PDA
View Full Version : Honda Civic (2006 - 2015)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. How to Remove trunk (boot) hatch inside panel
  2. size and weight between L15 and R18
  3. Honda Civic Paddle Shiffter issue
  4. Hondabond vs The right stuff
  5. Looking to purchase a Honda Civic Si
  6. Civic Si 2015 ECU Swap
  7. Diagnosing short
  8. 65-1 Code Secondar o2 sensor heater?
  9. Civic 08 Ex ac compressor Auto
  10. car shaking at traffic lights
  11. Max AC, no increase in blower air flow?
  12. 2010 Honda Civic fg1 swap auto to manual
  13. Steering Wheel Issue
  14. 2006 civic hybrid/Si sedan seat interchangeability
  15. air will not leave clutch line
  16. DIY Alignment with 4 buckets, string and a tape measure
  17. Radiator cap 0.9 vs 1.1
  18. Weird electrical fault (radio + remote + headlights)
  19. rpm issues
  20. brake issues 2014 Civic EX
  21. Tranny problem????
  22. civic 2007 JDM parts
  23. VSA Light On in 07' Si. Brake switch the issue?
  24. 2015 Civic possible ignition problem,
  25. Stock amp questions
  26. PCV valve replacement interval
  27. Need help with replacing steering wheel radio controls 2012 Civic
  28. FA5 to FD2 Conversion
  29. Need a walkthrough for replacing AC compressor
  30. 2014 Honda Civic 1.8L
  31. 2006 Honda Civic Key Fob Replacement
  32. New Engine: New problems (Bearing noise)
  33. Suspension shock alignment
  34. Custom DIY Shift Boot
  35. 2008 Civic EX: Wiring harness question / CEL P0983
  36. 2006 Honda Civic poor performance and acceleration
  37. Unlocking Issues
  38. Nasty engine knocking
  39. Perfect Alignment Car Drifts To Right
  40. CODE RADIO CIVIC
  41. 07 Civic Si - Clutch Master Cylinder & Other questions
  42. Heated seats?
  43. 2014 climate control HELP
  44. Known problems with A/C?
  45. recirculation mode - 2014 Civic
  46. Should I fix this dent?
  47. Coupe Cluster to 4dr Sedan
  48. 2006 Honda civic EX 4dr wont Start, no Crank either, engineoil,brake,check engine ON
  49. Constant HU alerts and beeping
  50. Noise when put in reverse gear - what is this telling me?
  51. Headlight recommendation?
  52. Driveshaft Popped Out - Civic 2010
  53. ROLLER COASTER
  54. 2010 civic check engine light does not come on
  55. New short shifter for the 9th gen Civic!!!
  56. AC is always engaged. 2010 honda civic.
  57. Which is better for a 1.8L manual trans
  58. Help with exhaust
  59. 2010 honda civic A/C not working
  60. 2009 Honda Civic exl
  61. 2012 civic sedan rear wheel bearing ?
  62. Power Windows won't work... Weather related?
  63. The sweet spot on the atf dipstick is the halfway point
  64. I own a 2009 civic lx.
  65. 2014 Honda Civic CNG Stalling
  66. 2014 Civic EX Econ Mode
  67. 2006 Honda Civic Radiator Cooling Fan Change?
  68. Knuckle Assembly Swap
  69. fan not turning on/ ECT issues, maybe
  70. Need SRS wiring harness for 2009
  71. 2009 civic fa1 A/c Problem
  72. New Tires for 2011 Civic Sedan
  73. 2009 Honda Civic max A/C not working
  74. New teaser from Acuity Instruments ;)
  75. 08 Civic EX A/C problem
  76. Rattle noise from Strut/Rear Deck (Civic EX 2015)
  77. Thinking of buying a 2009 civic Si
  78. need '08 1.8L key/ignition info
  79. OEM Side Skirt
  80. Need Clutch help
  81. Honda Civic Hybrid 2008 doesn't start with key alone
  82. Considering a 2006 Coupe, Need Some Advice
  83. 06 civic si coupe
  84. CV Joint/Axle
  85. 2 door vs. 4 door body differences?
