What is cruise main light on dash board ?
I have a seen cruise main light on dashboard but I don't jave a cruise control in steering wheel?
how its possible ?
Why light is available if cruise control not their ?
how its possible ?
Re: What is cruise main light on dash board ?
What trim level and year do you have? I am not aware of any 2006-2015 Non-Si civics that do not have cruise control from the factory. Is it an aftermarket steering wheel?
Is it the EX, LX, Si, or Hybrid? Sedan or Coupe? The only model that doesn't have cruise control is the Si as it is a manual. Could you attach an image of your steering wheel? This will give us an idea of what you're seeing.
If the car does not have cruise control and the indicator light is on at the dash, then it probably is a short in the gauge control module causing the indicator to illuminate.
My bad. Saudi Arabia still allows importing vehicles. It is still in question as to whether it is an aftermarket wheel, as that is the only way that there would be no cruise control. Saudi Arabia sells what appears to be similar to the EX model.
If it had cruise control previously and currently using an aftermarket wheel, then a short is probably causing the dash light to illuminate.
That is a good hypothesis. It's not that I disagree, I just wanted something like an image so we can tell in an instant if it is just user ignorance (no disrespect intended towards Muhammed, it happens to everyone) or something like your aforementioned short in the gauge control module.
If it did previously had steering wheel cruise control buttons, the short can be anywhere along the wiring or the gauge control module.
Rob_KCMO
04-21-2010 08:33 AM
Aodhan
09-17-2007 08:46 AM
Wallace996
04-12-2002 08:43 PM
