2008 Civic EX air conditioning help
So my wife’s Civic has suddenly started having ac issues. While turning the ac on, full blast at MAX AC, we are getting semi-cool to warm air.
An odd attribute to this case is that when the AC is ON, the compressor turns, but never cycles off. The only way to stop it from spinning is turning off the ac from inside.
I’ve already:
Checked Freon levels. It’s full.
Checked the relay in the fuse box under the hood.
I can feel the “L” line cooling up, and the “H” line staying warm.
Any othter suggestions?
Thanks.
I’ve already:
Thanks.
Re: 2008 Civic EX air conditioning help
If the fans are working properly and the Freon charge is correct, the low side line should both be cold all the way to, and have condensation on it all the way to the compressor.
At first the low pressure line was warm to the touch, but suddenly after I was troubleshooting some options, it started to get pretty cold. The compressor still stays on and doesn’t cycle however.
if the refrigerant level is in fact good the compressor is not building enough pressure to allow it to get cold, and also shut itself off.
otherwise I would assume it's low on charge because expansion valve failure on hondas is rare.
PsychoCam
Honda Civic (2001 - 2005)
10
05-30-2011 08:25 AM
lakerschamp2000
19
04-24-2009 12:37 PM