  86. Civic LX Coupe 2007 Cold starting issues
  87. tire size increase 2009 Civic EX
  88. Air Conditioning Cycling
  89. 2010 Civic Odometer Jumped ~40,000 Miles After Service
  90. 06 Civic Rear tires wearing badly
  91. Carbon fiber or oem
  92. Trunk lock removal problem
  93. IAVC
  94. much weaker after technical service
  95. Transmission fluid question
  96. Air filter for honda civic hatchback 2009 1.8
  97. 2012 Honda Civic trouble code P2185 Circuit High
  98. Rear brake shoe tolerance
  99. Redshift Motorsports Coilover Review
  100. plugs car hathbak 1.8 2009
  101. Question about AC out put
  102. 2009 civic si mods
  103. Factory Subwoofer
  104. whistle noise after exhaust changed 15si
  105. 2008 Si : have compression, spark, fuel & air NO START video
  106. Wiper Cowl
  107. Error 1 dash diagnostic 08 civic si
  108. Best header/ exhaust combo for racing?
  109. R18 oil pan removale
  110. Input on idle surging after neutral
  111. Troubleshooting noise on 2011 Civic after bearing change
  112. K20A3 swap into 8th gen Civic SI
  113. 2014 civic si advice!!??!!??
  114. Condenser from Sedan Si on coupe Si?
  115. 2007 Civic A/C problem
  116. Korney's FA5 Semi-ish Track Car Build
  117. What year and model of the Honda Civic should I get?
  118. 2015 ex EXHAUST
  119. 2012 Civic SI weird problems. S.O.S.
  120. Catalytic convertor needs replacement
  121. 2006 civic Sedan Camber kit
  122. 2015 Honda civic ex under cover??
  123. Burnt Rubber Smell when trun on heat
  124. 07 fg2 SI
  125. Buying new shocks/ struts- Rockauto
  126. Trouble starting 2008 Honda Civic
  127. Problem with Car temperature and Error Code P0128
  128. 2007 Civic Si Transmission
  129. r18a1 2007 civic running lean
  130. Automatic gear shift light not working
  131. Navigation Update or hack?
  132. Might buy an 08 Civic but....
  133. Preventing Water from Inside Car 2014
  134. Issues maintenance a 2006 Honda Civic.
  135. advice about information honda civic 2008
  136. Problem about Honda Civic 2006 making noises
  137. Should I replace my Tie Rods?
  138. 2015 Civic Si Street/Track
  139. r18a1 starter rebuild kit?
  140. 2008 Honda Civic EX power window
  141. 8th Gen Si: Shifting Issues. Plz Help Asap!
  142. how do i remove the gauge bezel from a fn2?
  143. 2008 civic si abs and vsa light don't turn on.
  144. Question about repair Honda 2010
  145. Issues about my 2008 Honda Civic LX
  146. Not easiliy shifting into reverse
  147. 2015 Civic EX key fob
  148. Coolant fan turns on every 10 secs
  149. Civic SI 8th Gen VSA Unit Connector
  150. A1 service questions
  151. Replacing Wheels
  152. Acuity shift linkage bushings
  153. Running Lean CEL question
  154. hard shifting solenoid tested fine
  155. blower motor resistor
  156. 2008 Civic sedan left turn signal not working
  157. My new 07 Si - Upgrade options?
  158. K24A2 swap into 2006 Si coupe
  159. 2016 ILX repair/shop manual
  160. 2012 Civic Hybrid - 31,000 miles. Do I actually need a transmission fluid change?
  161. 07 SI, Trunk Smashed in, help get through inside?
  162. Need help. Could you compare Scion to Civic
  163. will a ep3 rotrex sport kit fit a fn2?
  164. commen issues?
  165. 2012-2015 Civic Steering Wheel Spline Count?
