Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Oil leak between oil filter and VTEC solenoid
Old 07-16-2018, 06:04 PM
firewall's Avatar
Default Oil leak between oil filter and VTEC solenoid
I've got oil leaking right above the oil filter and below the VTEC solenoid. Motor's a K20z3.
It looks like a sensor, and is surrounded by a black rubber shroud. Sensor's wires go up nearby the valve cover.
Here's a video of it. Video starts off looking at the right fender well, and looks between the oil filter and VTEC solenoid. A black rubber shroud can be seen center-screen.
https://www.youtube.com/watch?v=iEnQJQkJe98&feature=youtu.be
Any help's appreciated.
Old 07-17-2018, 12:39 AM
holmesnmanny's Avatar
Default Re: Oil leak between oil filter and VTEC solenoid
Would it really kill you to record a video when it's sunny out ? I just don't understand how people can go in their garage with the lights off and flash a light and expect people to easily make out what they are looking at.
Then you can just pan as much around the area as possible instead of giving a halfway pan of the area.
Old 07-17-2018, 05:40 AM
firewall's Avatar
Here's a photo I found online of the same motor. The sensor I'm describing is the green part extruding directly above the oil filter (big red circle).
Old 07-17-2018, 09:06 AM
Hysterically Calm
TomCat39's Avatar
The black shroud is covering the oil pressure sending unit. It's a tapered thread (pipe fitting) sensor.
If it's leaking there, you replace the sensor. The metal to plastic mating has lost it's seal and it can't be fixed.
Be cautious and don't over tighten. The tapered thread seals up the hole but over tightening is known to snap the threaded head off in the block.
Old 07-17-2018, 11:15 AM
firewall's Avatar
Any suggestions on torque? Service manual doesn't mention it.
Thanks a lot.
Old 07-17-2018, 02:55 PM
Hysterically Calm
TomCat39's Avatar
I didn't do a specific torque, once it started resisting I did about 2/3 to 1/2 turn and called it a day.
You could do finger tight and then one full turn.
Old 07-20-2018, 08:55 AM
I'm not Rick!
rick_rabies's Avatar
lots and lots of kseries have leak :/
my z3
my k24a4
friends k24a4.
replaced VC gasket. VTEC gasket and new filter. still didnt fix it. oil pressure unit................
Old 07-22-2018, 11:12 PM
Hysterically Calm
TomCat39's Avatar
my z3
my k24a4
friends k24a4.
Don't forget, the z3 has the oil cooler, there is an o-ring behind it. Not sure on the K24's but wouldn't be surprised if they do too.
On mine, I've replaced the vtec "filter" gasket, the oil pressure sending unit and the oil cooler o-ring. I think I've got mine fixed finally.
Old 07-24-2018, 05:00 AM
I'm not Rick!
k24s do not have the oil cooler, but good call. k24 is oil filter straight to block surface.
come to find out new VC gasket was pinched. little nubs werent in the cuts outs in the valve cover. smashing revlimiter in spalding MO roads and im smelling oil puking and cooking. (aka getting pumped out)
good vapors though. true vaping. makes me feel manly. the smell of cooking oil .......ok il stopl. i need more coffee
Old 07-25-2018, 01:52 PM
wabo's Avatar
13 ft/lb + hondabond
csx service manual
engine mechanical page 8-9
eclorian
Honda CR-V & Element
01-08-2018 08:43 PM
helpmeplease
K Series
03-04-2017 08:00 AM
FrontwheelENT
14
08-20-2012 05:30 AM
Spectrum24x
07-30-2006 10:39 AM
00siandrew
03-22-2006 07:56 PM
Quick Reply: Oil leak between oil filter and VTEC solenoid
