Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
P0700 Error Code
Old Sep 21, 2012 | 04:58 AM
Zedt3's Avatar
Default P0700 Error Code
Hi, my EM2 started giving this error code and I am told it's transmission related. I have downloaded a copy of the service manual, but it does not explain this code, can someone help me please as to what it is, and how do I rectify the problem? And from the diagnostic it gave a reference of 1-1. And it said to refer to the Honda Service Manual.
I am going to guess that it probably means a code like P0711 - Problem in ATF Temperature Sensor Circuit
Help please!
Old Sep 21, 2012 | 05:27 PM
lazlong's Avatar
Default Re: P0700 Error Code
For P0700, it says to refer to the auto tranny DTC section. The only way to get that DTC is to put a diagnostic tool (scan tool, code reader, whatever you wanna call it) on it and see what code you get.
You can also diagnose it by the symptom troubleshooting index if it's showing any abnormal performance. That index is also in the auto tranny chapter.
Try resetting the ECM/PCM by pulling fuse #6 in the underhood fusebox for at least 10 seconds. This is to be done while the ignition is OFF. Then see if the code comes back.
BlueRex1020
Dec 4, 2025 01:21 AM
rex_f
Acura TSX
Dec 12, 2013 08:49 AM
mckenze44
Engine Management and Tuning
Sep 13, 2009 11:31 PM
