Steering Wheel Shaking
I just purchased a 2008 Civic EX Coupe to replace my 99. It has 107k miles. When I hit about 60 mph and let off the gas, the steering wheel starts to shake. I'm not hitting the brakes so it's not the rotors. When I hit the gas the shaking goes away until I lift again. Sometimes at 60 mph it will go away on its own while cruising. I rebalanced the tires and rotated to see if the vibration would move to the back. Still does it. Would a bad CV shaft do this? I don't hear any clicking noise from while turning. Any help would be great. Thanks in advance.
T
T
Re: Steering Wheel Shaking
Thank for the response. I need to get the car off the ground high enough to shake and inspect. I'll have access to a lift next week.
It's not an alignment issue. That would cause the car to pull in one direction. Only a loose steering component will cause a shake. Like was mentioned the inner or outer tie rods or the actual rack itself is most likely the issue.
About the steering rack theory, wouldn't it be possible to feel play in it with the wheels off the ground if it was the cause of vibration? I ask because I've suspected mine, but everything feels solid and I've even had an alignment shop check everything out. My vibration is more 30-45mph and load dependent.
To follow-up: I was able to get the car up on a friends lift/alignment rack. We checked the lower control arm bushing and ball joints for play and cracking of the rubber with a pry bar. They all are OK. We checked the play in the outer tie rods, steering rack and axles. They are all tight with no ripped boots. Nothing is bent from what I could see. Alignment was also within spec. I'm thinking it might be a botched wheel balance but I didn't think getting on and off the gas would stop/start the shake. I'm going to have a wheel balance done at a different shop and see if that's it. Thanks for the help.
A wheel balance will not cause the issue you are having. If you give it gas or brake and it goes away it is a steering or suspension component worn or loose. You didn't check the inner tie rods or rack which would be the issue.
So I had the wheels rebalanced. The fronts were out by really bad on the outside of the rim. The tech showed me where he thinks the last person put the double back tape weights on incorrectly. The tape was there but not the weights. Perhaps it was old tape. The vibration is gone. I was totally surprised that this could be the issue but it seems to have solved it. I'm keeping my fingers crossed. Thanks for your help.
Glad your issue is resolved.
Sometimes wheel balance or out-of-roundness vibration can vary based on throttle input and braking, due to the weight shifting on the wheels in question. The issue may present itself more at a certain amount of load.
Congrats my friend!
It's nice to hear that your problem is solved!
I had a same problem before a few years and couldn't believe that the solution was so easy..,
also couldn't insist more and be 100% sure for your problem, because each car is a different story..!
So you can enjoy your ride now!
Thanks guys. I thought it was important to close the loop on my problem so others could learn. I thought for sure something was bent or loose. I also can't believe those stick on weights actually stay on through NJ winters. There has to be a better way!
I have been battling a similar issue all year, thrown tons of parts at the car trying to remedy it. I have new wheels on the way and also wonder if there could be a stiff spot or runout in the tires that the shops have not been able to detect. Might try a roadforce balance when I get em put on the new wheels.
I have found in the past that Honda's are very sensitive to wheel balance and roundness. Maybe because they are light cars, and then we go and put bigger/wider tires on them which adds more weight at a farther point from the axis of rotation, coupled with stiffer suspension translating it into the chassis. Just a theory but I have always had problems with wheel vibrations in my cars and it is something that bothers the hell out of me. Even when it is minor enough that most people probably wouldn't notice it.
A car should never rattle the steering wheel in off throttle or transition situations even with a off balance wheel. I've had bent wheels and wheels way off and it will not rattle only at that time unless there is a steering component loose or worn. A off balance wheel is only making the problem prematurely noticeable. I still think there is a worn inner tie rod in or steering rack and the problem will eventually get worse to where you notice it all the time.
Same with a minor bend in a 17" rim. I think that over sizing just makes everything more sensitive.
Idk about this. I have had two brand new CRZ's in the past that I put 17" and 18" wheels on, and even with the slightest out of balance (within spec per the tire shops) on the 18" tires you could feel it all the time.
Sorry to thread jack, it's just rare to get any kind of thoughtful input on this subject.
From the front that you feel it in the wheel? Sounds like an axle.
My question is was this a long-term fix for you? There seemed to be some disagreement about whether the wheel balance was the whole problem.
Mikee75,
My 08 is still OK without any vibrations since the wheel balance. It has been about a year and I have put on about 10K. I hope you can locate the problem. Vibrations can be very frustrating.
T
T
Apple395
10-21-2013 08:26 AM
black94lude
22
08-01-2013 12:43 PM
