2007 honda civic ex 1 inch lift
I have 2007 honda civic ex coupe. I want to lift it to put on 225 60 16 tires on it. I am curious could i just put on longer springs with same springs to gain that inch? Are there springs from another vehicle that would fit and were longer? Do i need to find a custom spring shop to have them made and who does that? Would adjustable coilovers and 1 inch coilspring spacers work even though adjustable coilovers are designed to lower a vehicle ? I am determined to making this work, but i want it done clean,,, it is my daily drive.
Re: 2007 honda civic ex 1 inch lift
Why do you want to run that specific tire size ??? It is more than 3/4" wider and 1.75" taller than the stock size tire... and this drastic of a change will make your speedometer display slow as well as potentially create issues with your ABS and VSA systems. The normally accepted variance in tire diameter/circumference is +/- 3%. The tire size that you have chosen is 7% taller than stock.
Obviously no manufacturer would create products that would be harmful and/or dangerous to the operation of your vehicle, so the only way you will find a taller spring is to use one from another application. I personally am unaware of a cross breed solution. Sorry.
Thanks for your input, I chose the size thinking it wouldnt be an issue lifting a cat 1 inch,,, i would love to make it work,, i bought universal coil spacers ,,,but universal does not fit stock spring. Would adjustable coilovers and the spacers work? I know it will be a stiffer ride but i might be ok with that ,,,,if it would work then i have that option. ,,,,How about a company that could make a longer open end coil to give me an inch lift?
Phailzilla
07-19-2013 06:08 PM
