My clutch makes a clicking sound
* B A N N E D *
When I press on the clutch I hear a click sound. If I press down more I will hear a 2nd click sound. Is this normal?
Re: My clutch makes a clicking sound (vroomboom)
Normal...I have a 2004 civic and it used to make that noise..It also made a noise when down shifting...If this is happening you need to look at getting a new clutch and flywheel. I got the stage 2 exedy clutch and ACT light weight racing flywheel and I have no complaints....It grips great and was the best mod I did to my car other than the custom turbo kit I just put on it..So you might need to look at getting a new clutch and that should fix the problem.
D17a2 @ 8 psi= 214whp
Bitches Love Boost
Bitches Love Boost
* B A N N E D *
Re: (HONDURA2K2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDURA2K2 »</TD></TR><TR><TD CLASS="quote">It's most likely your clutch master cylinder making the clicking sound. mine is doing the same thing.</TD></TR></TABLE>
Will I damage anything if I still drive the car w/ the clicking sound? Also how much will it cost to get it fix?
Re: (vroomboom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomboom »</TD></TR><TR><TD CLASS="quote">
You won't damage anything, I drove mine around like that for quite a while and then had it replaced under warranty right before I decided to void mine.
* B A N N E D *
Re: (katzenjammer84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katzenjammer84 »</TD></TR><TR><TD CLASS="quote">
You won't damage anything, I drove mine around like that for quite a while and then had it replaced under warranty right before I decided to void mine. </TD></TR></TABLE>
Cool, thanks for telling you had the same problem and got it fix, but would help if you told me what did they fix lol
When I got mine fixed it was the Master cylinder also..So that is what you need to have them fix..but for the price of getting a clutch and flywheel with the tranny already out...you should just look at getting the whole thing like i did..it was the best upgrade for the d17 other than turbo
Master cylinder replacement doesn't involve transmission removal, it's right underneath the dash against the firewall.
If you don't know what you're talking about, stop pretending like you do.
bbrian
Transmission & Drivetrain
06-14-2013 10:09 AM
