FIXABLE?
Old Aug 23, 2006 | 12:18 PM
DA6mike's Avatar
Default FIXABLE?
is this Fixable? ,
Old Aug 23, 2006 | 12:28 PM
ManBearPig4silly's Avatar
Probably.
Old Aug 23, 2006 | 12:42 PM
Flashmn's Avatar
Default Re: (I4sillypwr)
people really should invest in torque wrenches.
Old Aug 23, 2006 | 12:47 PM
DA6mike's Avatar
Default Re: (Flashmn)
engine is from car after a crash
Old Aug 23, 2006 | 03:00 PM
C_H_A_D's Avatar
Default Re: (DA6mike)
I would try it.
Old Aug 23, 2006 | 04:11 PM
b18ccivics's Avatar
Default Re: (NINJASWORD)
take it to a welder grind out the crack, fill in the grinded part, and retap to next size bigger, (probably a standard size) then drill out the mount (steel part) for the bolt to go threw
Old Aug 23, 2006 | 05:46 PM
metal craft's Avatar
Default Re: (b18ccivics)
i would break off the cracked part and fill the hole thing up with weld, re drill it and tap it, cuz if u just weld the crack it will crack again
Old Aug 23, 2006 | 05:56 PM
C_H_A_D's Avatar
Default Re: (metal craft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal craft &raquo;</TD></TR><TR><TD CLASS="quote">i would break off the cracked part and fill the hole thing up with weld, re drill it and tap it, cuz if u just weld the crack it will crack again </TD></TR></TABLE>
Bad advice.
I would try to grind down the area around where it is cracked so there is more room to weld. Then I would put a clamp on it to get it to pull back together. Then weld it and make sure you penetrate deep.
Old Aug 23, 2006 | 06:05 PM
Hamstr323's Avatar
that happend to me a few years ago with my boys type r motor (long story)
it got welded back up & tapped & didn't have a problem
Old Aug 23, 2006 | 07:05 PM
richeybrooks's Avatar
Default Re: (Hamstr323)
dont worry about it just use the other two holes. honda put three of them there so one could break and you would be fine.
Old Aug 23, 2006 | 10:49 PM
ssmdc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">take it to a welder grind out the crack, fill in the grinded part, and retap to next size bigger, (probably a standard size) then drill out the mount (steel part) for the bolt to go threw</TD></TR></TABLE>
I would not recommend drilling the factory steel mount. I was in a scenario were I had to do that, I gave it to my machine shop guy and it turns out it's some kind of hardened steel and you need special bits, drill press and patience. He charged me $60.00 including the price of the bits. Not worth it IMO.
Old Aug 24, 2006 | 01:23 AM
DA6mike's Avatar
Default Re: (ssmdc2)
THX guys,sefe my day
Old Aug 24, 2006 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASWORD &raquo;</TD></TR><TR><TD CLASS="quote">
Bad advice.
I would try to grind down the area around where it is cracked so there is more room to weld. Then I would put a clamp on it to get it to pull back together. Then weld it and make sure you penetrate deep. </TD></TR></TABLE>
You will end up grinding down to almost nothing anyway. THe second you start an arc on the block casting whatever is left of the cracked off piece is going to disintegrate anyway. Crack it off and build it up with filler. I've done it before and it works better.
Before.
After and before drilling and tapping.
Old Aug 24, 2006 | 08:27 AM
JK_Motorsports's Avatar
Odd, I've drilled and tapped a small bolt into mie to support and hold my oil lines, didn;t give the ol' $40 cordless drill even a workout.
Old Aug 24, 2006 | 09:54 AM
DA6mike's Avatar
Default Re: (JK_Motorsports)
thx all
migs
Feb 11, 2008 08:07 AM
. a d a m
Jun 17, 2007 01:07 PM
JDM_Frijoles
Sep 13, 2006 04:43 PM
shorto85
Feb 1, 2006 10:27 AM
matix
May 4, 2004 11:12 AM
