX, needs some Insight
  121. pulsating headlights, speedo not working
  122. Anyone used the TWM full replacement short throw assembly?
  123. Throttle Response
  124. Engine is imobilized...Please help
  125. 500+whp 07 Civic SI build (final round of upgrades)
  126. Finally got my grill for my 2010 Si
  127. Mugen si grill
  128. Should I HONDACARE?
  129. Si wheels on a ex?
  130. SRS Light, module reset
  131. suspension 4dr lx
  132. Berks high flow 3" cat
  133. Steering Issue
  134. Help: 2006 vibration when stopped
  135. 2008 Honda Civic, Hyundai Elantras, etc.. On Buying Cars?
  136. dealer pricing on a 2012 civic ex
  137. Good Website To Order Exterior Parts From
  138. Can Rims be to Big For Me
  139. brake calibers
  140. Clunk when starting with wheel turned
  141. White stain on engine block??
  142. vsa light on and horn doesn't work
  143. Everything you need for the Albins trans to work
  144. 2007 honda civic lx bad vibration at idle, any ideas?
  145. 06 si clutch not releasing, help!
  146. Should I Buy?
  147. Pivot Bolt Repeatedly Breaking
  148. non oem door sills
  149. shifter feels loose? ('11 Si)
  150. 06 Civic Si rought thru gears
  151. Front lip question
  152. 2007 Si Rust Issues
  153. new owner of 09 civic si
  154. can't get brake dust boot bin properly
  155. $$$ October-December 06-11 FS/WTB/WTT $$$
  156. Should I report to DMV my car was broken into and radio was rebuilt?
  157. Clutch pedal keeps getting stiffer
  158. Rattling Noise when I Turn the Steering Wheel in Park
  159. In dash navigation
  160. Real or Fake Mugen Si!!!!
  161. Plowing with Si
  162. Clicking Noise during Slow Driving? HELP!!
  163. PROGRESS is looking for 2006-2011 Civic
  164. Really Hate Ohio roads
  165. front wheel bearing replacement
  166. R18 Turbo Kit
  167. h22a in a 97ek mounts?
  168. SI with Nav audio connections
  169. Stereo keeps cutting off
  170. 2010 Civic uneven tire wear issue (Canada)
  171. What mods/bolt-ons can I add without disrupting my warrenty?
  172. Creeking in Clutch Pedal
  173. New Civic Owner =)
  174. Motor Mount
  175. knocking noises?
  176. Slightly Overfilled Oil in my civic.
  177. 2010 Civic started smoking after jump start
  178. My nightmare 07 4dr Si
  179. CF Door Handles
  180. Hey, new to the forums
  181. BUILD Thread - Fox Marketing/Honda-Tech 12 Civic Si
  182. FD2 hood fits FG2 or FA5?
  183. Maintanence minder screw up
  184. FG's on 18" rims Pics and Help
  185. Back on the Honda Scene
  186. Winter steelies vibration
  187. 2012 aftermarket parts?
  188. Fitting/Fabbing an rsx cat back onto FA5
  189. Skunk2 short shifter adapter
  190. will a tsx SRI fit a 2012 civic si?
  191. Fully Built R18 Stepping Up
  192. Hatch front end parts?
  193. First winter with the FA5 couple of questions...
  194. Honda hybrid
  195. header=tuning???
  196. Water Pump pulley bolts
  197. civic si rims (09-11)
  198. question about skunk 2 alpha header and kidracing header
  199. 07 4dr si part number question
  200. Engine rattle at 3500 RPM
  201. Factory shift knob and boot
  202. Fa5 - 75k miles - Which shocks
  203. 2009 Civic Si sedan the only one in germany
  204. 2012 civic hybrid
  205. DIY HFP suspension install
  206. Typical RPM for better mileage and engine life
  207. 16's on si and tpms 09
  208. 06 civic si muffler
  209. Malfunction Indicator Lamp
  210. Progress rear sway bar and TWM shifter bushings?
  211. Throttle Response question
  212. new to me honda 2006 civic dx
  213. 10 front bumper on 07
  214. Radio code help?
  215. Radiator fans stays ON all the time! Why?
  216. Mugen front bumper falling off
  217. Maintenance Minder - Is it Gospel?
  218. Dripping on Honda Civic
  219. 2007 si intake resonator bolts
  220. My dealing with Honda, also need some help.
  221. Just purchased 07 FBP SI sedan!
  222. Houston's Monthly BBQ Meet after C&C
  223. FG2 H.I.D Problems!! Wont work?
  224. wheels hitting springs ??
  225. FA5 Spring Rates
  226. drop engineering motor mounts
  227. odd noise after camber bolt install
  228. Pressing on clutch creates tick tick that I hear and feel.
  229. lug nut help
  230. 08 si sedan brake lights inop
  231. I Need HELP!!! Just bought a 10' CiviC LX-S.
  232. self installation warranty void?
  233. FA5 hfp lip kit parts?
  234. Aftermarket HU question
  235. Cheapest Coils out there for 08 SI COUPE?
  236. Looking for FA5 parts.
  237. Told I need a camber kit on my stock civic... help please.
  238. Front knuckle assembly SI vs DX
  239. Hardware dimensions?
  240. work emotion reps??????????
  241. Key Fob Help
  242. stupid headlight problem!! HELP!!
  243. sway bar ??
  244. 2012 Honda Civic Fails Consumer Reports’ Tests
  245. something will have to go
  246. Anybody else have this problem? Brake Problem 07 Civic SI Sedan
  247. 2012 Trailer Hitch
  248. 09 civic si coupe part out
  249. More fogs
  250. Brand New Member and EX
