Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
P0128 code
Old Jun 4, 2011 | 05:54 PM
jasrams's Avatar
Default P0128 code
let me get quick to the point my car is throwing a P0128 code- coolant thermostat (coolant temperature below regulating temperature how do I fix this
Old Jun 4, 2011 | 07:14 PM
jasrams's Avatar
Default Re: P0128 code
P0128 OBD-II Trouble Code
Technical Description
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
What does that mean?
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
Symptoms
You will likely not notice any drivability problems other than the MIL illumination.
Causes
A code P0128 may mean that one or more of the following has happened:
Low engine coolant level
Leaking or stuck open thermostat
Faulty cooling fan (running too much)
Faulty coolant temperature (ECT) sensor
Faulty intake air temperature (IAT) sensor
Possible Solutions
Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
Old Jun 4, 2011 | 07:30 PM
slowcivic2k's Avatar
Thermostat is generally the faulty part. Honda's don't have a track record for bad coolant temp sensors or intake sensors. If you have one of those "performance modules" take it out now.
Verify the intake temperature, and the engine temperature with a laser thermometer and compare to scan tool data for those items, if the difference is more than 10 degree's from the sensor location, I would be leary of the sensor being inaccurate (very unlikely)
Old Jun 6, 2011 | 04:40 AM
jasrams's Avatar
thank you slow civic2k
mkrieger500
Sep 26, 2009 07:09 PM
davidfillups
24
Mar 17, 2009 10:29 AM
nsxracer79
Oct 25, 2008 02:03 PM
MPALUGHI
Jan 7, 2005 05:11 AM
sacredc0w69
Jun 5, 2003 02:03 PM
