Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
shift boot
Old Dec 25, 2008 | 11:44 AM
jdmfreak1992's Avatar
Default shift boot
hay guys I got a skunk 2 shift **** today and I really like it but the plastic peace on the **** boot looks retarded is there away to remove it or do I have to buy a new shift boot which is what I planed on. Also I can't figer out how to get the stupid boot off is there a dyi on honda tech that I'm just not seeing? If any one kind tell me how that would be great thanks.
Old Dec 25, 2008 | 12:08 PM
Default Re: shift boot
Ok I found out how to get the boot ring off but I still can't find out how to completly remove the boot from the console.
Old Dec 25, 2008 | 01:03 PM
LatinEM2's Avatar
You have to remove the console and look underneath. The boot is heald by some clips and staples.
Old Dec 25, 2008 | 08:34 PM
00falcon's Avatar
it's a pain in the butt, took me forever.
i used a washer to hold up the Type R boot.
Old Dec 26, 2008 | 11:29 AM
I can't figure out how to get the console out.
Old Dec 26, 2008 | 11:53 AM
Ok good new I the stupid console out and now I just Have the black plastic peace the boot and that silver trim. I haven't removed the boot yet because I don't have a type r boot yet. I was wondering what part of the boot that I had to trim, is it the part with the staple in it?
Old Dec 26, 2008 | 12:21 PM
It Wasn't Me's Avatar
Yes, you'll be trimming that section of the replacement boot. Remove those staples, along with the OEM boot. Trim the new boot one section at a time. Start with the front and work your way around in a clockwise motion. It's relatively simple, but take your time so you don't mess up.
Edit: When I did mine, I used a thick needle and heavy thread to attach my new boot. It was easier than trying to reuse the staples.
Old Dec 26, 2008 | 12:38 PM
Ok thanks every one big help. Ok so my only other question before I order is will this boot work. I'm ordering the itr one.http://www.inlinefour.com/jdmtypshifbo.html
Old Dec 26, 2008 | 12:52 PM
You can buy one for less on eBay.
Old Dec 26, 2008 | 03:37 PM
integ_lude's Avatar
FYI I just fixed a lot of problems someone did to my wifes new car and the boot was one. He destroyed the ring around the boot so what I did is I put the boot over the entire thing, tucked underneath center console and glued it. There is many ways of making the boot look nice this was one (depends on boot). Another tip for you is if you have a shift **** with those annoying screws that always fall out try buying tube from a hardware store (the kind you can buy per foot) and buy the first small one that fits over the steel bar, then go up one more size to go over that one, and build up until your **** fits snug then glue it or just keep it the way it is. Hope this helps
red98integra
Dec 17, 2008 10:33 PM
IMHARD2
Jul 13, 2008 07:52 AM
speedeGdc2
Mar 17, 2008 10:19 AM
siaemsi
Apr 8, 2004 11:54 AM
allmotorls95
Aug 12, 2002 12:01 PM