  166. Weird Noise ! Civic Si 2008 Sedan. Help!
  167. light issue
  168. Power steering leaking very fast
  169. Honda Civic 2007 LX Fuses
  170. Need Help Looking
  171. What is this called ._.
  172. Oil change question
  173. Looking for this parts... (for TypeR)
  174. will a EP3 rotrex kit fit a FN2?
  175. Why no FG squad for 9th gens?
  176. 2016 ILX
  177. What is your favorite winter tire?
  178. Transmission Fluid
  179. 2007 Honda Civic - Engine Question
  180. 2008 civic AUX port
  181. BLACK SMOKE HELP. 2008 civic type-s
  182. 2016 Civic Sub-Forum
  183. Type R shift knob on FD1?
  184. DYI: 8th Gen Civic Steering Rack Passenger Side going over bumps knock fix
  185. 09 Civic Windshield - side "molding" missing
  186. How to replace fender on 2013 Civic
  187. Crackling static "Pop Rocks" sound from engine?
  188. Rear ended - alternator and battery dead
  189. 06 EX Engine stock swap, now cranks but won't start. Help!
  190. Trouble with transmission range sensor?? Engine doesn't crank... Civic 2007
  191. Civic 2013 oil change
  192. Help, car dead...
  193. Ecu repair
  194. 2006 civic not shifting out of park sometimes
  195. Getting a "Thunk" while shifting
  196. 2008-09 civic si sedan rear seat question
  197. 06 civic lx starter replacement
  198. 2013 Civic - 2014 Corolla
  199. Immobiliser reset on fn2
  200. check engine lights came on with my 2012 civic si
  201. 2007 Civic Hybrid Advice
  202. Suggested Upgrades for an automatic 08 civic coupe
  203. more horsepower for cheap
  204. Clutch pressed => low RPM => engine shuts off
  205. 06 SI K20Z vs engine possibilities
  206. 2014 Civic LX sedan has crooked steering wheel
  207. What year door locks and ignition cylinder are compatible with a 2015 Honda Civic?
  208. How to: Fog Light Install 9th Gen Civic
  209. Resetting dash warnings
  210. 2015 Honda Civic SE CO2 Emissions specification
  211. Can't find civic ex w/auto back up switch, anyone?
  212. Motor Mount Question - This Sound About Right?
  213. Civic Mugen RR
  214. 12' SI light front end collision, now only runs for 3-5 seconds
  215. 2008 Civic Hybid- need help identifying part that may have fallen off while driving
  216. 2012 Civic- High Temp light for a bit, steam coming from under hood
  217. OBD2 Port Loose on Civic SI 2010
  218. 2010 SI excessive oil consumption
  219. 2013-2015 Civic Sedan 4D Front Lip MD Style
  220. Cold air intake install
  221. Don't fall asleep at the wheel.
  222. Check TPMS System
  223. New to the Honda Life!
  224. 2016 Civic Coupe revealed while testing
  225. 2013 Civic Amp install help
  226. Prealignment Inspection
  227. HELP: Can't solve cracking noise
  228. SRSystem repair/ airbags
  229. Easy Car to learning stick?
  230. 2008 Honda Software Update
  231. Door post ID sticker color decode
  232. Compression test results
  233. Car jerks when letting off or barely pressing gas pedal
  234. 2015 Civic Navegation
  235. 2015 Civic SI under warranty
  236. New Ultragauge
  237. intermittent vibration in the front end
  238. 2014 Civic Si Transmission HELP!
  239. Persistent creaking noise - Civic 2012
  240. Heat shield
  241. honda gps question
  242. Honda Civic 2.2 I-CTDI Engine problem.
  243. Best struts for 12' Civic LX
  244. 2014 oem radio in 2010 civic
  245. Bumper parts and supports
  246. Airbag/safety belt issue
  247. 08 civic mystery part
  248. Eaton charger on 8th gen... help
  249. How does the factory alarm security work for 2015 Civics?
  250. Bump stop noise?
