Engine lost power between 20 kms and 30 kms
Re: Engine lost power between 20 kms and 30 kms
when i go slow between 20kms and 30kms the engine is shaking like loosing power after 30kms every thing work great
The 3rd clutch sensor is the easy one to change and jack stands and a metric wrench set is all you need to change it. The 2nd gear sits under the air filter housing and you have to remove it to get access. DO NOT follow the common BS that you need to remove the battery and tray , work the air filter housing out carefully and you won't need this . just disconnect the positive while you're working on the electrical system and you will be fine.
Ufretin
08-22-2011 09:01 AM
Drew96EJ
04-25-2005 08:07 PM
